Multiple Codes, too many to narrow it down
Discussion in '2nd Gen Tundras (2007-2013)' started by WildFan, Apr 27, 2019.
  1. Apr 27, 2019 at 5:36 PM
    WildFan
    WildFan [OP] New Member
    2010 Tundra Double Cab 5.7 Flex Fuel 4x4
    2010 Tundra Double Cab 5.7 Flex Fuel. 122,000 miles.
    The typical Toyota tick got a little more pronounced so I threw the code reader on it. I got so many codes that I just can't narrow it down.
    Anyone seen anything like the list below. I'm hoping there is one root cause that is contributing to the other codes.
    P0300 Random misfire detected
    P0011 Intake camshaft position timing - over-advanced (bank 1)
    P0012 Intake camshaft position timing - over-retarded (bank 1)
    P0014 Exhaust camshaft position timing - over-advanced (bank 1)
    P0015 Exhaust camshaft position timing - over-retarded (bank 1)
    P0021 Intake camshaft position timing - over-advanced (bank 2)
    P0022 Intake camshaft position timing - over-retardeded (bank 2)
    P0024 Exhaust camshaft position timing - over-advanced (bank 2)
    P0025 Exhaust camshaft position timing - over-retardeded (bank 2)
    P0101 Mass or volume air flow circuit range/performance
    P0102 Mass or volume air flow circuit low input
    P0103 Mass or volume air flow circuit high input
    P0116 Engine coolant temperature circuit range/performance
    P011B Engine coolant temperature/intake air temperature correlatuion
    P0125 Insufficient coolant temp for closed loop fuel control
    P0128 Coolant thermostat (coolant temp below thermostat regulating temperature)
    Any help would be greatly appreciated.
  2. Apr 27, 2019 at 5:57 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Check the oil level right away, and check that you have engine oil pressure.
    Load test the battery, and make sure the terminals are cleaned bright and are tight.
    Somewhere after that I’d clear that list of codes, drive it, and see what codes come active first.
    Filthyphil likes this.
  3. Apr 27, 2019 at 6:13 PM
    WildFan
    Since the I found the codes, I've changed the oil early to check for any debris in oil or filter. It was all clean. I went ahead and changed the spark plugs since I wanted to check them all for fouling, burnt electrodes, etc.. The spark plugs all looked ok.
    After doing the oil change and the spark plugs, the codes are still there. I have started clearing the codes starting with P0300 misfire but it comes back immediately. Pretty frustrating that it doesn't show P0301 - P0308 to help narrow down a particular cylinder and/or cylinders.
  4. Apr 27, 2019 at 6:18 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Is P0300 the only code coming back, or just the only one you’ve tried clearing so far?
  5. Apr 27, 2019 at 6:20 PM
    WildFan
    It's the only one I've cleared. As soon as I clear it and navigate back in to clear the next code, P0300 is already back.
  6. Apr 27, 2019 at 6:42 PM
    Windsor
    Windsor New Member
    Oregon
    2008 Tundra Crewmax 5.7L
    Seat covers, SnugTop.
    What are you using to check/clear codes? Are you able to see parameters?
    landphil likes this.
  7. Apr 27, 2019 at 6:51 PM
    WildFan
    I have an Innova 3160d. I can read the parameters but I'm not familiar with them.
  8. Apr 27, 2019 at 6:52 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Are you clearing with the engine running? If so, try with key on, engine off. And like @Windsor said, being able to monitor live data is likely going to be necessary here.
    15whtrd likes this.
  9. Apr 27, 2019 at 6:53 PM
    WildFan
    I work for Toyota but I'm Maintenance in a manufacturing plant. I have access to the complete TIS system but unfortunately no access to Tech Stream.
  10. Apr 27, 2019 at 6:59 PM
    WildFan
    Yep, I'll have to try resetting the codes that way and see what comes back first. If you don't mind, keep watching this post and I'll get back with updates as I'm away from the vehicle for the weekend.
    Thanks for the help so far.
    landphil[QUOTED] likes this.
  11. Apr 27, 2019 at 7:08 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    No problem. You can always tag me or other members in your posts by putting the @ symbol in front of the username with no space.
