Need some steps
Discussion in '2.5 Gen Tundras (2014-2021)' started by BlueBottle, Oct 17, 2016.
  1. Oct 17, 2016 at 10:16 AM
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    I need some kind steps. I prefer something high clearance. I was eyeing the GoRhino raptor style steps. I like that it's high clearance and also protect from door dings.
    Anyone else have any other suggestions that I can look at?
    AMP power steps are nice but over my budget....
  2. Oct 17, 2016 at 10:22 AM
  3. Oct 17, 2016 at 10:44 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
  4. Oct 17, 2016 at 11:16 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I been seeing those! I don't want anything that drops down that low though. Those are so cheap. I might be worried about quality and strength
  5. Oct 17, 2016 at 11:17 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    just bite the bullet and get some nice sliders
    BlueBottle[OP] likes this.
  6. Oct 17, 2016 at 11:34 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I've thought about that but I don't have any intentions to take this truck anywhere I will be needing sliders. Also sliders aren't the best for steps from my past experiences.
  7. Oct 17, 2016 at 11:54 AM
    sdhq_offroad
    sdhq_offroad New Member Vendor
    GILBERT, AZ
    https://www.tundras.com/threads/new...nd-double-cab-bolt-on-sliders-from-sdhq.6192/
    These are our sliders. I have them on my tundra, they act as a nice step although they weren't designed to be a step. They are high clearance and hug the body nicely. All 4130 chromoly steel, tig welded, and 100% bolt on. As far as I am aware, we are the only company that makes our first mounting point at the front body mount (works with body mount chops). When you drop off a ledge, the first part that is going to hit is right behind the front wheel. Most companies don't have their first frame support until 18-20" back.
    There is really no in between for sliders and steps from what I have seen.
    Edit: This is a frame mounted slider set.
  8. Oct 17, 2016 at 12:30 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Been meaning to ask, would it be okay to mount these raw? Will there be rust issues in the future?
  9. Oct 17, 2016 at 12:36 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Those are nice. Definitely be one of the sliders I would considered if I were to go the slider route. do you have any option to plate it so it's easier to use as a step?
  10. Oct 17, 2016 at 12:39 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I had similar thoughts in mind, ended up going with Iron Cross HD steps. I love em. High clearance but not much door ding protection, I think you will need something that sticks out pretty far for door dings.
  11. Oct 17, 2016 at 12:46 PM
    sdhq_offroad
    GILBERT, AZ
    As with any steel, it will rust. I don't know what kind of weather conditions you have in your area but if you wanted to mount them raw, I would just do a clear coat of spray paint.
  12. Oct 17, 2016 at 12:54 PM
    RCI steps featured here. More support than my current ADD ones.
  13. Oct 17, 2016 at 1:30 PM
    sdhq_offroad
    GILBERT, AZ
    We don't offer it as an option but we could probably do something for you if interested.
  14. Oct 17, 2016 at 1:40 PM
    SOCO Tundra
    SOCO Tundra When do you stop being the FNG?
    bsr
    SOCO
    '16 SR5 TRD Off Road, DBL Cab, Super White
    Leer topper, MagnaFlow, TRD CAI, TRD Hvy skid plate, and I want less chrome!
    STOP!!! I just crushed my right side, Toyota brand, steps. Hauling a kayak to Lake Deweese here in Colorado for some fishing. Heading nose over a little drop and heard something scrap. Stopped and backed up. Got out again and looked, no rocks, no boulders, just some dirt. Got home and the Toyota steps where at the door sills.
    Definitely think about the construction, and go for solid and real steel if you can. I didn't think about the dirt as much as I should have thought about the weight coming down on the steps.
    Great question, as I was going to ask about sliders. My 2 cents, skip the steps, get rock sliders and weld them to the frame. I read that is the way to go for strength.
  15. Oct 17, 2016 at 5:21 PM
    thoj
    thoj New Member
    2015 black tundra SR5 crewmax 4x4
    zcarpenter92 and BlueBottle[OP] like this.
  16. Oct 17, 2016 at 5:26 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Those are nice. Do you have a pic from the side of the truck? I'd like to see how low they are.
  17. Oct 17, 2016 at 5:51 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Completely off topic, but for a 7" lift that thing looks badass man!
    thoj[QUOTED] likes this.
  18. Oct 17, 2016 at 6:15 PM
    Kilos and BlueBottle[QUOTED][OP] like this.
  19. Oct 17, 2016 at 6:29 PM
    NFab Rough Country Go Rhino
  20. Oct 17, 2016 at 6:41 PM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    I'm a supporter of Nfab. They are the best of both worlds...sliders and steps
  21. Oct 18, 2016 at 7:52 AM
    SuperSilverTundra
    SuperSilverTundra i didnt pull up i Landed
    Nick
    Los Angeles California
    16 TUNDRA 5.7 PLATINUM-PRO
    3"/1" TOYTEC 18x9 XD818 Heist 295/70r18 COOPER XLT DirtyDeeds BAMuffler 2018 LEDs KatzKin Leather S&B CAI
    what does a set of these cost?
    Kilos likes this.
  22. Oct 18, 2016 at 8:16 AM
  23. Oct 18, 2016 at 11:34 AM
    sdhq_offroad
    GILBERT, AZ
    I could be wrong, but I am 99.9% sure that those bolt straight to the body. If you were to drop on those, you would rip the bolts right out of the body. So those would not be a slider.
    757TUNDRA and joonbug like this.
  24. Oct 18, 2016 at 3:43 PM
    stefan702
    stefan702 IG: 702stefan_
    Randy
    Las Vegas
    2015 Tundra TRD Offroad
    IG: 702stefan_
    Bro I just put @sdhq_offroad sliders on last night!! Those bitches are solid!
    AnonVet likes this.
  25. Oct 19, 2016 at 10:11 AM
    thoj
    thoj New Member
    @zcarpenter92 well I just put what I had since the op asked for
    I'm just sayin....:notsure:
  26. Dec 7, 2016 at 6:35 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Ended up getting a great deal on some GoRhino RB10's during black friday.
    Im pretty happy with them.. Makes it easier to get my folks in and out and they also act as door ding protector and it looks like it will also shield the side of my truck from tire spray since I don't have mud guards.
    C5B13220-E82E-4063-939B-DAD2E85A6023_zps_f13864611b906990a6e47fd7ac90c7abf2ae82e2.jpg
    180D47DF-63CD-4665-B521-A58847D0678D_zps_2affc0d6bcdd261522f0e811905dad10e70ee2b7.jpg
