My New 208,000 Mile Tundra
Discussion in 'General Tundra Discussion' started by DesertWanderer, Jul 31, 2022.
  1. Jul 31, 2022 at 3:58 PM
    DesertWanderer
    DesertWanderer [OP] New Member
    2004 White Tundra
    Hello. I found my 2004 Tundra yesterday, one owner, 4.7 L, 208,000 miles. I looked up service records and I found 13 items addressed at 187,000 miles. The ones I have questions about are shown below.
    #1) WATER PUMP W/ TIMING BELT & DRIVE BELTS, R&R WATER PUMP W/ TIMING BELT & DRIVE BELTS, R&R~|~WATER PUMP W/ TIMING BELT & DRIVE BELTS, R&R~|~ ~|~WATER PUMP W/ TIMING BELT & DRIVE BELTS, R&R
    #2) POWER RACK & PINION ASSY, R&R (ADD ALIGNMENT)~|~POWER RACK & PINION ASSY, R&R (ADD ALIGNMENT)~|~ ~|~POWER RACK & PINION ASSY, R&R (ADD ALIGNMENT)
    #3) CUSTOMER DOES NOT WANT WORK DONE CUSTOMER DOES NOT WANT WORK DONE~|~ENGINE OIL DIPSTICK O RING LEAKING~|~ ~| ~CUSTOMER DOES NOT WANT WORK DONE
    #4) CUSTOMER DOES NOT WANT WORK DONE~|~BOTH FRONT SHOCK BUSHINGS SHIFTING DUE TO AGE~|~ ~|~CUSTOMER DOES NOT WANT WORK DONE
    Here are my concerns:
    #1) It looks like the timing belt was replaced. I cannot find a sticker anywhere under the hood showing that this was done. Where would the sticker be?
    #2) It looks like the "POWER RACK & PINION ASSY" was replaced. Is that "a thing" with this generation?
    #3) Does anyone know what "O-Ring" is needed for the dipstick and where I might get it?
    #4) I am not really sure what shock bushings shifting means on #4. Any help?
    I am working on my first day of ownership. Any help is appreciated!
    WVI and YardBird like this.
  2. Jul 31, 2022 at 4:02 PM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Oil dip stick o-ring should be about $2.00, Front shock bushing warn, it has 208K miles. Put some new shocks on it.
    AZBoatHauler likes this.
  3. Jul 31, 2022 at 4:07 PM
    DesertWanderer
    2004 White Tundra
    Thanks! Any idea on where to get the O-Ring?
    I am going to an online Toyota dealer I use for the shocks (I have 3-MR2's) unless I am convinced otherwise.
    In any case, THANKS!.
  4. Jul 31, 2022 at 4:16 PM
    TheBrit
    TheBrit Wrinkly member
    Mark
    2013 Double Cab Tundra 2WD stuckinthemud
    Worth checking the 'for sale' section on the forum. It's the reason I joined up in the first place. I managed to score a barely used set of shocks, locally, for a very reasonable price, for my 2013 2nd gen whose mileage (for it's age) makes yours looks barely run in. :rofl:
    I can't say if the rack and pinion is an issue on your model but the fact that you have a new unit that was put in 20,000 miles ago is likely to mean that it's going to be a good long while before it becomes an issue for you.
    EDIT: As for the 'o' ring it probably isn't worth jacking around, give your local Toyota stealership's parts dept a call and order one - for small consumables, IMHO, it's not worth risking some poorly fitting part sourced from Amazon for the sake of a couple of cents.
  5. Jul 31, 2022 at 4:18 PM
    Welcome from NY.
  6. Jul 31, 2022 at 4:38 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  7. Jul 31, 2022 at 6:00 PM
    DesertWanderer
    2004 White Tundra
    Here is one answer for my O-Ring question.
    Engine Oil Dipstick Tube Seal - Toyota (96721-19010)
    Maybe not. It is still on backorder!
