Microphone on Kenwood HU not working
Discussion in 'Audio & Video' started by Thattundradude, Feb 22, 2019.
  1. Feb 22, 2019 at 3:23 PM
    Thattundradude
    Thattundradude [OP] New Member
    Platinum Tundra
    Lifted
    Hi all. Got a dnx574s hu installed it, went to test the mic and nothing. I can hear the other person but they can't hear me at all. I had the same issue with my dmx7705s
  2. Feb 22, 2019 at 5:23 PM
    13igtymer
    13igtymer New Member
    2016 toyota tundra crewmax limited
    Are you using the factory microphone or the one that came with the headunit?
  3. Feb 22, 2019 at 6:39 PM
    Thattundradude
    Platinum Tundra
    Lifted
    Both
  4. Feb 22, 2019 at 7:07 PM
    13igtymer
    How are you able to use both microphone? I have a Kenwood ddx 9903s and i couldn't use the factory microphone.
    Mnorris1206 likes this.
  5. Feb 22, 2019 at 7:11 PM
    Mnorris1206
    08 tundra
    I'm with @13igtymer I also had to use the keenwood one as well. Amd in some head units you will have to go into settings and turn it on. Other then that not sure .
  6. Feb 22, 2019 at 7:26 PM
    13igtymer
    Just try using the Kenwood microphone. I have mine installed in between the sun visor and the rear view mirror. I wish I could have use the factory microphone phone. It would look cleaner.
  7. Feb 22, 2019 at 7:40 PM
    Thattundradude
    Platinum Tundra
    Lifted
    What I meant was, I used the factory one with the dmx7705s and I had another one for dnx574s. I've plugged the mics into the computer to test the second one and it worked. What's the setting to turn it on?
  8. Feb 22, 2019 at 8:47 PM
    GNTundra
    Gino
    2013 White
  9. Feb 22, 2019 at 9:31 PM
    Thattundradude
    Platinum Tundra
    Lifted
    I guess I'll try that, I also ordered another mic just to see if it does anything.
  10. Oct 3, 2019 at 11:30 AM
    chinadog
    chinadog New Member
    Knoxvegas
    2018 Midnight Black Metallic 1794, 2013 Black Platinum
    @Thattundradude
    Did you ever get your mic issue resolved?
