NEW! 2007+ Tundra ABS Guards
Discussion in 'SDHQ Offroad' started by sdhq_offroad, Oct 3, 2016.
  1. May 10, 2018 at 9:48 PM
    #61
    geno0506
    geno0506 New Member
    Michael
    I’m in. :spending:
    HighDesertSurfer likes this.
  2. May 10, 2018 at 10:17 PM
    #62
    @sdhq_offroad will these work with aftermarket spindles? Have a RC lift kit bolts I have on mine look smaller
  3. May 11, 2018 at 11:31 AM
    #63
    sdhq_offroad
    sdhq_offroad [OP] New Member Vendor
    GILBERT, AZ
    I cannot confirm nor deny the fitment with aftermarket spindles. We have not installed any here in house but we have had quite a few members with 6" lifts and such order them. Fitment should be the same as far as the bolt size (because the sensors has a set size on it), you may just need to buy shorter or longer bolts for it.
  4. May 11, 2018 at 11:32 AM
    #64
    Be placing order soon on em, Thanks
  5. Jul 30, 2018 at 12:06 PM
    #65
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Got these installed over lunch. Takes less than an hour to do. However, my parts bag had an extra 50mm bolt and was short a 45mm bolt. So I ended out needing to use one of the nuts that came in the parts bag on a longer bolt to take up the slack.
    FYI, you'll need to get under your truck from in front of the wheels to see the sensors.
    The tools list is a little incomplete. Here are the tools you'll actually need (but may not use) to do it right:
    • 2x 10mm wrenches (one of them needs to be a combo wrench with an open end, the other a socket for the torque wrench)
    • Loktite
    • Inch-pounds torque wrench (need 72 IN LB of torque)
    • 5mm Allen wrench
    • A light makes this job much easier
    When installing the rear guards you may not need to do the two-nut suggestion. I was able to unscrew the bolt with my fingers. If you have to use the second nut, this is when the open ended wrench may come in handy.
  6. Jul 30, 2018 at 12:17 PM
    #66
    sdhq_offroad
    GILBERT, AZ
    Thanks for the feedback! I have also got with my shipping department to double check all the kits we have on the shelf so that the longer bolt issue doesn't carry across. PM me if you want us to send a 45mm bolt out to you.
    T-Rex266 and Sas like this.
  7. Jul 30, 2018 at 12:20 PM
    #67
    Sas
    OKC, OK
    If you don't think it'll be an issue the way I did it then I'm not worried about it.
  8. Jul 30, 2018 at 12:21 PM
    #68
    sdhq_offroad
    GILBERT, AZ
    It won't be an issue. The 50mm bolts carry across to the Tacoma platforms and its easier for us to do it all in one kit rather than multiple kits.
    Sas[QUOTED] likes this.
  9. Jul 30, 2018 at 12:30 PM
    #69
    Great right up! Might add some color to mine not sure :popcorn:
    HighDesertSurfer and Sas[QUOTED] like this.
  10. Aug 12, 2018 at 12:02 PM
    #70
    HighDesertSurfer
    HighDesertSurfer Surf The Dirt
    New Mexico
    2018 SuperWhite DC TRD OR
    Leer shell
    Just ordered from @sdhq_offroad ! Free shipping!
    New Mexico has some pretty rocky trails and my scuffed up wheels show it after 10 mos.
    Decided not to tempt fate anymore and ordered the ABS guards.
    It just makes sense...
  11. Sep 2, 2018 at 9:04 AM
    #71
    HighDesertSurfer
    New Mexico
    Leer shell
    They are on!
    Easy to install...and by far...the cleanest part of the truck for the moment! :rolleyes:
    Thanks sdhq!
    MotoTundra, sdhq_offroad[OP] and Sas like this.
  12. Sep 4, 2018 at 8:44 AM
    #72
    sdhq_offroad
    GILBERT, AZ
    Looks killer! Definitely looks like you get out and use that thing!
  13. Nov 5, 2018 at 4:30 PM
    #73
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Definitely got to need another set to put on my new 2019 TRD Sport
  14. Nov 5, 2018 at 7:42 PM
    #74
    32vsnake
    32vsnake New Member
    david
    British Columbia
    2008 DC Limited
    @sdhq_offroad... any idea what shipping cost to Canada would be on these. Website doesn't seem able to calculate shipping to Canada.
    Thanks
  15. Nov 5, 2018 at 7:48 PM
    #75
    MotoTundra
    MotoTundra The Ocho
    Don
    I need these in my life!
  16. Jan 10, 2019 at 9:08 AM
    #76
    sdhq_offroad
    GILBERT, AZ
    Updated, these are now made out of solid billet and have a clear anodizing on them.
  17. Jan 10, 2019 at 9:42 AM
    #77
    csuviper
    Broomfield, CO
    Oh nice. Guessing it’s cheaper to CNC the parts vs bending, welding, painting and etching.
  18. Jan 10, 2019 at 9:44 AM
    #78
    sdhq_offroad
    GILBERT, AZ
    Cost a little bit more but having our CNC machine running it takes more off our production/welding crew so that we can keep more Tundra sliders on the shelf. :thumbsup::thumbsup:
  19. Jan 10, 2019 at 9:50 AM
    #79
    csuviper
    Broomfield, CO
    Gotcha. That works. Same protection.
  20. Jan 10, 2019 at 9:51 AM
    #80
    sdhq_offroad
    GILBERT, AZ
    Same protection.... actually, even more. Being able to machine it has allowed up to be able to encapsulate the sensor more so it does wrap around the sensor more than our previous style.
    MotoTundra and csuviper[QUOTED] like this.
  21. Jan 10, 2019 at 10:26 AM
    #81
    MotoTundra
    MotoTundra The Ocho
    Don
    Such a smart investment.
  22. Jan 10, 2019 at 10:28 AM
    #82
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    I always thought these should have been bigger to wrap around the sensor more.
  23. Jan 10, 2019 at 10:30 AM
    #83
    Tacogrande
    Jeremy
    Is there a forum discount? I never did get the discount when I ordered.
  24. Jan 10, 2019 at 10:32 AM
    #84
    sdhq_offroad
    GILBERT, AZ
    There is, you just need to type in your Tundras.com username into the notes section before you check out! Or you can always just PM me and we can get an order going
    T-Rex266 likes this.
  25. Jan 10, 2019 at 10:34 AM
    #85
    WTF?!?!?? Now I want those! Shuda waited :anonymous: anyone wanna buy mine?
  26. Jan 10, 2019 at 12:46 PM
    #86
    MotoTundra
    MotoTundra The Ocho
    Don
  27. Jun 7, 2019 at 3:25 PM
    #87
    sdhq_offroad
    GILBERT, AZ
    Just got these back from anodize. These are in packaging and ready for order!
    T-Rex266, csuviper and MotoTundra like this.
  28. Jul 2, 2019 at 9:55 PM
    #88
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    3" Suspension lift 18" method roost 35x12.5x18 ridge grapplers 2020 sequoia LED headlights
    Wow I just found these! Such a simple and great addition/mod
    Order coming soon
    olsin6 likes this.
  29. Oct 23, 2019 at 8:35 PM
    #89
    ccdawnpatrol
    ccdawnpatrol New Member
    Salt Lake City, UT
    2017 SR5 MGM CM 4x4 5.7L
  30. Oct 24, 2019 at 9:24 AM
    #90
    sdhq_offroad
    GILBERT, AZ
    ccdawnpatrol[QUOTED] likes this.
