Mildew wiper fluid
Discussion in '1st Gen Tundras (2000-2006)' started by 05newb, Apr 26, 2018.
  1. Apr 26, 2018 at 4:26 PM
    05newb
    05newb [OP] New Member
    '05 SR5 Access Cab-2wd-4.0L
    K&N intake, Removed badges
    For some reason every time I use my wiper fluid, my truck cab gets filled with this horrid stench of mildew. Somehow the water has gotten nasty in my reservoir. I drained it all out and re-filled with clean water but it still does it. What are some ideas on how to clean this out?
  2. Apr 26, 2018 at 4:42 PM
    NewImprovedRon
    NewImprovedRon SouthBoundSteve Fan Club President
    Ron
    Bentonville, AR
    2015 Radiant Red TSS Doublecab 4X4 Off Road
    Deck rail system, Bed divider, door sill protectors, LED reverse light bars, Aries Bull Bar with 28" 180 watt LED light bar, LED step lights, LED bed lights, driver-side grab handle, TRD Rear Sway Bar, BedRug bed mat and tailgate mat, Morimoto Fog Lights, more to come.....
    I have read that some people use a weak blend of (10%) bleach and water and run it through the washer/lines. I wouldn't do that though as I would be concerned about the effect on rubber and paint that it contacts. Some folks recommend using hot (not boiling) water in the reservoir and pumping it through the lines to the nozzles. After it is cleaned out, make sure you use a washer fluid instead of plain water.
    05newb [OP] likes this.
  3. Apr 26, 2018 at 5:12 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Buy a couple bottles isopropyl alcohol, run the sprayer to get it in the lines, let it sit for a couple minutes, repeat a couple times and fill it with washer fluid. The remaining alcohol won't hurt anything and will mix with the fluid.
    Bbombs, Grey Wolf and 05newb [OP] like this.
  4. May 3, 2018 at 8:23 AM
    05newb
    I ran a half bottle of alcohol through the lines and it worked. No more stank in the water. Then had to buy a $3.69 bottle of Prestone washer fluid but it doesn’t have any smell
    NewImprovedRon and Festerw like this.
  5. May 3, 2018 at 12:42 PM
    NewImprovedRon
    Ron
    Bentonville, AR
    Glad you got it back in shape!
