Need Bay Area installer for tail gate lock
Discussion in '2.5 Gen Tundras (2014-2021)' started by Shadowfax1, Apr 15, 2022.
  1. Apr 15, 2022 at 4:10 PM
    Shadowfax1
    Shadowfax1 [OP] New Member
    California
    2018 Toyota Tundra 1794 Edition w/ TRD Off-Road Package
    I bought the OEM electronic tail gate lock kit from BAM Wholesale—best price I could find at the time, $127.93.
    I don’t have the time to learn to do the install myself right now. But my local dealer (Toyota Dublin CA) wants freaking $220 per hour to do it. Their standard hourly rate for any service whether mechanical or accessory install. That’s so far beyond a non-starter…
    Need recommendations for other local places I can take it. Anywhere between Marin and Santa Cruz, or out to Tracy.
    Would prefer a licensed shop of some kind, unless you have an alternative recommendation I can be convinced won’t be a disaster that would ruin my truck or void my warranty. :)
  2. Apr 15, 2022 at 5:37 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    A teenager armed with YouTube should have it done in around :45.
    clarkritchie, Joe333x and Saltyhero13 like this.
  3. Apr 15, 2022 at 5:43 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    The OEM is plug and play. The hardest part is fishing the wires into the cab through the trucks belly. I was able to do the install while recovering from a serious debilitating condition.
  4. Apr 15, 2022 at 6:00 PM
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    I did mine in 45 minutes, plug and play.not rocket science and there are tons of YouTube videos on it. Sometimes your truck is in better hands if you do it yourself.
    panicman and Saltyhero13 like this.
  5. Apr 15, 2022 at 8:12 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Super easy install, legit plug and play. Zip tie the wires and you're done. The oem instructions are very straightforward and you don't even need to remove the heat shield like it says you do.
  6. Apr 15, 2022 at 8:20 PM
    Shadowfax1
    California
    Why not? If it says to, why should I not do it / why isn’t it required?
  7. Apr 15, 2022 at 8:23 PM
    InfernoPRO
    InfernoPRO Technicolor BASTRD
    Scott
    Sacramento
    2015 Inferno TRD PRO
    sr5shark and 831Tun like this.
  8. Apr 15, 2022 at 8:25 PM
    Joe333x
    Joe333x Member
    Boston
    it says to remove the heat shield while running the wires so you don't cut yourself but if you wear gloves or just very careful it's not necessary and will make the job much easier.
    STR1 likes this.
  9. Apr 18, 2022 at 11:46 AM
    vtr996
    vtr996 New Member
    Super easy install. I didn't remove the heat shield either.
  10. Apr 18, 2022 at 11:55 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I installed a universal kit, not PnP, and it took me a couple hours.
    You're entirely better off doing it yourself.