    I’ll be honest, I’m better at reading and interpreting live data on commercial diesel engines, but I’ll help where I can.
    We have a “Ask the Toyota Tech” thread on here too, but I’m not sure how active it is lately.
  12. Apr 27, 2019 at 7:20 PM
    Windsor
    Windsor New Member
    Oregon
    A few things.
    Clear all codes.
    Check your cables. A bad ground will cause all sorts of weird stuff.
    Check battery voltage with engine off key off.
    Check again with it running.
    Check parameters for coolant temp sensor. Bad sensor can cause issues with other sensors/systems that require engine temp to know what to do.
  13. Apr 28, 2019 at 6:54 PM
    WildFan
    I tried resetting the codes with the ignition on but engine not running. The scanner told me it successfully erased all DTCs. It then proceeded to show me all the same DTCs again. I tried this several times with the engine running and without the engine running.
  14. Apr 29, 2019 at 5:14 AM
    Dr_Al
    Dr_Al New Member
    Al
    I didn't see anyone else say this but check your radiator fluid level. Is your expansion tank empty? Those last 4 codes are basically saying you are low on coolant. It should be one of the first things you fix as it will lead to bad things if you don't. Secondly the computer uses the coolant temp to determine how to adjust the timing and fuel/ air ratio.
  15. Apr 29, 2019 at 5:21 AM
    Jobthegiant
    Jobthegiant Super extra premium member delux
    2012 Tundra 2WD basically stock
    TRD wheels, Fog lights, Bed Liner, Under seat storage, Lots of scratches and rub marks
    Low on coolant would cause high temps. Coolant temp too low for closed loop is likely a bad thermostat, stuck open. The maf codes could be a bad or dirty sensor. Both parts should be testable. I'd start with the thermostat.
  16. Apr 29, 2019 at 5:44 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Of all those codes, the ones MOST CONCERNING to me is the camshaft timing codes. Those, combined with an increase in the "typical Toyota tick", may indicate a cluster**** in progress. I would drive it to the dealer immediately and hope for the best. Maybe it'll be something minor...better safe than sorry.
  17. Apr 29, 2019 at 9:19 AM
    Dr_Al
    Dr_Al New Member
    Al
    Actually low coolant will not always give you a high temperature indication. What happens is the temp sensor will no longer be submerged in coolant so it'll read like the engine is cold. However other indicators will tell the ECU that the engine is hot. The computer picks up on the disagreement and gives off codes. It takes seconds to check the coolant level. If too low bad things like warping the heads can happen.
    Jobthegiant likes this.
  18. Apr 29, 2019 at 12:25 PM
    WildFan
    The coolant level is fine and there is some in the overflow reservoir.
    When up to temp, I show coolant temp mid range, oil temp mid range, oil pressure mid range.
  19. Apr 29, 2019 at 12:32 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    All the codes coming back with the engine off makes me think that either the code reader isn’t working right or the ECM is fubar. Don’t rush out and replace it based on this though.
    Am I right to assume that the check engine light is on all the time?
  20. Apr 29, 2019 at 12:42 PM
    WildFan
    The check engine light has only come on once. When it came on, it wash flashing constantly. The truck had a great reduction in power. I pulled over, turned the engine off and when I started it again, the check engine light was off and engine power was restored.
  21. Apr 29, 2019 at 12:44 PM
    bigdogk9
    bigdogk9 New Member
    Ed
    2018 Toyota Tundra 1794 Edition
    Sounds like a bad thermostat for sure and as for the others that dont clear i would clear the codes with scan tool, then disconnect the battery while your changing the bad thermostat and then reconnect battery after disconnected for a least a hr and let all the modules reboot and see what returns then.
  22. Apr 29, 2019 at 12:50 PM
    15whtrd
    15whtrd Mr. Blonde
    I’ve never had a code reader erase the code and then have it come back up before at least starting the engine. Usually I have to drive a little bit for the code to come back. I think there’s something wrong with your scanner too.
    Aerindel and landphil like this.
  23. Apr 29, 2019 at 3:01 PM
    WildFan
    I haven't done anything with the thermostat as I couldn't find one locally.
