Nanosparkle cloth
Discussion in 'Detailing' started by Nbab23, Feb 24, 2023.
  1. Feb 24, 2023 at 6:55 AM
    Nbab23
    Nbab23 [OP] 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    Anyone ever hear of or use this product? NanoSparkle Cloth (buynanosparkle.com) My son took a magnetic wand to the door of my truck and left some nice scratches on it. I'm thinking this is snake oil, but figured I would see what others thought.
  2. Feb 24, 2023 at 8:36 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Read the reviews on Amazon. Even if the cloth had two sides of different grit level it would be impossible to do what it claims to do.
    Nbab23[OP] likes this.
  3. Feb 24, 2023 at 8:48 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Post some pictures of the scratches. Probably can get away with a polishing to remove the scratches.
  4. Feb 27, 2023 at 6:24 AM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    Not great photos since the truck needs a bath, I can feel the scratches a bit with my nails, I’m good mechanically but little to no experience when it comes to body work and handling scratches.
  5. Feb 27, 2023 at 6:31 AM
    Danimal86
    Daniel
    Sacramento, CA
    Ouch! Dont think that a polishing would take those scratches out.
    I would go get some matching paint and a syringe and try filling it in.
  6. Feb 27, 2023 at 6:53 AM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    Yeah I wasn’t too happy about it. I have a paint match touch up pen although they are probably a little too narrow to use that. I’ll give your route a go once the weather warms up a bit. Thanks.
  7. Feb 27, 2023 at 7:18 AM
    Danimal86
    Daniel
    Sacramento, CA
    I've seen videos of people using things like this to fill in chips, but not sure how it would work on a car door
    https://www.amazon.com/Gold-Label-D...id=1677511056&sr=8-3-spons&smid=ALRPFGEN62HZC
  8. Feb 27, 2023 at 7:58 AM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    I found this video in researching and the guy goes through the best tools depending upon where the scratches or chips are. Its about the 5-1/2 minute mark where he talks about the ones he uses and the one you linked to is in there as well. https://www.youtube.com/watch?v=WLJnqiBxKtg&t=792s
  9. Feb 27, 2023 at 8:39 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    If you're not into polishing yourself, I'd take your truck to a detailer and ask him to take a look. It's quite possible that either a polishing or light wet sanding could make it barely noticeable. I'd stay far away from trying to fix a long scratch with touchup paint.
    Nbab23[OP] and Saltyhero13 like this.
  10. Feb 27, 2023 at 8:40 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    You might try washing the area first and dry thoroughly. Then fill in the scratches with a touch-up applicator followed by scraping the surface of the scratch with something firm, but non-metallic, like a playing card. The card will remove the paint that didn't fill in the scratch. Wipe the card edge clean from the paint it removed and repeat on the other scratches. I've had pretty good results doing this. Hope this helps.
  11. Feb 27, 2023 at 10:47 AM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    I tried polishing it myself once a few years back and it turned out beautiful until it hit the light just right and all I could see were holograms....that's when I decided exterior detail work other than washing and waxing is not for me. After that I took it to a detailer and they corrected it for me. I may go back there and see what they say. I just don't want them to do a paint correction because isn't that just removing some of the clear coat? Obviously I want the scratches to not look so obvious, but the big thing for me is just avoiding oxidation down the road as I would like to keep this truck as long as possible.
    sask3m[QUOTED] likes this.
  12. Feb 28, 2023 at 7:34 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Any decent detailer should have a paint depth meter and be able to tell just how much clear is left and what can be done.
  13. Mar 5, 2023 at 2:44 PM
    Danimal86
    Daniel
    Sacramento, CA
  14. Mar 5, 2023 at 2:50 PM
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    I agree, looks like clear coat scratches. This is very common with dark colors, especially black. The fine scratches will show up white, some times a little chalky - it’s the clear coat against a dark color. I bet a good detailer can fix that.
