New battery time…..Odessey Dilemma
Discussion in 'Electrical' started by ProtoJ, Nov 28, 2021.
  1. Nov 28, 2021 at 6:29 AM
    ProtoJ
    ProtoJ [OP] New Member
    2018 Crewmax TRD Off-Road
    I’ve read the reviews and decided to get an odessey battery. I know direct replacement is a 24F…..however, the 34R seems to be more available. Who is using a 34R and which version? It appears there are lots of variants of this model.
  2. Nov 28, 2021 at 6:36 AM
    FortyNorth
    FortyNorth New Member
    Northern ON
    2014 Tundra Super White SR5
    I replaced my oem one this past summer with an Odyssey 27F AGM, has been great. Extremely similar to the discontinued Northstar 27F but a bit more CCA I believe.
  3. Nov 28, 2021 at 8:32 AM
    ProtoJ
    This is the one I found on sale and I’m stock
  4. Nov 28, 2021 at 9:06 AM
    ProtoJ
    This one actually might be the ticket. So many models of battery!
  5. Nov 28, 2021 at 11:00 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Keep in mind, the factory charging system in your truck is voltage regulated and not designed to properly charge an AGM battery. You will need to alter the output voltage as well as put a trickle charger on the battery occasionally to prevent over draining the battery. Unless you absolutely need an AGM battery because you’re doing very heavy off roading, stick with the best wet cell battery you can find. An AGM is actually more maintenance needy than a regular wet cell.
    Dawoofles likes this.
  6. Dec 9, 2021 at 4:39 PM
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    why, AGM is not a gel battery and should charge just fine.
  7. Dec 9, 2021 at 4:47 PM
    Danman34
    Danman34 New Member
    Danny
    Because the required charging voltage for an AGM is higher than what the voltage regulated system puts out. Most agm’s require 13.9 or higher constant voltage in order to charge. The voltage is regulated to no more than 13.7 after warm up.
  8. Dec 9, 2021 at 4:58 PM
    poheller
    Scot
    2018 platinum
    Cool to know, thanks
