Need a second set of eyes, my rear is too high
Discussion in 'Suspension' started by CyberViking, Apr 12, 2019.
  1. Apr 12, 2019 at 5:15 PM
    CyberViking
    CyberViking [OP] New Member
    The Ozarks
    2018 MGM Tundra TRD Sport
    I installed a 2.5" Eibach kit from Toytec and some shakles set at 1.5". I put on some 295/70r18 tires and had to do a slight BMC to clear. The extreme rake has been bugging me so today I lowered the shakles to the 1" setting. I measured from center hub and I had 24" in the front and 27" in the rear. Now I'm at 24" front and 26.5" in the rear.
    ***UPDATE***
    Toytec is not willing to work with me. Something is obviously wrong...not even close to 2.5".
    Buyer beware.
    ***Final Update***
    Toytec admitted that Eibach tested the coilovers on a 2WD Tundra and that they were in emergency mode to produce a spring for a 4WD truck. Toytec was difficult to deal with but I eventually got a refund and went with a different setup from a different vendor.
    Others mentioned in a previous thread that maybe my coilovers are really only 2". Even then should it be 2.5" off?
    What do you think? I took the picture on as level ground as I could find. And no the business isn't open so I'm not blocking handicap :)
    And here's a picture of the coil-over. My springs are resting .5" below the lowest C-clip (should be 2.5" of lift".)
    Another angle of the coil-over...(lowest ring)
    Kerktam likes this.
  2. Apr 12, 2019 at 5:22 PM
    Professional Hand Model
    Hand Protectors
    Looks good to me. I like a little forward rake. Keep it like it is.
    BlackSheep, Toyokuhl, OR18TRD and 3 others like this.
  3. Apr 12, 2019 at 5:25 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    +1
    OR18TRD and CyberViking[OP] like this.
  4. Apr 12, 2019 at 6:01 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Looks more like 2in up front....been hearing complaints on that eibach kit it’s the wrong spring rate so your not getting the amount of lift advertised I could be wrong tho. Did you take before and after measurements?
    I think it looks good with the rear higher honestly...our stock leaf packs are so soft anything in the bed puts it nose high.
    24” from center hub to fender it is about 2” of lift
    15whtrd and CyberViking[OP] like this.
  5. Apr 12, 2019 at 6:05 PM
    xtyfighterx
    Ty
    North Idaho
    Here’s my old setup 2.5 up front 1in rear with 295s
  6. Apr 12, 2019 at 6:35 PM
    CyberViking
    The Ozarks
    That looks pretty close...
    xtyfighterx[QUOTED] likes this.
  7. Apr 12, 2019 at 6:37 PM
    CyberViking
    The Ozarks
    I didn't take measurements unfortunately. I may just end up adding shims when I get bored. I like rake too but 2.5" is a bit much! Or pay a shop to move the clip up on the Eibach but I'd still need shims anyway.
    Boerseun likes this.
  8. Apr 12, 2019 at 6:59 PM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    Although I like a little rake, I think in that pic the rear looks a tad high. And it’s bothering you enough so that you keep looking at it and posting here about it. I don’t believe thats the proper 2.5” in the front. I have 1.75” in front and yours doesn’t look much higher, if any. I added 1” in the back for a little rake with the 1.75”, so something is off on yours. To me, the back looks higher than 1”.
    CyberViking[OP] likes this.
  9. Apr 12, 2019 at 8:47 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Looks good in the picture.
  10. Apr 12, 2019 at 9:04 PM
    bandit
    bandit New Member
    2011 Supercharged Mazzulla Long Travel Rock Warrior
    Duh Tundra
    +1 looks solid as it sits. Unless you were hoping for the bulldog look.
  11. Apr 12, 2019 at 9:05 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Our trucks need 700lb springs. Every manufacturer is selling coilovers with 600lb springs and no one is getting the lift they’re saying you will get.
    LiftMeUp and xtyfighterx like this.
  12. Apr 12, 2019 at 9:21 PM
    charliebison
    charliebison New Member
    +1 Spot on! I dealt with this recently. 700s are perfct.
  13. Apr 12, 2019 at 9:24 PM
    Aerindel
    Aerindel New Member
    Montana
    The rear is supposed to be high. It's a truck.
  14. Apr 12, 2019 at 10:40 PM
    xtyfighterx
    Ty
    North Idaho
    700lb springs are what the trucks need for sure that’s what I have with my fox 2.5s no complaints plenty of lift currently at 3.5”....get shims and you will level out better
    monaco730 likes this.
