Need help with truck issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by Erichudgins, Jul 21, 2018.
  1. Jul 21, 2018 at 1:59 AM
    Erichudgins
    Erichudgins [OP] New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    Were in Arkansas headed west. Just got gas and truck is sputtering and shaking and engine light is flashing!!! Truck has auto disabled traction control.
  2. Jul 21, 2018 at 3:22 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Sorry for your luck. I'm not sure what's going on but if it happened right after getting gas, it's probably bad gas. I'm not a 100% but just based on that info it's what I would assume it is.
  3. Jul 21, 2018 at 4:43 AM
    Erichudgins
    Eric
    Murfreesboro, TN
    Its gotta be.. I limped it about 100 miles and put 2 bottles of heet in it. Running fine now, cel still on however
    4x4_Angel likes this.
  4. Jul 21, 2018 at 5:01 AM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    If you are still driving try and burn that gas off without getting stranded. Otherwise suck that fuel out yourself and run a tank of the highest grade to help clean out any residual junk. Perhaps you filled up shortly after the fuel truck delivered and the tanks are all stirred up.
    Pop your hood and make sure rodents havent chewed up anything.otherwise call toyota road side and have it picked up.
  5. Jul 21, 2018 at 5:55 AM
    Erichudgins
    Eric
    Murfreesboro, TN
    Ok so update. Limped it to about half a tank.. it was sputtering and shaking and after about a half a tank I added some heet to absorb the water. It's been fine now other than the engine light. Ran it all the way down. Filled up again now so lets see what happens.
  6. Jul 21, 2018 at 5:59 AM
    rvrats2
    rvrats2 Too Often Yankees Overprice This Auto
    Carbondalé, CO
    2011 SR5. Bench Seat!
  7. Jul 21, 2018 at 6:14 AM
    Be sure to keep the receipt. What brand fuel was it?
  8. Jul 21, 2018 at 6:32 AM
    Erichudgins
    Eric
    Murfreesboro, TN
    It was a rinky dink station. It was absolutely pouring down rain.. so I feel like the water may have made it's way into the tanks. Wasnt familiar with the area and wasnt going to make it to another station. My own damn fault. Gonna slide by the toyota dealer here in okc and get diagnostics ran and clear the light. I'm sure it's a misfire of some sort. Still has traction control automatically disabled.
    ColoradoTJ and 4x4_Angel like this.
  9. Jul 21, 2018 at 6:46 AM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    good luck! Does sound like bad fuel like everyone has mentioned. Definitely hit dealer. :fingerscrossed:
  10. Jul 21, 2018 at 6:53 AM
    HighDesertSurfer
    HighDesertSurfer Surf The Dirt
    New Mexico
    2018 SuperWhite DC TRD OR
    Leer shell
    Well, that's always hairy to have happen on a trip!
    Glad you're working that crap gas outta there.:thumbsup:
  11. Jul 21, 2018 at 7:15 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    I read this right as i was about to walk back into work last night! Glad things are better!
  12. Jul 21, 2018 at 7:29 AM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    Well hopefully the codes pulled by toyota dont yield anything crazy and its a matter of resetting and pressing on with your travels. Heet is a good product i like using the lucas oil fuel injector and head lubricant every now and again. Its a carry over from my diesel days and ive also used seafoam with great success. If able it wouldnt hurt to drop that fuel filter out of there and start fresh with new fuel and new filter. Food for thought. Good luck happy :mudding:
  13. Jul 21, 2018 at 7:54 AM
    Erichudgins
    Eric
    Murfreesboro, TN
    Ok so all codes were air fuel related. Cleared and good to go. However the truck auto disabled traction control and will not turn back on
  14. Jul 21, 2018 at 8:45 AM
    LML 3500HD
    Save receipt. Water does some bad stuff to engines (doesn’t compress) and fuel injection systems. Lucky for you this is a gas motor. Diesel, this is a very large bill.
    Stay away from mom and pops gas stations. This is very common with low turn over and not being able to keep up on tank maintenance.
    Sas, Erichudgins[OP] and T-Rex266 like this.
  15. Jul 21, 2018 at 9:21 AM
    Erichudgins
    Eric
    Murfreesboro, TN
    L
    Lesson learned
  16. Jul 21, 2018 at 10:00 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I’d run some premium octane gas through it as well. GL
    Erichudgins[OP] likes this.
  17. Jul 21, 2018 at 2:17 PM
    Erichudgins
    Eric
    Murfreesboro, TN
    91 is only available here in okc... threw that in with a bottle of injector cleaner