    I did pull all four of the oil control valves that operate the variable valve timing. Each one was clean. Each one measured 8 ohms on the coil. Each one actuated when 12vdc was applied to the coil. I think that pretty well proves the oil control valves are good. It doesn't prove that they are being sent the voltage to operate when the truck is running. Really couldn't find a good test point for that and even if I could, I'm not sure how I could force the ECM to trigger them on/off.
  24. May 8, 2019 at 2:10 AM
    WildFan
    Well... I just don't understand it. Saturday night I took it to the Toyota dealer and dropped it off. I live about 40 minutes from the dealership and stopped and filled it up then drove some interstate miles. It actually sounded and responded better along the way.
    The dealership checked it out Tuesday and said they could not get it to set any codes. They said they drove it listened to it and could not manage to get to go into limp mode or trigger a single code. Guess I'll go see them Wednesday morning but I'm taking my spare set of keys and trying it out for myself before I talk with them.
    Wonder if I just got a bad tank of gas and that was the whole problem. I'll know more when I pick it up I suppose. Bad gas, intermittent sensor/connector. Something dying but just not fully dead.
  25. May 8, 2019 at 2:21 AM
    Aerindel
    Aerindel New Member
    Montana
    Have you checked your alternator?
    I know it sounds odd, but I had a failing alternator on different vehicle (it was putting out 20+ volts!) once that threw dozens of codes and lit up every light on the dash. All your sensors use a reference voltage and then some component that changes that voltage in response to readings. If that reference voltage is FUBAR it will cause sensors to tell the ECU all kinds of strange things.
  26. Nov 10, 2020 at 3:55 PM
    13tundradude
    13tundradude New Member
    LOS ANGELES
    2012 TUNDRA
    2013 4.6 ENGINE AND TRANS. COUPLED WITH A 5.7 REAR END LSD
    I have the first 9 codes, I'm yet to read the responses you received.
    I have a 2013 5.7 tundra
    1 p1604 startibility malfunction
    2 p1604 startibility malfunction
    3 p0300 Random misfire detected
    4 p0011 Intake camshaft position timing-- over--Advanced (Bank 1)
    5 p0012 Intake camshaft position timing-- over--Retarded(Bank 1)
    6 P0014 exhaust camshaft position timing-- over--Advanced(Bank 1)
    7 p0015 Intake camshaft position timing-- over--Retarded(Bank 1)
    8 p0016 crankshaft position-- camshaft position correlation--Bank1 sensor A
    9 P0017 crankshaft position-- camshaft position correlation--Bank1 sensor B
    10 P0018 crankshaft position-- camshaft position correlation--Bank2 sensor A
    11 P0018 crankshaft position-- camshaft position correlation--Bank2 sensor B
    12 p0021 Intake camshaft position timing-- over--Advanced (Bank 2)
    13 p0022 Intake camshaft position timing-- over--Retarded(Bank 2)
    14 P0024 exhaust camshaft position timing-- over--Advanced(Bank 2)
    15 p0025 exhaust camshaft position timing-- over--retarded(Bank 2)
    16 P0031 Ho2s heater control circuit low (Bank 1) sensor 2
    17 P0032 Ho2s heater control circuit low (Bank 1) sensor 1
    18 P0051 Ho2s heater control circuit low (Bank 2) sensor 1
  27. Nov 12, 2020 at 4:47 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    I think @13tundradude wants to know what @WildFan ended up figuring out? A lot of similarities in the codes.
  28. Nov 12, 2020 at 7:27 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Maybe a loose ground?? or was anything disconnected while the battery was still plugged in?? I got some of these codes when I pulled the MAF with the battery connected.. trying to figure out why my truck wouldn't start... My first suggestion would be to check and make sure all plugs are pushed in all the way...
  29. Nov 13, 2020 at 10:22 AM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
    May have been bad gas or maybe the fuel cap was not on correctly and triggered the issues? Or maybe a bad fuel cap? Seeing that is ran better after a fuel up.
  30. Nov 24, 2020 at 7:27 PM
    13tundradude
    LOS ANGELES
    2012 TUNDRA
    after starting the car like hell I noticed water flowing from the muffler.
    I have a blown head gasket.
