Nanny warnings with front parking sensors
Discussion in '3rd Gen Tundras (2022+)' started by WesternMassOutdoors, Feb 23, 2023.
  1. Feb 23, 2023 at 4:27 AM
    WesternMassOutdoors
    WesternMassOutdoors [OP] New Member
    Massachusetts
    2023 iForce MAX Platinum
    First time I drove my 2023 platinum in the snow last night and I finally have my first Forum-worthy nit.
    The parking sensors in the grill are in a a slight depression and the pocket fills with slush as your driving.
    Eventually your dash lights up with parking sensor obstruction warnings that ding and flash all over the place. I have no idea how to tell them to shut up so I can focus on the icy road but I ain't stopping and getting out every mile to wipe slush out.
    Any thoughts on how to solve this design flaw?
    There should be a STFU and let me drive setting on things like this.
    OnThaLake, wing-2, dekeman and 2 others like this.
  2. Feb 23, 2023 at 4:44 AM
    Taikowaza
    Taikowaza New Member
    I have enjoyed turning off a number of nanny warnings using Carista. You can make changes to the artificial engine noise, adjust seatbelt and parking chirps, door warnings etc. I changed the number of turn signal blinks per short press, etc.
    Here is a partial list of customizations showing on their website, there are others I’ve found on the app. I used the free trial to make some adjustments. I paid for another month to play with it some more, will cancel as I’m happy with the setup now. Once you have the hardware you can always pay for another month of access if you want to tweak further.
    Dings & Warnings
    Seat belt warning ding (driver)
    Enabled / Disabled
    Seat belt warning ding (front passenger)
    Enabled / Disabled
    Ding when headlights are left on
    Yes / No
    Key-in-ignition ding sound
    Slow / Medium / Fast
    Driver Assist
    Pre-Collision System (PCS) sensitivity: remember last state
    Enabled / Disabled
    Default distance for Pre-Collision System (PCS) alarm when the PCS switch is turned off and back on
    Far / Remember last distance
    Default distance for Pre-Collision System (PCS) alarm when the ignition is turned on with the PCS switch off
    Default distance for Pre-Collision System (PCS) alarm when the ignition is turned on with the PCS switch on
    Heater & A/C
    Open vents to outside air when ignition is turned off
    Yes / No
    Instruments: Displays & Nav
    Instrument lights dimming sensitivity
    Darkest / Darker / Normal / Lighter / Lightest
    Instrument lights restoring sensitivity
    Display odometer after ignition is turned off for…
    30 seconds / 1 minute / 10 minutes / Off
    Microphone sensitivity
    1 - 11
    Lights: Automatic
    Auto headlights activation threshold
    Lights: Exterior
    Daytime running lights
    On / Off
    Lane-change turn signal auto-flasher count
    Off / 3 flashes / 4 flashes / 5 flashes / 6 flashes / 7 flashes
    Coming-home lights duration
    Off / 30 seconds / 60 seconds / 90 seconds
    Lights: Interior
    Interior light control
    Enabled / Disabled
    Turn on interior lights when you shut off engine
    Yes / No
    Turn on interior lights when you unlock doors
    Yes / No
    Turn on interior lights when smart key in range
    Yes / No
    Dim interior lights after…
    7 seconds / 15 seconds / 30 seconds
    Locking: Automatic
    Wireless door locking
    Enabled / Disabled
    Auto-lock all doors
    Disabled / When shifting into gear / When vehicle starts moving
    Auto-unlock all doors
    Disabled / When shifting into park (P) / When driver's door is opened
    Re-lock doors automatically if you unlock, but don't open a door
    Yes / No
    Re-lock doors automatically if you unlock, but don't open a door within…
    30 seconds / 60 seconds / 120 seconds
    Locking: Beep & Blink
    Beep when locking/unlocking with remote
    Yes / No
    Volume of beep when locking/unlocking with remote
    Off / 1 / 2 / 3 / 4 / 5 / 6 / Max
    Blink turn signals when locking/unlocking with remote
    Yes / No
    Locking: Doors & Alarm
    Unlock doors via remote
    Driver's door on 1st press, all on 2nd / All doors on 1st press
    Unlock doors via physical key
    Allow locking when a door is still open
    On / Off
    Warn (beep) when door can't be locked because it's still open
    Yes / No
    Windows & Sunroof
    Open windows and sunroof by turning and holding key in door lock
    On / Off
    Close windows and sunroof by turning and holding key in door lock
    On / Off
    Other
    Panic function on remote
    Enabled / Disabled
    Sixty9Four20, gimili and Henry1jg like this.
