My Rigid Light is squeaking!
Discussion in 'Lighting' started by SouthBoundSteve, Sep 11, 2016.
  1. Sep 11, 2016 at 7:26 AM
    SouthBoundSteve
    SouthBoundSteve [OP] Rowdy Ron/Driverdog 2020
    BAMA Bound!
    2015 White Tundra Crew Max SR5/Off Road
    Bilstein 6112's and 5100's, Husky floor liners, etc..
    Hi gang,
    Well, last week had my Rigid Industries 30 " SR2 combo bar with the R.I. mounting brackets installed.
    Since then an annoying squeak has developed. The shop has readjusted and checked everything. When I hold the light itself, the squeak will go away when rocking the truck. Once I let go of it the squeak comes back.
    So we have contacted R.I. and just waiting for a response back to see if they have any solutions or suggestions.
    The light itself is great and could not be happier. I'm wondering if the brackets are sufficient which I would imagine they are.
    I'll keep you guys updated as to the fix or whatever the issue is...
  2. Sep 11, 2016 at 7:30 AM
    csuviper
    Broomfield, CO
    2012 Rock Warrior 5.7L 4X4
    Rubber washers at connection points might do the trick
  3. Sep 11, 2016 at 7:53 AM
    SouthBoundSteve
    BAMA Bound!
    Thanks Brian! This is one of the reasons why I like this site. I was thinking about that.
  4. Sep 11, 2016 at 7:57 AM
    csuviper
    Broomfield, CO
  5. Sep 11, 2016 at 8:23 AM
    RowdyRon
    RowdyRon SouthBoundSteve Fan Club President
    Ron
    Bentonville, AR
    2015 Radiant Red TSS Doublecab 4X4 Off Road
    Deck rail system, Bed divider, door sill protectors, LED reverse light bars, Aries Bull Bar with 28" 180 watt LED light bar, LED step lights, LED bed lights, driver-side grab handle, TRD Rear Sway Bar, BedRug bed mat and tailgate mat, Morimoto Fog Lights, more to come.....
    Brian brings up a good potential fix for the squeak. The only other thing I can think of is the possibility that the bumper plastic is making contact with the light bar perhaps.....
    Law323 and SouthBoundSteve [OP] like this.
  6. Sep 11, 2016 at 8:25 AM
    SouthBoundSteve
    BAMA Bound!
    Great point Ron. I was going to look for rubber type tape and apply it to the bottom between the bar and trim.
    Thanks for the input!
  7. Sep 11, 2016 at 8:27 AM
    RowdyRon
    Ron
    Bentonville, AR
    You are welcome, Steve. There may be just enough flex in the bumper plastic that a light contact could make it squeak against the bar. I know you will get it figured out!
    SouthBoundSteve [OP] likes this.
  8. Sep 15, 2016 at 8:42 AM
    SouthBoundSteve
    BAMA Bound!
    On further evaluation, it appears that he brackets were rubbing the cross member of the truck. Where the bracket comes up you'll see a spot on each side rubbed down. So I readjusted the brackets and I can tell you that the tolerances were tight!
    I went about my errands and so far no squeak.
    I'll keep my fingers crossed that this was it...
    Law323, RowdyRon and Sean266 like this.
  9. Sep 15, 2016 at 3:39 PM
    RowdyRon
    Ron
    Bentonville, AR
    Sounds like you have it surrounded, Steve!
  10. Sep 15, 2016 at 3:48 PM
    ToyotaTundraMike
    2015 Tundra
    Keep us posted! Was thinking of doing a similar setup in the future with the rigid mounts.
  11. Sep 15, 2016 at 4:21 PM
    SouthBoundSteve
    BAMA Bound!
    Hopefully...LOL!
    You bet Mike. Trick is once you get the bracket in place, push up on it and snug up the bolts. With a little contorting it can be done.
    If not, the grinder is coming out. Rigid tech support and another fabricator looked at the pics and confirmed.
    A good sign was when I put the light back in the brackets, it tilted downward. The light was free wheeling...sort of, if that makes any sense.
  12. Sep 15, 2016 at 6:35 PM
    Inferno16
    Inferno16 New Member
    I have the exact same setup, same squeak, had to losen the nut and pull down the braket or the entire lightbar while someone tighten the nuts. OR you can put some white grease where cross member and braket rubs. I did that and squeak went away immedaitely until it rained few times and ran through the car wash. But to get rid of sound permanently, you have to remove the braket and shave that area where it rubs...
  13. Sep 15, 2016 at 6:37 PM
    SouthBoundSteve
    BAMA Bound!
    You may want to let Rigid know. I didn't think I would be the only one with the issue. I did contact them and Alex was my point of contact.
    Thanks for the heads up.
  14. Sep 15, 2016 at 9:13 PM
    Law323
    Law323 Shhhhh....Boardude is really Batman.....
    Law
    Tennessee
    2012 4.6 L MGM DC
    Toytec BOSS suspension lift @ 3" (front) Toytec BOSS remote resi's (back) 1" Toytec block (rear) 275/70r18 Toyo AT2 Info system mod 3D MAXpider Kagu floor mats LED interior lights 50% ceramic tint front windows 35% ceramic tint windshield brow Bed mounted YETI bottle opener Paracord wrapped oh Sh!t bars 3" stubby antennae Upcoming: LED backup lights/cargo lights OEM Backup camera Method Standard 18x9 wheels Iron Cross Patriot step bars TRD sway bar Trifold or roll up tonneau cover
    Grinder was my first suggestion. But I guess if you want to pussyfoot around, rubber tape and washers would do just fine......sissy.
    :crapstorm:
  15. Sep 15, 2016 at 9:33 PM
    MatthewPTguy
    MatthewPTguy New Member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    LOVE the light!!! I have the RI Dually fog lights and love them. I've wanted to do the light bar... But haven't saved up the $$$.
  16. Sep 15, 2016 at 9:44 PM
    Law323
    Law
    Tennessee
    2012 4.6 L MGM DC
    Kinda hard to save money especially when you're a member of this forum.....Or so my wife tells me. I don't see the problem :confused::confused::confused:
  17. Sep 16, 2016 at 12:05 AM
    SouthBoundSteve
    BAMA Bound!
    :rofl: :p Leave my sister out of this...LOL!
    MatthewPTguy and Law323 like this.
  18. Sep 16, 2016 at 12:39 AM
    Law323
    Law
    Tennessee
    2012 4.6 L MGM DC
    LOL!!!!
    All's fair in love and tundras.com!! :oldglory:
    Oh yeah, tell your sister I said hey! LOL!!:rofl:
  19. Sep 16, 2016 at 12:42 AM
    SouthBoundSteve
    BAMA Bound!
    Oh Snap!! You know being from Joizee, we got da mafia here. Don't make me pick up da phone...Capeeche? :cool::bananadance::cheers:
    RowdyRon likes this.
