Mixed lift?
Discussion in 'Suspension' started by 14srAKH, Apr 12, 2020.
  1. Apr 12, 2020 at 7:37 PM
    14srAKH
    14srAKH [OP] New Member
    2014 tundra sr white
    Wheels, center console swap, tinted windows,
    Alright guys I need help.
    I've done some reading and searching and reading and searching.
    I'm looking at piecing my lift kit and am looking for input on possible issues I might run into?
    2.25 inch preloaded struts.
    2 inch spacers on top of those
    1 inch diff drop
    2 inch add a leaf
    2 inch shackles
    For a total of 4.25 inches of lift in the front and 4 inches in the rear.
  2. Apr 12, 2020 at 8:06 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I don't think you will even be able to get the coilover installed...besides you will probably have alignment issues.
  3. Apr 12, 2020 at 8:07 PM
    14srAKH
    is there a way to make that possible?
  4. Apr 12, 2020 at 8:08 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    dump the spacer. Then it will work.
  5. Apr 12, 2020 at 8:09 PM
    14srAKH
    okay that being said. How can I get another 2 inches with the 2.25 inch preloaded struts?
  6. Apr 12, 2020 at 8:14 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Are you 2 wheel drive or 4 wheel drive ?
    There are spindle lifts out there that you can use if you are 2 wheel drive..
  7. Apr 12, 2020 at 8:21 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    For the amount of lift your wanting to achieve, You are gonna need aftermarket uca's.
  8. Apr 12, 2020 at 8:35 PM
    14srAKH
    Sorry. Meant to include that. I'm 4x4
    In my 2014 tundra sr double cab.
  9. Apr 12, 2020 at 9:03 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    If you're shooting for ~4.5" of lift, the safest way to do that is with a drop bracket. Stacking those thick spacers on top of that much coilover preload is just asking for damage. The lower stem of the coilover will snap in half once you do any mild offroading.
  10. Apr 12, 2020 at 9:58 PM
    TXTundra2722
    2015 Black Tundra
    Damage from even bouncing on the road too! It doesn't take much when you stack anything like that. Some things you don't want to cheap out on
  11. Apr 12, 2020 at 9:59 PM
    TXTundra2722
    2015 Black Tundra
    The rear is fine.... plus you can go 4 up front and 2 in the rear and still have more height in the rear vs the front
  12. Apr 12, 2020 at 11:21 PM
    vegas4x4
    vegas4x4 Blaaack
    Las Vegas
    2016 Black TRD CM 4x4
    I think 3”, maybe 3.5” is the highest ur gonna get up front without a drop-bracket lift. 3.5” is gonna wreck ur cv’s and probably wont align correctly without upper control arms. I had a 3” leveling kit for a while and it rode like stock, it was a top hat spacer, not a preload. Preloads suck.