  3. Feb 23, 2023 at 5:09 AM
    WesternMassOutdoors
    Massachusetts
    Do you know when they will support 3rd Gen with that? Looks like its only compatible with gen2 Tundras
  4. Feb 23, 2023 at 5:36 AM
    nodak67
    nodak67 New Member
    JR
    some of those settings are done via the main center stack console and not regulated to techstream or carista only.
    Chugbug likes this.
  5. Feb 23, 2023 at 5:57 AM
    BillorJackorPeteorDennis
    BillorJackorPeteorDennis New Member
    Washington, DC
    ‘25 TRD Pro - Mudbath
    It doesn't list as being compatible with 3rd Gen but it definitely works as I have used it many times on my 2022 Tundra. I was skeptical at first as well, but it was seamless.
  6. Feb 23, 2023 at 6:02 AM
    nodak67
    nodak67 New Member
    JR
    most of those are standard configs for all newer gen tss v3 cars. so the options are common across all models in the ecu.
    heck some of those options are even in my old 2018 tundra and my 2014 4runner.
  7. Feb 23, 2023 at 6:04 AM
    18" TRD Off Road Wheels
    You should have a button on your dash/center console to turn off parking sensors. Super easy.
  8. Feb 23, 2023 at 7:01 AM
    WesternMassOutdoors
    Massachusetts
    Yeah apparently even if you turn it off it's unhappy that the sensor is blocked...
    DFS likes this.
  9. Feb 23, 2023 at 7:39 AM
    That might be your radar sensor behind the Toyota emblem in your grill. The parking sensors are a separate system.
  10. Feb 23, 2023 at 7:42 AM
    nobaddays
    nobaddays New Member
    Tyler
    2023 Black Tundra TRD Pro
    Full front PPF, Tint, Go Rhino boards, Retrax, 35's, Rekgen Flaps
    Carista works fine for the 3rd Gen. Used it on mine and worked great. I get the same warnings when its covered in snow, have not found a way to keep it from popping back up. Extremely annoying.
  11. Feb 23, 2023 at 7:48 AM
    nodak67
    nodak67 New Member
    JR
    the parking sensors have only a few functions from what i know, proxmity to objects while parking, people collision, bsm while driving. so you have to turn off a few functions for it to not beep.
  12. Feb 23, 2023 at 7:50 AM
    They do not do BSM. Those are separate and larger sensors located inside the bumpers. The parking sonar is only for proximity at short range.
    nodak67[QUOTED] likes this.
  13. Feb 23, 2023 at 7:53 AM
    nodak67
    nodak67 New Member
    JR
    yep you are right forgot about those big squares in the bumper corners.
  14. Feb 23, 2023 at 8:34 AM
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    Yep. Turn off LTA and lane-centering completely, all the time. Turn off adaptive cruise control every time I turn on cruise control, and turn off collision braking assist or whatever it's called whenever I get the sensor warning.
    mikvic likes this.
  15. Feb 23, 2023 at 8:48 AM
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    First off...I think you'll find what is "forum-worthy" to be very subjective. :rofl: Feel free to post whatever you want. :thumbsup:
    Regarding the sensors:
    TSS Radar (Circled in Red): The sensor complaining about snow build up while driving is the TSS Radar circled in red. If snow builds up on that, you will start to get dash warnings saying PCS (Pre-Collision System) and ACC (Adaptive Cruise Control) are unavailable. I believe it also says "clear sensor of debris" or something like that. This is pretty common while driving in snow. Happens to me all the time when I drive through snow.
    Parking Sensors (Underlined in Blue): The parking sensors are only actively "pinging" when driving under a certain MPH. Somewhere below 10 mph, I believe. At highway speeds, they are not actively sensing and essentially turn off.
