MPG after Ridge Grapplers or Worse?
Discussion in 'Wheels & Tires' started by treihing, Aug 13, 2017.
  1. Aug 13, 2017 at 8:48 AM
    treihing
    treihing [OP] MAGA
    TR
    Washington State
    2018 Black Limited CrewMax
    Good Morning Everyone-
    I have had my Ridge Grapplers for a month and a half or so now and since I have had them, my mileage has taken a dive. When I got my truck in May I was sitting between 15mpg and 16mpg. After I added my Grapplers, I am sitting at just above 11mpg. Is this typical for adding LT tires or could it be something else? The only other mods since my Grapplers are my TRD Air Intake and TRD Rear Sway Bar.
    Thoughts?
    TR
  2. Aug 13, 2017 at 8:50 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Computer "settling" the MPG the more you drive it too. Not all associated with the tires.
    Jsena and treihing[QUOTED][OP] like this.
  3. Aug 13, 2017 at 8:55 AM
    gosolo
    Ray
    NW Oregon
    What was the size of the tire you were running before the grapplers?
    Is the only change the tread design or did you go taller and wider also?
    treihing[OP] likes this.
  4. Aug 13, 2017 at 9:03 AM
    treihing
    treihing [OP] MAGA
    TR
    Washington State
    My truck was totally stock running 275/55r20 Duelers before the Grapplers which are 295/55r20.
    Jsena likes this.
  5. Aug 13, 2017 at 9:14 AM
    gosolo
    Ray
    NW Oregon
    You have several things happening.
    You no longer have an accurate reading of your speed and mileage because your larger diameter tires will cover a little more distance each time they turn. This can be recalibrated.
    Next, you will have an actual reduction in true MPG from decreasing mechanical advantage (less hp at the wheel) reduced traction (less rubber in contact with the asphalt) and increased wind resistance because the truck now sets higher and the engineered air flow geometry has changed.
    vanthesupreme, Jsena and treihing[OP] like this.
  6. Aug 13, 2017 at 9:18 AM
    treihing
    treihing [OP] MAGA
    TR
    Washington State
    Thanks Brother. Another reason why I love this forum.
    Black Wolf, TXMiamiFan and Jsena like this.
  7. Aug 13, 2017 at 9:26 AM
    gosolo
    Ray
    NW Oregon
  8. Aug 13, 2017 at 9:28 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I went from 15 mpg when stock, I put 37's in my truck 3 weeks ago and I'm getting about 12mpg now... lost about 3mpg now, I'm getting the 4.88 gears soon.. I've been told that will help with gas and pay for itself within the year..
  9. Aug 13, 2017 at 9:42 AM
    gosolo
    Ray
    NW Oregon
    If you're driving 15,000 miles in a year at 3$/gal gas you will save $750.
    What price were you quoted for the regearing?
    Jsena likes this.
  10. Aug 13, 2017 at 9:44 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Where did you come up with those #'s??? And yea I ended up finding a guy who all my friends use.. $500 for gears and bearing ans $300'labor $800'
    Black Wolf and gosolo[QUOTED] like this.
  11. Aug 13, 2017 at 9:54 AM
    gosolo
    Ray
    NW Oregon
    Pretty simple math; take the 15000 yearly miles, divide by 15 (miles per gallon) and you know you're using 1000 gallons per year. At $3/gallon gas it's $3000.00. Do the same thing divided by 12 (miles per gallon) and it's $3,750.
    If i keep the numbers even like these it's easy to do in your head.
    treihing[OP] and Jsena[QUOTED] like this.
  12. Aug 13, 2017 at 9:58 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    You smart guys lol, never would have thought of that.. well I'll get an increase of mpg when new gears come in.. thanx brofessor
    TXMiamiFan likes this.
  13. Aug 13, 2017 at 3:46 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    That will move your power band closer to what it was before the swap, but your odometer will still be off. You need to install a speedometer calibrator in order to be able to trust what your computer is telling you.
    Jsena[QUOTED] likes this.
  14. Aug 13, 2017 at 4:35 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I don't care about my speedometer lol..
  15. Aug 13, 2017 at 4:51 PM
    gosolo
    Ray
    NW Oregon
    This might not be the best thing to say when you get pulled over for speeding! lol
  16. Aug 13, 2017 at 4:52 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    True, but I did the speedo test app and it's like 7mph off. So I kinda have that in my head
    gosolo[QUOTED] likes this.
  17. Aug 13, 2017 at 6:15 PM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    That's what I did too. I went from 275/55/20 to 295/55/20 ridge grapplers. I checked the speedometer with my gps before and after the tire swap and, with the 295's, the speedometer is now accurate. I also lost about 1.5 mpg. I went from about 16.5 mpg to 15.0 mpg.
    gosolo likes this.
  18. Aug 13, 2017 at 11:20 PM
    TRDpro619
    TRDpro619 Follow My Build on Instagram:TRDorcaTUNDRA
    San Diego
    TRD Pro CM
    What gears are you getting for $500?! And wow $300 for labor I was quoted $1500... lol I'll drive for Vegas in a heartbeat for that deal
  19. Aug 13, 2017 at 11:32 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    $300 labor.. this guy in Vegas used to own audio excellence.. sold shops and does mechanic work out here.. I went to his shop the other day when my buddy was having him install some shit on his truck.. gears ans mini bearing kit was like $500 so that's what's up.. also my truck is 2wd so no need for front
  20. Mar 6, 2019 at 9:07 AM
    Bluechord04
    Bluechord04 New Member
    Justin
    2018 Platinum Tundra
    None
    I put on 275/60 20s on Furl Assault 20x10s, and I feel like mine has plummeted. I would estimate my speedometer is probably off only by 3 mph or so, but not sure how impactful this has actually been on fuel economy
  21. Mar 6, 2019 at 11:34 AM
    Baldmonkey22
    Baldmonkey22 New Member
    Quartz Hill, Ca
    I did 295/60/20 RG's and im about 12.5-13mpg when i used to be able to get about 14-14.5mpg on the same drive.i dont think much of it because the computers calculation is off. now for instance i know my commute is 5.9 miles but now after the tires it reports i only drove 5.6 so the truck is supplying the same amount of fuel to the engine per trip but it thinks its traveling a shorter distance therefore the illusion of worse than expected MPG
