Need some pointers
Discussion in '1st Gen Tundras (2000-2006)' started by kurticus91, Jul 16, 2019.
  1. Jul 16, 2019 at 6:28 AM
    kurticus91
    kurticus91 [OP] New Member
    Greetings guys, new here. I'm going to look at an 04 SR5 later today and was wondering what are some things specific to 1st gen tundra maintenance that I should check before I buy? Do they have lower ball joint issues like the 3rd gen 4runners? Timing belt and water pump? Any and all tips are greatly appreciated. Here's a pick of my 2002 SR5 4runner for attention. Cheers
    Brown Bear, bmf4069 and Darkness like this.
  2. Jul 16, 2019 at 6:39 AM
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Leitner Designs ACS
    Welcome. Nice shot.
    There are a ton of super knowledgeable guys on here -- I don't count myself as one of them -- so hold out for one of them to chime in. You've definitely come to the right place.
    Pinay likes this.
  3. Jul 16, 2019 at 6:44 AM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    I ran 200k on mine.
    My issues:
    1) Exhaust Manifold leak - never did fix it.
    2) One starter replacement - That was expensive.
    3) Last 50k miles headlight would go out every 2-3 months. Never could find the cause.
    kurticus91[OP] likes this.
  4. Jul 16, 2019 at 6:57 AM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    Timing belt and water pump replaced every 80k is the big one. It is an interference engine.
    05 and 06 have a 5 speed transmission and vvti motor if you're on the fence between what year to buy.
    bmf4069 and kurticus91[OP] like this.
  5. Jul 16, 2019 at 6:59 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    04 is a good year, the bugs were worked put by then. Has the bigger front calipers and good 4 speed auto. Does not have VVTi or air injection system.
    Timing belt and water pump as you mentioned are the only big ticket maintenance items. Lower ball joints have a reputation as a weak point but not something to be afraid of as long as they're in good condition. They did get slightly bigger on 05/06 models, but again not something to fear. Check the undercarriage carefully for rust. Check all the fluids but pay attention to the radiator fluid and trans fluid to be sure they aren't mixing. There have been reports of the trans cooler leaking into the radiator.
    They are solid trucks, good luck and welcome.
  6. Jul 16, 2019 at 7:01 AM
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    This video is helpful
    • Frame rust. Not sure what state you're in but inspect it thoroughly. Make sure someone didn't paint over rust.
    • Early ones did have LBJ issues but there was a recall done. I don't hear about it still being a major issue. If you're buying one with 100K+ miles you'd probably want to replace them anyways.
    https://www.youtube.com/watch?v=cPfQcIXmFiU
  7. Jul 16, 2019 at 7:26 AM
    kurticus91
    Thanks guys. I'm familiar with the pink milkshake, not personally, but it's been mentioned a few times on the 4runner forum. I'm in SoCal so rust SHOULDNT be an issue, but I'll be all up under that truck before I take it home
    Darkness likes this.
  8. Jul 16, 2019 at 9:47 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    BestGen and joonbug like this.
  9. Jul 16, 2019 at 10:27 AM
    bmf4069
    bmf4069 Yup, that's car parts in a dishwasher
    TX
    02 AC sr5 4wd v8
    Rear diff breather is something to look at. It'll stick and cause diff juice to squeeze past the axle seals and do bad things to the rear brakes. Some of us have parking brake issues, and squishy brake pedals. How many miles? Pics or a link?
    HappyGilmore likes this.
  10. Jul 16, 2019 at 10:46 AM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    I bought an 06 that I'm happy with, but also drove a 2004 when shopping. Both seemed to have the same acceleration, at least from 0-70mph during my test drive. I'm told the VVTi motor is supposed to be 1-2mph better, but who really knows when you consider traffic and short vs long trips.
    I have not had the smog pump issue yet, but had I known there was no pump on the 2004, that would have made an impact on my decision making process. One less thing to put you into limp mode, and $2k plus repair if you're unlucky to have it fritz out when your far from home and have to rely on the nearest dealer. The 4 speed also has a dip stick if that is important to you. My double cab does have the head curtain airbags that I don't think were available on the 2004 and earlier. A little more peace of mind when hauling the kids, but it is a 5,000lb truck, so maybe not as critical.
    Darkness[QUOTED] and speedtre like this.
  11. Jul 16, 2019 at 11:18 AM
    remington351
    2006 SR5 DoubleCab
    I'll also add that the 05-06 have the funky master cylinder with some funky proportioning valve gizmo that when your master cylinder wears out you have to buy a $1,300 combo unit. There's a couple threads on here about it if you do a search.
    speedtre likes this.
  12. Jul 17, 2019 at 4:25 AM
    Professional Hand Model
    Hand Protectors
    1) Factory recall in 05’ fixed LBJ. If there is a problem after that, then its due to punishment.
    2) TB 9 years or 90k miles.
    Buyer beware.
    Openbaffle likes this.