    LTA & RSA (Circled in Yellow): The LTA (Lane Tracing Assistance) and the RSA (Road Sign Assist) camera is up at the top of the windshield. This can also get blocked by heavy snow, but your wipers cover this area during their swing. So it really shouldn't get blocked unless there is ice build up while driving. The heater has a hard time defrosting this area in bitter cold.
  16. Feb 23, 2023 at 11:43 AM
    WesternMassOutdoors
    Massachusetts
    Interesting -- I can confirm the warning was for parking sensor which I thought and you confirmed are the the blue circled sensor built in to the mile-wide grill.
    I was getting the warning even at "max" snow driving speed of 35mph....
    In general I think it may be specific to wet slushy snow - the sleet this morning didn't cause any problems when I let the wife borrow the truck to get to work.
    Sounds like in general its edge case.
  17. Feb 23, 2023 at 1:22 PM
    porterbc
    porterbc New Member
    Brandon
    2022 Tundra Crewmax Limited TRD OFF-ROAD
    I put the plow on front of my 2022 and shut every sensor off and still slams on the brakes and cuts power as I’m pulling away…
    about ready to unplug the radar sensor see it makes it useable, otherwise I can’t leave the driveway with this foolishness..
  18. Mar 5, 2023 at 7:24 PM
    bccs22
    bccs22 New Member
    2023 Black Tundra Limited LB
    Anyone know what microphone this is in the Carista settings? I assume for the navigation assistance, but is there no way to turn it off entirely, instead of adjusting sensitivity? Thanks in advance for any insight.
  19. Mar 6, 2023 at 8:25 AM
    nodak67
    nodak67 New Member
    JR
    its for voice commands/phone calls to the head unit. look above your head and to the left a little and you will set some vents?
  20. Mar 7, 2023 at 5:32 AM
    mikvic
    mikvic New Member
    Anyone in NE Wisconsin have the Carisata?
  21. Mar 7, 2023 at 6:12 AM
    articdesert
    articdesert Will work for truck parts
    23 1794 MGM
    I have Carista and am in south ms if anyone wanna use it
  22. Mar 7, 2023 at 10:07 AM
    bccs22
    bccs22 New Member
    Figured that was it. I guess the sensitivity is for the Wake word to wake up the assistant. It'd be nice if it could be disabled without physically unplugging it.
  23. Mar 7, 2023 at 10:15 AM
    nodak67
    nodak67 New Member
    JR
    we use it to do voice to text replies while driving.
  24. Mar 27, 2023 at 7:20 PM
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    Anyone have the Carista adapter lying around? If so, let’s set up a rental program with a small fee that includes shipping to/from.
    mikvic likes this.
  25. Mar 28, 2023 at 5:55 AM
    articdesert
    23 1794 MGM
    I have one
  26. Mar 28, 2023 at 6:14 AM
    Hella Krusty
    Hella Krusty New Member
    The reality of all the safety innovations. My wife’s 2017 Lexus is the exact same.
  27. Mar 30, 2023 at 9:11 PM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    Do you know if you can turn the enhanced engine sound off with Carista? Referring to the engine sound pumped through the upgraded JBL sound system. Thanks
  28. Mar 31, 2023 at 1:02 AM
    articdesert
    23 1794 MGM
    yes, you can
  29. Mar 31, 2023 at 7:15 AM
    PERRY1060
    Perry
    Indiana
    Sweet! Thank you. My dealer couldn’t figure out how to turn it off. Im not sure if they didn't want to spend the time to look for it or couldn’t find it.
  30. Apr 3, 2023 at 4:42 AM
    nodak67
    nodak67 New Member
    JR
    dealer is just jerking your chain. its not that dam hard to find in techstream. especially if you are a certified toyota tech. they just didnt want to do it (either the tech, thinking its a waste of his time since they are not getting paid to do this, or the dealer doesnt want to waste a paying customer slot for the tech to do it)
    you could also offer to pay for an hour of tech labor and they will prob do it, but its just cheaper to pay for 1 month of carista to do it yourself. ($10)
    OnThaLake likes this.
