Mounting Shovel to Deck Rail
Discussion in '3rd Gen Tundras (2014-2021)' started by NewImprovedRon, Oct 16, 2017.
  1. Oct 16, 2017 at 3:29 PM
    NewImprovedRon
    NewImprovedRon [OP] Hey! Get off my grass!
    Ron
    Bentonville, AR
    2015 Radiant Red TSS Doublecab 4X4 Off Road
    Deck rail system, Bed divider, door sill protectors, LED reverse light bars, Aries Bull Bar with 28" 180 watt LED light bar, LED step lights, LED bed lights, driver-side grab handle, TRD Rear Sway Bar, BedRug bed mat and tailgate mat, Morimoto Fog Lights, more to come.....
    I know I've seen posts where some of you have mounted a shovel to your OEM deck rails but I'll be darned if I can find any posts now. How have you done it?
    Wrongside likes this.
  2. Oct 16, 2017 at 3:32 PM
    COMiamiFan
    COMiamiFan SSEM #3. Don't forget to try the search bar.
    Jose
    Parker, CO
    2016 White Crew Max TRD
  3. Oct 16, 2017 at 3:36 PM
    joonbug
    joonbug bacon
    Joon
    NorCal - Dublin
    2020 Limited DoubleCab
    This was before painting them black.
    RJVA, Jman245, blue16 and 4 others like this.
  4. Oct 16, 2017 at 4:40 PM
    NewImprovedRon
    Ron
    Bentonville, AR
    Jose and Joon, thank you, Gentlemen!
    COMiamiFan and joonbug like this.
  5. Oct 16, 2017 at 4:45 PM
    NewImprovedRon
    Ron
    Bentonville, AR
    Joon, what hardware did you use to drop down the height of the shovel?
  6. Oct 16, 2017 at 4:56 PM
    joonbug
    joonbug bacon
    Joon
    NorCal - Dublin
    I chopped up some metal stock I had laying around, drilled them and bought some SS bolts and nuts. I also have unistrut so I used these cone nuts, not sure about OEM rails though.
    https://www.google.com/search?q=uni...&ved=0ahUKEwjx4P7yqvbWAhUP52MKHQxlAYsQgTYIiAI
    Ron, if you use the quick fists, I think you’re better off using the “mini” quick fists. My shovel is a little loose on the tightest setting of the regular quick fists.
    2mchfun likes this.
  7. Oct 16, 2017 at 5:04 PM
    NewImprovedRon
    Ron
    Bentonville, AR
    Thank you, Sir! I'll check out my drop down options and see how thick my shovel's handle is. Gracias!
    joonbug likes this.
  8. Oct 16, 2017 at 5:13 PM
    joonbug
    joonbug bacon
    Joon
    NorCal - Dublin
    YW Ron. Here’s one last close up with minis on top. 8A068EE8-9826-4F64-ACFB-B837DA06CEEE.jpg
    Hightide, Sunnier, Wrongside and 2 others like this.
  9. Oct 16, 2017 at 5:52 PM
    NewImprovedRon
    Ron
    Bentonville, AR
    Cool Beans, Joon!
    joonbug likes this.
  10. Oct 16, 2017 at 7:25 PM
    COMiamiFan
    Jose
    Parker, CO
    I tried the mini fists and didn’t work. The front part of the shovel was fine, but the fatter part didn’t fit with the minis. The original size works better for IMO. Either that or I’m not as strong as @joonbug :muscleflexing: to pull those straps over the handle.
  11. Jan 24, 2018 at 2:01 AM
    AZTRDPro
    AZTRDPro New Member
    2016 TRD PRO
    BFG KO2 275/70 Bak Ind. Revolver X2 Lock'r Down Console Safe LED interior lights, Reverse lights Rotopax bedrail mount, storage and fuel pax Husky Xact Contour Floor liners All-Pro Sliders Baja Designs Squadron Sport-R fog light kit
  12. Jan 24, 2018 at 2:43 AM
    Prostar 190 Super Secret Elite Member #9
    Really looks good.
  13. Jan 24, 2018 at 4:34 AM
    Vizsla
    Vizsla New Member
    Dave
    Arizona
    2018 Cement Crewmax
    I use regular quick fists for my shovel, and mini quick fists for my axe. The mini fists for the axe mount on the back side of the regular fists in first pic.
  14. Dec 8, 2020 at 3:39 PM
    RobertD
    RobertD "I call it Vera" ~Jayne Cobb
    Robert
    DFW, Texas
    @RainMan_PNW you were asking about these the other day. I was curious too and the guy we asked hasn't responded. I found this thread and you might appreciate the info here as well.
    RainMan_PNW likes this.
  15. Jan 23, 2021 at 5:42 AM
    Jman245
    Jman245 Just moving about my way.
    Jay
    R.CUCAMOMGA,CA to Austin,TX
    '19 Tundra TRD SPORT
    How did you mount the jerrycan holder?
    BravoDeltaRomeo likes this.
  16. Jan 23, 2021 at 7:07 AM
    602runner
    602runner New Member
    Any other good ways to bolt to the stock rail? We’ve seen T-slot nuts and cone nuts in unistrut.
  17. Jan 23, 2021 at 9:03 AM
    joonbug
    joonbug bacon
    Joon
    NorCal - Dublin
    4 bolts drilled through the bed. Also needed a couple shims under the holder due to the uneven floor.
  18. Jan 23, 2021 at 9:19 AM
    Quikrete
    Quikrete New Member
    Used t but and bolt off of Amazon. Then grabbed a piece of flat stock extension at lowes(same area as unistrut)
    7B544D5C-26C2-4BA9-87AD-C490671603D0.jpg ED0FE315-77D4-46EF-BA86-7F04CAFFD353.jpg 1D4D7583-8825-4F10-98D4-FD676C087D53.jpg 29313773-ADCB-41CC-A5CA-7B60F540BCED.jpg 2CBE3BEE-4E45-4B5F-A694-E7E35AFF9E43.jpg
  19. Jan 23, 2021 at 9:47 AM
    Jman245
    Jay
    Sweet! Thanks!
    joonbug likes this.
  20. Jan 23, 2021 at 4:22 PM
    2mchfun
    2mchfun Lead foot, left lane, loud stereo
    2021 White 4x4 CM Trail Ed.
    Shovel?? Man that is why I sold my ford products! Believe me, after you sell the old Fords and purchase a fifty thousand dollar truck, you suddenly stop getting so far off the path! Kinda funny how that works!