  15. Apr 13, 2019 at 1:20 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Daddy like it just the way it is. :thumbsup:
    CyberViking[OP] and Black Wolf like this.
  16. Apr 13, 2019 at 2:41 AM
    rsgt
    rsgt New Member
    2019 crew cab TRD sport 4x4
    all stock
    I even put my glasses on but it looks like the same stance as my stock TRD sport 4x4.
    Paul B and Black Wolf like this.
  17. Apr 13, 2019 at 5:03 AM
    ktharbour6
    ktharbour6 New Member
    2016 Toyota Tundra TRD Pro MGM
    I think its to much rake, personally. If you don't care for it you could always order 1 set of shims from coachbuilder which would add .5" to the front.
    Hammy68 and rons23 like this.
  18. Apr 13, 2019 at 5:12 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    This^^^^^^^^^:thumbsup:
    Hammy68 likes this.
  19. Apr 13, 2019 at 5:15 AM
    Creatures 1982
    Creatures 1982 New Member
    2017 SR5
    Too much rake tofor me I like them level. But just my 2 cents
    You old set up looked better
    LiftMeUp, Hammy68 and Rex Kramer like this.
  20. Apr 13, 2019 at 5:37 AM
    Looks good. Last thing I want is my trucks' ass dragging on the ground every time I load it up or tow. If you never haul anything but groceries then level it out.
    Hammy68 and Filthy13 like this.
  21. Apr 13, 2019 at 6:15 AM
    Izzy
    Izzy New Member
    Looks like you went out of your way to park in the handicap spots. Douchebag.
  22. Apr 13, 2019 at 6:16 AM
    Hand Protectors
    Easy peezey.
    Tundyfundy and Black Wolf like this.
  23. Apr 13, 2019 at 6:30 AM
    justfortun
    justfortun New Member
    James
    Boston
    2016 SR5
    I think we have a jealous Ford owner. Go troll elsewhere, your game sucks.
  24. Apr 13, 2019 at 6:41 AM
    Got close to 2.7" with my OME 2.5" coilovers and that's with winch/ winch bumper hanging out front. ARB/OME coils are top notch. ToyTec matched my coilovers just right with the 614 coil.
  25. Apr 13, 2019 at 6:54 AM
    TXDrifter
    TXDrifter BlueGrass Crew
    Jeff
    Louisville, KY
    2017 Tundra MGM DC
    I thought the lowest ring is 1.9"...And top is 2.5ish.. Looks like your on the lowest setting so that stance is correct for the setting..:confused:
    Black Wolf likes this.
  26. Apr 13, 2019 at 8:27 AM
    Ycitytundra
    Ycitytundra New Member
    Gary
    Red 2008 sr5
    It’s a Tundra already the best looking truck on the road
  27. Apr 13, 2019 at 8:37 AM
    Migstoy
    Migstoy New Member
    Utah
    2008 Tundra Crewmax Limited 4X4
    Firestone Airbags Gibson MWA Exhaust Running on 35's
    Izzy, probably one of those fatass people that aren't really disabled but just can't make it out of the parking lot without stopping to have a breather.
    Tundyfundy likes this.
  28. Apr 13, 2019 at 8:42 AM
    Rockanock
    Rockanock 21 Chevy 2500
    I think it looks good but....... I’d want my nose to be level with the rear if I spent the money you did to get it to where it is.
  29. Apr 13, 2019 at 9:08 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Here’s a pic for comparison. This was when I had my Toytec Boss 3/1.5 with same size tires as you.
    justfortun and Darkness like this.
  30. Apr 13, 2019 at 10:39 AM
    CyberViking
    The Ozarks
    The difference is 2.5" currently. Supposedly 2.5" Eibach Coilovers in the front and a Toytec shackle set at 1" (middle hole).
    A stock rake is 2.5", leveling kits are sold as 2.5". If we remove my rear 1" lift that leaves 1.5" of difference. Meaning my front "2.5" Eibach Coilovers got me only 1" of lift. They likely put them together wrong. 1.5" is too much to be off..I could see .5" but not 1.5".
    I've already contacted Toytec so hopefully they have good customer service. They forgot to ship me my rear shocks entirely when I ordered them along with the coilovers. I had to call and ask where they were.
    I'm okay with rake, and it does look ok but I'm not getting what I paid for. There should be 1-1.5" rake. Not 2.5".
