My leather wheel wrap....
Discussion in 'General Tundra Discussion' started by Eric32444, Mar 9, 2019.
  1. Mar 9, 2019 at 12:29 PM
    Eric32444
    Eric32444 [OP] "Pick up your balls and load up your cannons..."
    Eric
    Panama City FL, Lynn Haven
    just finished with the Amazon 50 buck Chinese leather wrap...worked fine...looks pretty good
    few suggestions...if u have a problem with tedious monotony, this will test you...patience is a must...go slow and preferably buy a $10 cheap wrap and do your wifes car first as practice! thats what i did.
    i removed airbag and laid it on top of wheel. also removed wheel controls...i did not use the double sided tape in the kit...not needed if u go slow and work the wheel as u go.
    good luck!
  2. Mar 9, 2019 at 12:57 PM
    ProtoJ
    ProtoJ New Member
    2018 Crewmax TRD Off-Road
    I’ve been thinking about doing this.....how long did it take?
  3. Mar 9, 2019 at 1:28 PM
    Eric32444
    Eric
    i am pretty OCD on stuff like this ....took me around 4 hours including all mechanical stuff involved...but i had done one before a week ago....definately worth it!.... really upgrades the driving pleasure!... soft fat wheel!
  4. Mar 9, 2019 at 1:38 PM
    AlmightyCrash
    AlmightyCrash Tundra Rookie, Jeep Veteran
    Crash
    San Leon, TX
    2015 Tundra MGM SR5 TSS CrewMax
    Looks great!
    Mines still sitting in the box, but I’ll do it one day.
    040Tundra and Eric32444[OP] like this.
  5. Mar 9, 2019 at 1:39 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    I think that looks great
  6. Mar 9, 2019 at 1:45 PM
    Eric32444
    Eric
    well thanks! i appreciate that...
    eric
  7. Mar 9, 2019 at 2:13 PM
    Denver Pro
    Denver Pro New Member
    Sergio
    2017 TRD Pro Crew
    Coachbuilder shackles and spacers, 35's
    Mine just arrived yesterday... any other tips?
    Eric32444[OP] likes this.
  8. Mar 9, 2019 at 2:15 PM
    Blueline
    Blueline New Member
    Jeb
    Temecula, CA
    2016 Tundra TRD PRO crewmax
    Bakflip MX4
    Beautiful work. Looks factory. Enjoy the “feel.”
  9. Mar 9, 2019 at 2:33 PM
    Eric32444
    Eric
    i did the bottom middle section first....the real problem i have is how to tie off a section when i finish.... never quite sure how to tie the knot to finish... i dont think i did it the same way twice, lol....
    then i did the next 2 sections on the left and right of that....
    then i counted 25 loops down from the right top of the wheel at about 2:00 oclock where the 2 different textured leather is sown together...that put me right in the elbow of the right side spoke and i started there and went to the left out to end of the spoke...make sure u start on the 25th loop on both front and back side of the wheel...
    then i went from the 24th loop and went all the way up and around to the left and finished up all the way thru the left spoke...like i said, i had the everything in the center of the wheel removed out of way...
    continually massage and rotate and twist the leather into the position as you work...take a break after every section and just relax...if u get frustrated, just put it down and walk away for a while...try not to get pissed and yank stuff, as the thread gets easily tangled... i stopped every so often to untangle the thread....
    go slow and enjoy the journey...
  10. Mar 9, 2019 at 3:34 PM
    tacomawv
    tacomawv New Member
    Richard
    Looks good, I did mine a couple years ago. Took me 3 plus days. I can't stay on a task for long. It is my favorite mod.
  11. Mar 9, 2019 at 3:34 PM
    TheBeast The Beach
    looks great ! however i do not have the patience for that kind of work :)
    Brownsfanhere and Eric32444[OP] like this.
  12. Mar 9, 2019 at 3:40 PM
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    Looks great. I don’t have the patience to do it
  13. Mar 11, 2019 at 8:40 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    well done
  14. Mar 11, 2019 at 9:16 AM
    TXTundra2722
    2015 Black Tundra
    Looks great! I've looked at this company before as well. Isn't this the company that offers a customized section and none of the steering wheels in that section match our Toyota one?
  15. Mar 11, 2019 at 11:25 AM
    Eric32444
    Eric
    https://www.amazon.com/gp/product/B071RRXZQM/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
  16. Mar 11, 2019 at 12:00 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Looks good :thumbsup: may consider doing this along with the addition of the driver side handle on the A pillar
  17. Mar 11, 2019 at 12:22 PM
    Brownsfanhere
    Brownsfanhere New Member
    2015 Crew Max
    Looks great. Want to do this. I know myself though. 2 hours into it and I’d be done with it. No patience likely for this.
  18. Mar 11, 2019 at 12:38 PM
    Eric32444
    Eric
    absolutely have-to's......u touch the wheel every time you drive, and the view with the 2 grab handles give the truck a great stout feeling....
  19. Apr 7, 2020 at 11:23 AM
    Dragon36
    Dragon36 New Member
    2019 TRD Sport
    Just finished mine today. Wasted 4 hours and $50. Idk how you got yours to tuck under the air bag but mine isn’t even close. I even restitched a portion to adjust it.
