My lovely wife.
Discussion in '2nd Gen Tundras (2007-2013)' started by Vince, Nov 18, 2019.
  1. Nov 18, 2019 at 11:59 AM
    Vince
    Vince [OP] New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    She wrecked the crown jewel question I have is ....
    The paint toyota uses on the lower half of the bed that rock chip paint..
    Can you buy this specific paint or is it a special technique used when they painted the trucks. Needing white.
    The trucks is not bad all the damage was to the bumper and the lower corner of the bed where the bumper was located.
    Prostar 190 likes this.
  2. Nov 18, 2019 at 12:02 PM
    That is usually applied under the paint then paint is applied on top of it. I believe 3M calls it rocker panel coating. Hope this helps.
    Vince[QUOTED][OP] likes this.
  3. Nov 18, 2019 at 12:03 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    It’s sprayed before paint is applied, you can find some products in an aerosol form if you are in a pinch.
    Vince[OP] likes this.
  4. Nov 18, 2019 at 5:45 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
