My Moon Roof Saga
Discussion in '3rd Gen Tundras (2022+)' started by Wtundra2023, Jan 31, 2026.
  1. Jan 31, 2026 at 11:28 AM
    Wtundra2023
    Wtundra2023 [OP] Bad Weld Aficionado
    2023 Limited Tundra, 2014 Limited Sequoia
    I have been struggling with the drivers side grab handle having water dripping out of it since I bought the truck. I have done most every fix I can think of (cleaning/boroscoping the front drains, fuel line zip ties on the drain tubes, sealing the seactions of the pan where it comes together in the front etc) and was about to try to force the dealership to replace the entire pan and has had to happen to some of the members trucks here on the forum.
    Before I went down that road, I had a thought to boroscope the rear drain channel and look what I found! I don't have the moon roof open that much nor does it get parked under trees so I don't believe that it got stuck in there during my ownership. I am hoping that it somehow made it into the channel during its time as a dealer demo and that is why it was dripping down the grab handle for so long.
    Time will tell for sure but I thought I would share this for anyone else who may be having a similar issue.
  2. Jan 31, 2026 at 12:45 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Is the dealer not willing to diagnose the issue? I understand they would require payment up front and then if they found a defect they would reimburse you.
    FrenchToasty likes this.
  3. Jan 31, 2026 at 1:45 PM
    Wtundra2023
    The dealer has said that its the drain tubes. I just did another water test and it still leaks. I took the headliner down partially and found its leaking from the seams of the sunroof pan where the front and the sides meet. Now to fight with the dealer to fix it.
  4. Jan 31, 2026 at 4:23 PM
    Wtundra2023
    This is the location of the leak. There is a droplet forming around the bolt hole in the pan. The water is coming in at the seam just above it.
  5. Feb 2, 2026 at 7:00 AM
    Wtundra2023
    I started the process of getting the dealership to fix the moonroof leak in my tundra today. Considering the location and how its leaking I believe it should be covered under warranty. However, there is a non-zero chance it won't be based on others past experience with this issue.
    If it is not, does any one know the steps or can point me to where I can find a set of instructions on how to remove and reinstall the moon roof? I have several options in mind to correct the issue myself should the dealer deny the claim but it would be nice to know what I would be getting into should I want to try to remove the moon roof myself.
  6. Feb 2, 2026 at 7:06 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    The car care nut has a video somewhere describing the process and saying if/when you pull the seal it's almost impossible to get it back in and not have a leak. If its at all possible to do the repair without removing the moon roof that would be your best chance. Otherwise you'll be swapping one leak for another. Ill find the video give me a minute.
    https://youtu.be/7HyuriUhTSo?si=SqqQbG3fHoUjfIXH
    1:40 in he goes over the seal.
  7. Feb 2, 2026 at 7:22 AM
    Wtundra2023
    They did change the design of the seal to where it does clip in all the way around the corners of the moonroof. There is a second seal that goes between the body and the pan that is what prevents water entry between the roof panel and the top of the pan. Not sure if that would fix the issues he is describing though. For me, the leak appears to be where the seams of sunroof pan where bonded together.
  8. Feb 2, 2026 at 7:46 AM
    Wtundra2023
    That video makes me think that I will probably see if I can create a sort of catch can that will collect and re-direct the water to a drain.
  9. Feb 2, 2026 at 8:01 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    If you plugged the hole with RTV would it then redirect to the drain tube?
  10. Feb 2, 2026 at 8:14 AM
    Wtundra2023
    I have thought about that as well but its in a very difficult to reach area both from the top/outside of the pan and inside/under the roof. I would be concerned I wouldn't be able to get the RTV in the right spot and not fix the leak and maybe make it harder to redirect.
  11. Feb 2, 2026 at 2:20 PM
    Wtundra2023
    Update from the dealer 2-2-2026. I provided them with 2 videos and a photo showing the leak location and my setup that verified the water leak at that location. Thus far they have not been able to replicate the leak yet and asked to keep it overnight to do more disassembly and try again in the morning.
    I will update this thread as I know more to keep track of the timeline and let others know of my experience.
    Update from the dealer 2-3-2026. They still haven't been able to make it leak. They are keeping it overnight. Again.
    Update from the dealer 2-4-2026. they are replacing the sunroof. Hopefully this will permanently fix the issue.
    1794forme likes this.
  12. Feb 3, 2026 at 10:17 AM
    donia
    donia New Member
    Miss’ippi
    2023 Celestial Silver Tundra 1794 4x4
    My (former) service dept couldn’t replicate it, more than once. It happens on mine only when parked nose down in heavy rain, as I stated, described in depth and emphasized. Dealer didn’t have any slopes around the lot, so they couldn’t replicate the condition it happened in (no, I do not use them any longer…this is just one of many reasons), so they could not replicate the issue. BS, there are curbs all around the place, but that wasn’t a workable option for them.
    @Wtundra2023 Is yours leaking while parked on flat ground or just when on an incline/decline?
    TucsonTundra1794 likes this.
  13. Feb 3, 2026 at 11:01 AM
    Wtundra2023
    So far its only leaked during heavy rain and most of the time parked nose down in the driveway.
    There are 2 levels of gutters built into the pan, an upper and a lower. The upper gutter is just under the seal around the panoramic roof that you can see from the outside. When water gets in that gutter up to a certain level it will leak. What it appears to be is the seam where the front part of the drain pan and the drivers side of the drain pan come together.
    I haven't heard back today from the dealership. I am hoping that they have either found the leak and are attempting to fix it, or are still trying make it leak and haven't given up on it yet.
    donia[QUOTED] likes this.
  14. Feb 4, 2026 at 10:49 AM
    Wtundra2023
    Updated the thread title to "My Moon Roof Saga" to more accurately depict what the thread has turned into. Latest update (also captured previously) is Toyota is replacing the moonroof. Hopefully this will be the end of the leaks.
  15. Feb 4, 2026 at 12:05 PM
    TheBigFudge
    TheBigFudge New Member
    23 Tundra Plat Hybrid
    While I think your issue is different.
    I had a similar leak but from the right side passenger and would spill through the A pillar and the leak into the headliner.
    It ended up being an issue with the gasket for the front windshield. Which had to be replaced.
    Hopefully your saga ends quickly.
    Wtundra2023[OP] likes this.
  16. Feb 4, 2026 at 12:08 PM
    Quinton595
    Quinton595 New Member
    2010 Toyota Tundra 4.6L V8, regular cab, long bed
    Today I learned that moon roofs have drain tubes.
    Never in a million years...
  17. Feb 4, 2026 at 1:14 PM
    Wtundra2023
    I found out about the tubes when the dealer told me they were the reason for the leaks. It is important keep them clear, but they weren't cause of the leak....
  18. Feb 4, 2026 at 1:24 PM
    CringyDad
    CringyDad New Member
    Scott
    Fresno, CA
    2024 Tundra 1794 TRD (blueprint/saddle tan)
    Nothing.
    On the topic of drain tubes, is there a recommended way to clean them? I try to periodically clean the tracks and guides on the slider as well as clearing bugs and debris off the air deflector and I would like to also flush the drain tubes if there's a good way of doing it.
  19. Feb 4, 2026 at 1:36 PM
    Wtundra2023
    I bought this off of the jungle website. Seems to work well. https://www.amazon.com/dp/B0CM6D2HBQ?th=1
    Quinton595 likes this.
