Need help trying to figure this out
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Siracruz, Apr 29, 2023.
  1. Apr 29, 2023 at 1:09 PM
    Siracruz
    Siracruz [OP] New Member
    Sira
    2015 tundra trd
    All these lights turned on and I can’t figure out why it’s doing it
  2. Apr 29, 2023 at 2:21 PM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Probably the battery getting low .
    Siracruz[OP] and biebs96 like this.
  3. Apr 29, 2023 at 2:29 PM
    Siracruz
    Sira
    2015 tundra trd
    Also my shifter is locked , and the speedometer isn’t working
  4. Apr 29, 2023 at 2:32 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Magnuson Magnum TVS 2650 S/C Sniv's Speed Shop 70mm pulley RCF Throttle Body TRD PRO BBS Wheels TRD Front Sway Bar TRD Rear Sway Bar Fox TRD Pro Shocks Limited mirrors (auto darkening/backup camera/power fold/puddle lights) Limited Grill Mod Automatic Climate Controls Mod Automatic Headlamp Mod Sequoia Transfer Case Mod Sequoia Leather Steering Wheel Mod Sequoia Limited Gage Cluster Mod Sequoia LED Headlamp Upgrade Window Tint 15/70% Fake Manual Transmission Mod 10" BAMufflers Stainless Catback Valhalla Catalytic Converter Shields Engine Block Heater Illuminated Ignition Key Ring Mod Deck Rail System w/cleats Solid Offroad Engine Mounts
    You're going to need to get the codes read to narrow it down, otherwise literally every guess becomes a probability.
    Your engine appears to not be running. That would explain why there's no oil pressure, the low voltage, why your battery light is on, why the tachometer isn't working. There are some dash lights that come on when you rotate the key to the RUN position to test that they're working.
  5. Apr 29, 2023 at 4:04 PM
    How old is the battery? If it's older than 2.5 to 3 years, replace it. Some cars will not shift out of park if the battery is shot.
