Need more HP/Torque for towing my camper
Discussion in 'Towing & Hauling' started by snogoer13, Jul 8, 2019.
  1. Jul 8, 2019 at 8:57 PM
    snogoer13
    snogoer13 [OP] New Member
    2014 Tundra Limited Crew Max
    Hi Folks!
    I have a 2014 CrewMax with the stock V8. I tow a 9500 pound camper and need more power for the hills of NH and VT. Any suggestions on how to ramp up the pulling power? I put in a K&N filter, but I'm thinking about a cold air intake, maybe a new muffler set up. Any suggestions or recommendations?
    Thanks!
    Rica25 likes this.
  2. Jul 8, 2019 at 9:01 PM
    tmart
    tmart New Member
    Travis
    Supercharger!!! You only need about 7500-8k total, do it!!!
    Gungho, Rica25, 10TundraSR5 and 2 others like this.
  3. Jul 8, 2019 at 9:06 PM
    snogoer13
    Thanks tmart. I'm hoping to keep the upgrade under $1K if possible...budgets!
  4. Jul 8, 2019 at 9:09 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    You're awfully close to the tow capacity of these trucks. I'm sure a heavy duty truck is not anoption but that is the only good and safe solution.
    As far as more power goes, you could do a super charger and gain a lot of hp and trq.
    Or you could talk to Keith at dirtydeeds and get long tube headers, exhaust, and and a bully dog tuner. Dollar for dollar this is your best option to add power but honestly HP isn't the answer to your towing issues unfortunately
  5. Jul 9, 2019 at 3:34 AM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    I would not waste money on CAI. It will just make noise. For $1000 I think your options are pretty limited. For a trailer that size you need a 3/4 ton with a diesel.
    sdde4n, nvrgvup444 and Y0TA PR0 like this.
  6. Jul 9, 2019 at 4:44 AM
    Professional Hand Model
    Hand Protectors
    Bigger truck. Or, smaller trailer.
  7. Jul 9, 2019 at 11:05 AM
    Tracy Perry
    Tracy Perry New Member
    Tracy
    East Texas
    2019 MGM TRD Off-Road 4x4
    When your trailer starts getting in that range of weight - it's time for a 3/4 or 1 ton truck to safely tow.
  8. Jul 9, 2019 at 11:08 AM
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    24 limited hybrid offroad
    I agree with the above posts. intake/exhaust doesn't really do much. The way your truck comes from the factory is pretty much the best its gonna get barring a supercharger. Either sell the tundra and get a diesel, or bust out for the supercharger. I vote supercharger.
    sdde4n, jewsNbrews and nvrgvup444 like this.
  9. Jul 9, 2019 at 12:00 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    4.88 gears will give you way more bang for the buck than any motor mod (minus blower)
  10. Jul 16, 2019 at 1:29 PM
    MrMax
    MrMax Introvertigo Eximious Geargasm
    Rob
    Eastern Iowa, USA
    2011 Crewmax S/C TRD Rock Warrior
    Torque is what you want. $1K is not going to buy a lot of torque but it will yield you a little. Honestly you and I are towing around the same load and I must say you either need a bigger truck or SC that sucker and be happy with the truck you already have.
    Black Wolf, Rica25 and Watt maker like this.
  11. Jul 16, 2019 at 4:21 PM
    avgasman
    avgasman New Member
    It never ends does it?
    I originally installed the SC to help with towing - which really never materialized. When I have towed with it you don't really notice the power unless you're climbing a long steep grade with over 1/2 throttle but holy cow does it move.
  12. Jul 16, 2019 at 7:48 PM
    snogoer13
    Thanks for all of the awesome replies - I'll let you know which way I go!
    Watt maker likes this.
  13. Jul 16, 2019 at 8:57 PM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    This. Too much trailer for a Crewmax.
    Rica25 likes this.
  14. Jul 17, 2019 at 10:50 PM
    Trog
    Trog New Member
    Kevin
    N. Africa
    Voodoo Pro
    4in ready lift, Rockstar's and Nittos
    Black Wolf likes this.
  15. Jul 18, 2019 at 8:44 PM
    snogoer13
    To clarify - trailer dry weight is 7,800 and I never top it off with weight. I'm probably pulling 9K at the absolute most...usually more like 8,500. Adding Airbags next week which should help the tow as well.
    Watt maker and Bigboitundra like this.
  16. Jul 18, 2019 at 8:58 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    How far over gcwr is that combo?
  17. Jul 23, 2019 at 2:27 PM
    snogoer13
    Tundra is rated for 9,500 - Trailer dry is 7,750.
  18. Jul 23, 2019 at 4:25 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Dont forget that 9500 is with no gear or passengers in the truck(passengers other than driver)
    It’s easy to load 500-1000+lbs into a trailer. Adds up fast
