Need help with reverse camera
Discussion in '2nd Gen Tundras (2007-2013)' started by Kidn1980, Nov 22, 2018.
  1. Nov 22, 2018 at 11:02 PM
    Kidn1980
    Kidn1980 [OP] New Member
    Hello new to site, my issue is with reverse camera during the day or when sun is out screen turns white and once I reverse into garage it starts working clear. It works at night time.
  2. Nov 24, 2018 at 7:45 AM
    SCtundra215
    SCtundra215 New Member
    Jmart
    Sc 2nd gen Trd
    Supercharged 5.7L Trd big brakes Trd sway bars Trd exhaust Amp power steps Decked bed box 3.5” lift 35” kumho m/t 20” -44 rockstar blk/machine 811 wheels
    This is odd, I’m wondering on a shady day is it fine? Or is the grounding rod in ur garage providing a better ground to the vehicle? Just a thought cause I had a similar issue with that , I have power steps on my tundra & they’d work until I pulled out of the garage and then they’d just make a Humm outside of it
  3. Nov 26, 2018 at 1:22 PM
    Kidn1980
    Thank you for responding
    Yes on a shady day it works fine or even at night.
  4. Nov 26, 2018 at 2:53 PM
    SCtundra215
    Jmart
    Sc 2nd gen Trd
    Is it aftermarket or oem?
  5. Nov 26, 2018 at 2:54 PM
    Kidn1980
  6. Nov 26, 2018 at 4:26 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    You can adjust brightness and contrast under display settings
  7. Nov 26, 2018 at 8:52 PM
    SCtundra215
    Jmart
    Sc 2nd gen Trd
    That’s what I was thinking too, but I removed my jbl so I couldn’t refer to it to look for that. So went to the fourms to look cause I’m interested in what would cause that
  8. Dec 5, 2018 at 8:37 AM
    Kidn1980
    Didn’t know you could adjust the camera. Like on a sunny day camera just turns white when reversing into the garage once camera is in garage BOOM works awesome
  9. Mar 11, 2019 at 9:51 AM
    LeePC
    LeePC New Member
    2007 Blue Streak Metallic Double Cab 5.7L Tundra Limited
    Could be the iris on the camera is not closing and the whited out display is excessive light.
  10. Mar 11, 2019 at 10:09 AM
    15whtrd
    15whtrd Mr. Blonde
    How about with your headlights on during the day? Does that change anything?
  11. Mar 11, 2019 at 2:23 PM
    Kidn1980
    What exactly is the iris
  12. Mar 11, 2019 at 2:23 PM
    Kidn1980
    No
    15whtrd[QUOTED] likes this.
  13. Mar 13, 2019 at 3:09 PM
    LeePC
    LeePC New Member
    It controls the amount of light the camera needs to create the image. It opens and closes as needed, but it should be an automatic operation, the camera may be defective. If the camera connection is easy to get to and you have access to a camera, you can temporarily connect it, see if it helps.
  14. Mar 14, 2019 at 1:05 PM
    minter66
    minter66 2007 TSS CrewMax
    Like LeePC is stating, looks like you might have a defective OEM Camera. Seems to be stuck in night mode only.
