NC's 2018 CM build
Discussion in '2.5 Gen Tundras (2014-2021)' started by NCinCO, Feb 12, 2018.
  1. Feb 12, 2018 at 6:39 PM
    NCinCO
    NCinCO [OP] Is it Friday yet?
    Gary
    Thornton, CO
    2018 Smoked Mesquite Limited CM TRD
    Hey gang. I'm looking for build ideas for a 2018 CM. It will be my DD when I sell my lil '07 Cobalt to help pay for some of the goodies. Here is what I'm looking at now, the TTHA-TUN lift with a 1-1.5 block (was told to use the block if I wanted duals which is on the want list also), SPC UCA's, Spidertrax spacers, more aggressive tires and not sure about the size (I want Nitto Ridge Grapplers but DANG they are pricey), rims (I'll run stock for awhile), and probably a Bambi buster later.
    What do you guys think between a SC or chip/tuner? I know the SC would be out of this world awesome but the price tag will be too.
    I'm trying to convince the wife we desperately need all the mods (or at least some) this year. It's work in progress! Lol
  2. Feb 13, 2018 at 9:00 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Isn’t that the Toytec/Eibach kit? I went with shackles on my Toytec/Radflo lift and am pretty close to the exhaust at full droop, so that makes sense going with a block.
    As far as tires go, I’m a big fan of my Ridge Grapplers. They’re only slightly louder than the BFG Rough Terrain AT’s I had before, which for an aggressive tread is pretty good. With the 3/1 you’re planning on running, I’d go with 295/70-18’s. I got mine through a local dealer for $297 a tire with free mounting and balancing.
    Eclipsed & Floating likes this.
  3. Feb 13, 2018 at 8:04 PM
    NCinCO
    Gary
    Thornton, CO
    Yes it is the Toytec/Eibach kit. For the price it seems pretty good. I was looking at the Bilstein 5100 set up. Kinda torn between the two. Do you know if the ride is any different between the shackles and blocks?
    That size tire seems to be very popular. I'll have to keep looking out for prices to fall a bit. The cheapest I've found is around 320.
  4. Feb 13, 2018 at 8:19 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Unfortunately I haven’t heard anything on that kit. But knowing the boys at ToyTec, they don’t put out a product of inferior quality. As a general rule, I’d go with ToyTec, but definitely do your homework. Unless you’re beating on the suspension off road I don’t think a block is a problem. I went with the shackle because I plan on off roading mine. Do some shopping around on the tires, you can find a better price.
  5. Feb 13, 2018 at 8:35 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    the toytec kit should be better than the 5100's. the 5100's doesn't come with springs and you have to use your original top hats so that will add cost to the install. you have a solid lift for the price. looks like you did your homework! but it now! Don't forget to get the forum discount from toytec.
  6. Feb 13, 2018 at 8:58 PM
    A-A-Ron
    A-A-Ron Done messed up
    Aaron
    Seattle
    2021 GMC 2500 AT4 Gasser
    I have the Toytec/Eibach kit, great value without a reduction of ride quality like the 5100’s can have. Easier install since they come as an assembled unit. Neither are for aggressive off road use.
    NCinCO[OP] likes this.
  7. Feb 14, 2018 at 5:31 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I don't quite get it. You buy a new Tundra for a daily driver on want to "build" it on a budget? You must have a pretty big budget since you want to add a lift and bigger wheels and tires and are also considering a super charger (no SC tunes available yet as far as I know) or maybe a tuner (again none available yet for the 2018s except maybe DAP).
    Anyway if you are used to driving a Chevy Cobalt as a DD you will be in for a rude awakening as far as MPGs are concerned after you lift your truck and put bigger tires on. Just something to consider besides the obvious warranty concerns with your proposed changes.
  8. Feb 14, 2018 at 8:32 AM
    NCinCO
    Gary
    Thornton, CO
    I drive the Cobalt every now and then. This is my 3rd tundra but the first one I'm doing mods to. I guess the budget would be quality equipment at the cheaper price end. If I don't have to dip into the savings and stay out of the dog house, I consider that a budget.
    Eclipsed & Floating and 71_340 like this.
  9. Feb 14, 2018 at 11:32 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Staying out of the doghouse is not always easy when you buy unnecessary (wife's point of view) parts for your truck. I know all about that "having" to buy parts for the Tundra and my Chevelle. I am good for a little while though because last fall I forked out 12k for bathroom upgrades my wife thought were necessary.
  10. Feb 14, 2018 at 11:38 AM
    Magnuson S/C offers financing I believe
  11. Feb 14, 2018 at 5:10 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    But do they make one for the 2018. And then there is the big warranty concern.
  12. Feb 14, 2018 at 8:21 PM
    NCinCO
    Gary
    Thornton, CO
    Great question. I'm going to have to research and find out.
  13. Feb 14, 2018 at 8:31 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Super chargers are supposed to be fun but aske @Sean266 about reliability
    T-Rex266 likes this.
