Need honest advice: hyper-tech interceptor
Discussion in 'Performance and Tuning' started by muhman_527, Jun 22, 2019.
  1. Jun 22, 2019 at 12:43 AM
    muhman_527
    muhman_527 [OP] New Member
    Houston Texas
    okay I want to get the hyper tech interceptor for my 2011 tundra 4.6L v8 sr5. I have a 6 inch lift with some big ole 35’s that slowed my truck down so much that I could barely hit 80. I ended up emptying my wallet and regearing to 4.88 gears which helped a lot but I drive like an a**hole and I want my truck a little more fun to drive. Looking thru the performance mods I’ve decided to go with a tune because I heard cai were useless on tundras and long tube headers are kinda pricey (college kid funds). In terms of tuner/programmers it has boiled down to a custom tune or a hypertech interceptor. Leaning towards the hypertech because that’s what dirtydeeds recommends and he’s a smart man. However I’m reading a lot of mixed reviews in terms of the interceptor and that it just throws codes. I was hoping I could get some good experiences/reviews before I pull the trigger. Thanks in advance. And yes i know I need a 5.7
  2. Jun 22, 2019 at 3:03 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    Ran one. Noticed no change except for the codes I got weekly.
  3. Jun 22, 2019 at 5:22 AM
    Bigdog
    Bigdog New Member
    2014 sr5 tundra 4x4
    7 inch pro comp lift 37 12.5 nitro ridge grapplers 639 k&n cai hyperforce interceptor tuner
    Same issue thru codes an went thru two mafs took off an BigRed runs better
    andy9743 likes this.
  4. Jun 22, 2019 at 5:23 AM
    Bigdog
    Bigdog New Member
    2014 sr5 tundra 4x4
    Oh an i still have sitting on bench in garage along with throttle body spacer
  5. Jun 22, 2019 at 6:23 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    I did like the pedal commander thing. I still run that. Grabbed a trd blower and never looked back.
  6. Jun 22, 2019 at 7:07 AM
    Duneflyer
    Duneflyer MGM is the light at the end of the tunnel
    Darren
    Yuma AZ
    2017 1794 edition Crewmax 4x4
    Nitro 4:88 gear package with locker in rearend, Procomp 6" lift, mid travel arms, with devers on back, Fox 2.5 coilovers
  7. Jun 22, 2019 at 7:47 AM
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    I would definitely go with a tune.
    I ran the hypertech interceptor and was unimpressed. I also had codes pop up a couple times. I removed it and haven’t had any random codes since.
  8. Jun 22, 2019 at 8:40 AM
    dirtydeeds
    Keith
    USA
    2003 and 2013 tundra
    more than I can list here
    I recommend the Hypertech without the pedal module.
    If your truck is pre 14’ codes aren’t as likely. 13’ and older they’re actually unlikely. But possible. Po101 is the kne I’ve seen. It doesn’t hurt anything, it’s just annoying.
    Pretty sure Mat can’t tune a 4.6, but if he can that would be a great option as well.
    All that said, Hypertech has a guarantee. Pretty sure it’s 30 days. Nothin to lose. If not happy send it back. But each and every truck I’ve installed on onto, there was a noticeable difference.
    Call for details. 760-877-4234
  9. Jun 22, 2019 at 9:35 PM
    muhman_527
    Houston Texas
    Thanks for everyone’s input. I think I am going to test out the hypertech interceptor and if I don’t like it I’ll send it back since it’s just a plug and play. If that doesn’t work out then I’m going to look into custom tunes. I guess the best way to get a real answer is to try it for myself. Had the same run in with the rough country lift kits having a two sided experiences. Thanks again peeps
