Minor steering wheel vibration
Discussion in 'General Tundra Discussion' started by teedubbya, Mar 26, 2018.
  1. Mar 26, 2018 at 7:18 PM
    teedubbya
    teedubbya [OP] I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    Is some minor vibration normal? First tundra.
  2. Mar 26, 2018 at 7:24 PM
    Lifted?
    What kind of tires?
    Exhaust?
  3. Mar 26, 2018 at 7:26 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    I dont think that's normal.
  4. Mar 26, 2018 at 7:28 PM
    Marty McFly
    Morty McBoonJug
    You could try putting air in the tires :notsure:
    I noticed my steering wheel vibrating a little and found that my tires were a little low. Added some air and now it's smooth as butter again :burnrubber:
  5. Mar 26, 2018 at 7:33 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    No, not normal. Certain speed?
  6. Mar 26, 2018 at 7:37 PM
    teedubbya
    Austin TX
    Not lifted. Michelin defenders. Stock exhaust. Seems fairly constant at >30mph.
    PSI recommendations? I’ll check that first, of course.
    I only noticed because my watch band was rattling lol
  7. Mar 26, 2018 at 7:40 PM
    Could be a tire balancing issue
    joonbug likes this.
  8. Mar 26, 2018 at 7:40 PM
    nk1794
    San Jose, CA
    When was the last time you have your tires balanced? That's what I would check first.
  9. Mar 26, 2018 at 7:59 PM
    teedubbya
    Austin TX
    Just bought it today, 73k miles. Tires look fairly new. It’s certified so I’d hope they’d have done it, but I reckon I can take it to the dealer and get them to do it.
  10. Mar 26, 2018 at 8:03 PM
    nk1794
    San Jose, CA
    You can also try rotating the tires and see if the rear tires work better in the front.
  11. Mar 27, 2018 at 5:21 AM
    Wrongside
    Wrongside New Member
    AB
    2016 Tundra
    Is it constant, or only the first 10-15 minutes of driving? I ask because some of us had noticed minor vibration, but it turned out to be tires 'flat-spotting' from be parked for a while.
    @Law323, a little higher pressure fixed your problem too, didn't it?
    Law323 likes this.
  12. Mar 27, 2018 at 5:36 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Yes sir Upped my pressure from 30 (don't know why the dealer dropped it that low when I went in for an oil change and rotation) to 40-45. Took care of my situation like a champ.
    Wrongside[QUOTED] likes this.
  13. Mar 27, 2018 at 5:44 AM
    Wrongside
    AB
    2016 Tundra
    Good, I thought that had fixed it for you, but me old memory can be foggy sometimes. :) 40ish PSI helped mine too. Tho when it's cold and it's been parked 5-7 days I'll still get a little initial vibration.
    OP, not sure this is even your problem, but it's worth mentioning. Hopefully it's a simple fix for you.
    Law323[QUOTED] likes this.
  14. Mar 27, 2018 at 6:01 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    LOL
    Yeah, i've been contemplating getting a small compressor to keep in my truck for those cold days. Even when parked half a day, I'll get some flat spots, probably not as pronounced as 5-7 days!
  15. Mar 27, 2018 at 9:25 AM
    teedubbya
    Austin TX
    So front PSI is around 33. 275/55/20’s
  16. Mar 27, 2018 at 9:32 AM
    That PSI is fine. Sometimes, a tire is not perfected when manufactured. Rotate the tires or look into road force balancing- although that should not be needed with those street tires.
  17. Mar 27, 2018 at 9:37 AM
    teedubbya
    Austin TX
    Thanks, will do
