Mushrooms growing in shower - mold?
Discussion in 'Home Improvement' started by COTundra23, Apr 1, 2022.
  1. Apr 1, 2022 at 12:00 PM
    COTundra23
    COTundra23 [OP] New Member
    Hey Everyone,
    Over the past few weeks I’ve seen some of these little white mushroom like plants growing through the grout / tiles in my shower.
    Is this mold? Any ideas to remediate? Should I be concerned / is it harmful?
    thanks for y’all’s help..
    Taco-Spike and Darkness like this.
  2. Apr 1, 2022 at 12:03 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    You could start selling them to offset gas prices
  3. Apr 1, 2022 at 12:04 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Or clean your bathroom….
    scrubbing bubbles?
  4. Apr 1, 2022 at 12:08 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
  5. Apr 1, 2022 at 12:11 PM
    CNE0207
    CNE0207 New Member
    Arvada, CO
    2020 Cement CM Limited
    Bleach and a specific mold remover/cleaner… remove the grout i that area and let it dry out a few days before using caulk in those corners
  6. Apr 1, 2022 at 12:11 PM
    COTundra23
    Will do. Thank you!
  7. Apr 1, 2022 at 12:12 PM
    2mchfun
    A little bleach, scrubber, and elbow grease will make it all better faster than greased lightning!
    COTundra23[OP] likes this.
  8. Apr 1, 2022 at 12:13 PM
    COTundra23
    preciate it!!
  9. Apr 1, 2022 at 12:13 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Must be a joke ( I hope)
    BravoDeltaRomeo likes this.
  10. Apr 1, 2022 at 12:16 PM
    COTundra23
    Wish it was. This is at a rental property of mine
    FrenchToasty and Darkness like this.
  11. Apr 1, 2022 at 1:03 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Bleach and mold cleaner. That has not seen any cleaner in a good while. I have a rental house also, some people are filthy animals.
  12. Apr 1, 2022 at 1:11 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    when vegetables are growing in the filth it might be time to suggest the tenants hire a cleaner come at least a couple times a month
  13. Apr 1, 2022 at 1:13 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    That should be a sealant joint around the edge anyway. Like others have said, kill the organic growth and cut the grout out (the full depth of the joint) and fill it with a 100% silicone.
    Hopefully water isn’t being held in the pan under the tile, that’s a whole other set of issues.
  14. Apr 1, 2022 at 1:18 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    That explains so much. I have weird stuff happen at mine as well.
    Squatting Pigeon likes this.
  15. Apr 1, 2022 at 1:36 PM
    COTundra23
    I am In the crawl space now and besides the ground moisture, there is some dry rot but none of the joist are currently wet. Seems like there may of been an overflow in the past that was never addressed.
    My guess is the humid TN weather we have is compounding the warm showers and lack of cleaning.
    Installing a dehumidifier in the crawl space and going to redo the grout like others have suggested. Maybe install a more powerful exhaust fan
  16. Apr 1, 2022 at 2:46 PM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    If there is that much growth there, it is time to do a renovation. If there is enough mold/mildew to provide a base for mushrooms to grow, you have most likely have moisture behind the surface.
    I dealt with toxic black mold at our barracks at Ft Bragg, nasty stuff.
  17. Apr 2, 2022 at 1:40 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Wire the (oversized) exhaust fan to the light so it has to come on. Get that moisture out of there.
  18. Apr 2, 2022 at 1:55 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Or a humidity sensor.
  19. Apr 2, 2022 at 2:09 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    A couple of sprays of this and that'll clear up. Weekly sprays will keep it from returning.
  20. Apr 2, 2022 at 2:13 PM
    This is the way.^^^
  21. Apr 2, 2022 at 2:30 PM
    FrenchToasty
    Mo
    Bone stock
    Thank you, I’ll put that in my pocket as a get out of jail free card…….
