Morimoto 3rd brake light issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by 19TRDProZ, Mar 31, 2023.
  1. Mar 31, 2023 at 6:20 PM
    19TRDProZ
    19TRDProZ [OP] New Member
    just received my 3rd brake light from Morimoto and it seems like a design flaw they did not add the screws that the nut tights onto.
    top is the new morimoto bottom is stock.
    not sure if i’m missing something but there seems to be no way to tighten this down.7C5B478C-FE86-4428-AF42-FA11DAB3CE47.jpg
  2. Mar 31, 2023 at 6:26 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Do you have to take apart the factory housing and move those screws over to the MM unit?
    Edit - NVM.
    RegGex likes this.
  3. Mar 31, 2023 at 6:26 PM
    RegGex
    RegGex I noticed you copied my beard
    Oregon
    2021 TRD Pro CM
    You actually are missing something :D (so are all the folks who got theirs shipped out) Morimoto sent out an email earlier so you should be getting yours soon and you’ll be all set :thumbsup:
  4. Mar 31, 2023 at 6:28 PM
    19TRDProZ
    i figured thanks!
    RegGex likes this.
  5. Apr 4, 2023 at 9:03 PM
    Tundra-XP
    Tundra-XP New Member
    Will
    2020 Toyota Tundra XP MGM CM TRD Off Road
    I am looking at getting one of these. Let us know how bright the lights are, brake and cargo?
    TucsonTundra1794 likes this.
  6. Apr 4, 2023 at 9:50 PM
    19TRDProZ
    i plugged mine in and they are much brighter than stock.
    Y0TA PR0 and Tundra-XP like this.
  7. Apr 4, 2023 at 10:44 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    also waiting for the threaded mounting studs.
    WILLINH and Tundra-XP like this.
  8. Apr 5, 2023 at 8:34 AM
    mista_g
    mista_g New Member
    2016 Quicksand TRD Pro
    Can we get a side by side comparison, specifically how much more will it protrude out of the roof compared to stock? Thanks
    rdiddy5 and Y0TA PR0 like this.
  9. Apr 5, 2023 at 2:05 PM
    19TRDProZ
    i can once these studs come in and i get these installed.
    mista_g[QUOTED] and Y0TA PR0 like this.
  10. Apr 5, 2023 at 2:09 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I might have to get that next!
    Y0TA PR0[QUOTED] likes this.
  11. Apr 5, 2023 at 3:52 PM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Don’t forget a install video. Lol.
  12. Apr 20, 2023 at 7:12 PM
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    2015 Tundra DC Silver Sky
    275/65/20 Goodyear Wrangler Duratracs (May2024) Full ARH long tube system Bilstein 6112 Front +2.7" Bilstein 5160 Rear & Icon 1.5 AAL & +2.0 Shackles Fender Flares 1D6 White Knuckle sliders TRD Grille Morimoto LED Headlights with LED DRL/sequential amber switchback turns Rigid Fogs with Square TRD Bezel 4x LED bed lamps wired in OV Tune base load with iterations coming Tech12Volt remote with 2 way fobs and range extender antenna 4.88s with Auburn TRD skid plate Koyo radiator - FAILED REINSTALLED OEM Tyger tri-fold bed cover Bed mat from Boss 4x4 Front bumper spacers 0.5 inch by Boss 4x4 Pop n Lock tailgate wired in Black badging all around Classico Faux Leather Seat Covers Rough Country Floormats Halo 9 HU Underseat kicker sub JRT upgraded speakers
    FYI - I received my Morimoto 3rd brake light today and the box did include the two self tapping long 10mm mounting studs.
    rodm1 likes this.
  13. Apr 20, 2023 at 8:26 PM
    mista_g
    mista_g New Member
    If anyone gets a chance can we get a side by side of stock vs the Morimoto. Curious how much more it protrudes away from the truck.
  14. Apr 21, 2023 at 7:42 AM
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    I can take some profile before and after pictures once I get to it. Chilly outside and even snow flurries this aft here in Iowa today.
    mista_g[QUOTED] likes this.
  15. Apr 21, 2023 at 10:53 AM
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    Question on that extra short harness 5028 p/n. I didnt see in the instructions where this short piece connects to.
    Did you end up using it somewhere? Thanks
  16. Apr 21, 2023 at 11:14 AM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    That 5028 I believe is direct connection for NON flashing before going solid mode.
    mzim[QUOTED] likes this.
  17. Apr 21, 2023 at 12:06 PM
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    2018 Crewmax 1794 4x4
    following
  18. Apr 21, 2023 at 6:23 PM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Got her done finally!
    Jego, dla500, coldcanuk and 7 others like this.
  19. Apr 21, 2023 at 6:47 PM
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    Looks clean...Always liked black accents on a white Tundra.
  20. Apr 22, 2023 at 6:46 AM
    mista_g
    mista_g New Member
    Does look legit.
  21. Apr 23, 2023 at 5:13 PM
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    Installed late yesterday. I have a DC and installation wasn't a nightmare like Ive read.
    You really have to pull hard to get the original lamp housing pulled away from the foam adhesive.
    I used a heat gun and alcohol to clean down to the metal.
    The headliner is a semi-rigid piece of plastic and will bend down enough to get your hands in to get a socket on the 10mm.
    The hardest part was getting the small 10mm flange head screw started on the extended stud up inside the roof.
    Heed advice when they say to have a magnetic socket or a piece of tape holding the nut secure while removing and starting.
    The headliner will re-assemble fairly easily by pushing up where the anchors pop back in.
  22. Apr 23, 2023 at 5:21 PM
    Jim LE 1301 Camaro Lover, SSEM # 11
    Did you have to remove anything on the headliner to get it down enough to remove the 2 nuts?
    Y0TA PR0 likes this.
  23. Apr 23, 2023 at 5:36 PM
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    I did remove the 2 small 10mm bolt on the c-pillars and pulled the top of the trim out.
    Other than that I just slipped a hand up there and pulled down and the headliner pops down in 4 places.
    The anchors can fall out of the mounts so watch for that. I was lucky I found one that fell out.
  24. Apr 23, 2023 at 5:49 PM
    So the coat hooks and the seat belt trim didn't have to removed?
  25. Apr 23, 2023 at 6:09 PM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    I did pulled back on the seat belt trim just to get to the liner to be pulled down, that coat hook I don’t have in mine
  26. Apr 23, 2023 at 6:13 PM
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    I did not have to remove the coat hooks. The seat belt trim piece was loosened at the top by removing one 10mm bolt and popping out an anchor. I have large hands and had no problem getting both hands in position for the nut removal/install
    WILLINH and Jim LE 1301[QUOTED] like this.
  27. Apr 23, 2023 at 7:01 PM
    :hattip:
  28. Apr 23, 2023 at 7:01 PM
    :hattip:
  29. Apr 24, 2023 at 10:06 AM
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    Looks awesome. Now WE NEED ACTION SHOTS! Light in use etc
  30. Apr 25, 2023 at 8:46 PM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Not the best picture but bright as hell!
    And the white one’s actually light up your bed pretty good. If I didn’t have a cover of course lol.