  14. Feb 15, 2018 at 5:04 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I bet they are fun and definitely the best bang for the buck. I know 7k sounds like a lot of money but I sunk more then that into my Chevelle over the past year. Like I said my concern would be the warranty on my new truck, not only the engine but the whole drivetrain. I wish Toyota still sell and install the SC, a co-worker of mine bought a new Tacoma in 2002 and had the SC installed at that time, he has over 230K miles and never had an issue, he also maintains his truck meticulously, it still looks near new.
    I would be willing to spent 7K if my warranty is unaffected!
  15. Feb 15, 2018 at 11:34 AM
    NCinCO
    Gary
    Thornton, CO
    What's your input @Sean266
    It looks as if the Bully Dog or DAP tuner is a good option also. Thoughts?
  16. Feb 15, 2018 at 1:19 PM
    Personally, I’m not going with either. I’m not risking a $47k truck for some tuning. If I wanted a hot rod, I would own one. That’s just my .02. Different strokes for different folks.
  17. Feb 15, 2018 at 7:04 PM
    NCinCO
    Gary
    Thornton, CO
    I'm not looking for a hot rod by no means. I've got my 2.2L Cobalt for that (lil Ferrari). I'm just looking for something to help it so it won't downshift on a small incline. I friend of my suggested a SC. I am skittish about certain mods like this since it would void parts of the warranty.
  18. Feb 15, 2018 at 7:32 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I checked the Magnusson site today and they will give you a 36K drivetrain warranty, it starts from when the truck was new and will cover up to 12.5K. To get the warranty the SC has to be installed by a licensed mechanic. I contacted them and they are currently working on the software for the included BD GT tuner but do not have a release target date yet.
    As of now the only option to get a little more power and improved drivability is the DAP tune. I read numerous posts/reviews about DAP and most everybody is pleased with it.
  19. Feb 15, 2018 at 9:12 PM
    NCinCO
    Gary
    Thornton, CO
    That is some awesome researching you did. I've been seeing a few good threads about DAP. I'll look into it asap. In the meantime...back to work:annoyed:
  20. Mar 16, 2018 at 8:31 PM
    NCinCO
    Gary
    Thornton, CO
    First 2 quicky mods. Console tray and screen off display. Change it to IMG_20180316_140427.jpg
    Something I've been looking at is dipping all the badges. Any suggestions on color or the best product? The main pro is it looks freakin sweet. Are there any cons that you guys ran across?
    The build list is getting longer by each post....and :spending::spending::spending:
  21. Mar 16, 2018 at 9:05 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    For some extra HP contact Keith @dirtydeeds. He can get you some good power with headers, exhaust, tuner...
  22. Apr 26, 2018 at 1:01 AM
    NCinCO
    Gary
    Thornton, CO
    Has anyone heard of Maxtrac lift kit?
  23. Apr 26, 2018 at 3:39 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    You probably will never notice a difference with a canned tuner that gives you maybe 20-25 more hp,and you have to run 91 or more octane and void the factory warranty.Not worth it IMO. At $7 grand or more a supercharger is a serious commitment.You gotta REALLY want one and it sounds like you will have to do some serious sweet-talking (ass kissing) with the wife to get one. Anyhow,keep us posted with your build. BTW...I hope you get the SC!!!
  24. May 1, 2018 at 7:06 PM
    NCinCO
    Gary
    Thornton, CO
    Let the fun begin!!! One of many steps taken today as I bought the Toytec Boss kit w/SPC UCA's. My hats off to Carsen @Toytec Lifts for his patience and going over several different options with me. Now to find time to do the install and get tires.
    Toytec Lifts likes this.
  25. May 27, 2018 at 7:08 AM
    NCinCO
    Gary
    Thornton, CO
    Toytec Boss kit Finally installed but I need to do some final adjustments. Getting wheels, tires, and an alignment this week. Thinking about Fuel Vapors w/BFGs' Duratracs, or Nitto Terras. The waiting is the hardest part!
    roots likes this.
  26. May 27, 2018 at 11:59 AM
    roots
    roots New Member
    Looks good. I really like that colour but in Canada it's only available in the 1794 package. I've used all three of the tires you're considering and I like the BFG and Duratracs more than the Nitto. I found the duratracs were the best of the three for winter performance and the BFG were the quietest.
  27. May 27, 2018 at 4:55 PM
    NCinCO
    Gary
    Thornton, CO
    It's strange that it's not available in the limited up there. Wonder if it can be ordered and them ship one from the states?
    Thanks for the awesome info roots. The Nitto's have a better price but I'm leaning towards the BFGs or Duratracs. Just wondering which ones would be better for mild-medium offroad trails?
  28. May 28, 2018 at 8:25 AM
    roots
    roots New Member
    Yeah the Nitto's are usually the best price. They're actually what I have right now and they're not a bad tire at all, I just liked the BFGs I had previous more. I also run a 2nd set of tires/rims in the winter. I think you'll be happy with any of the choices. I remember I went down your way in 2009 to the Ouray area for some offroading (I had duratracs at the time) but all those tires were out on the trails and were doing good.
    NCinCO[QUOTED][OP] likes this.
  29. May 28, 2018 at 2:14 PM
    NCinCO
    Gary
    Thornton, CO
    Spot on. I think it will come.down to what package deal they give me with the fuel wheels.
