Method standard guys
Discussion in 'Wheels & Tires' started by tuckertravis, May 14, 2018.
  1. May 14, 2018 at 5:45 AM
    tuckertravis
    tuckertravis [OP] New Member
    Tucker
    Abilene, TX
    2018 TRD Sport Crewmax
    None... Yet
    I'm looking at getting 20's at +18 or 17's at 0 offset. I know the 0's are going to have some bigger stickout and I know tire rub will be different with both and different with different size tires. My question is you guys that are running both of these setups which is worse rubbing and trimming wise and what not? Input is much appreciated
    Oh and I'm getting an 18 TRD sport if that makes a difference
  2. May 14, 2018 at 6:03 PM
    tuckertravis
    Tucker
    Abilene, TX
    None... Yet
  3. May 14, 2018 at 7:13 PM
    TheBeast The Beach
    18" with +18 offset.
    pictured here with 295/70/18
    also @831Tun runs them too
    831Tun likes this.
  4. May 14, 2018 at 7:18 PM
    tuckertravis
    Tucker
    Abilene, TX
    None... Yet
    Stock height or lifted/leveled?
    Any rubbing?
  5. May 14, 2018 at 7:22 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    What is this rubbing you speak of? :anonymous: Seriously, I'm running 18s with +18 offset. I've done the CMC, nothing rubs anymore. The larger the rim, the more expensive the tire. You will usually find less selection with larger wheels to. IMO 20s aren't for wheeling.IMG_20180427_131755775.jpg
    TheBeast and jewsNbrews like this.
  6. May 14, 2018 at 8:37 PM
    tuckertravis
    Tucker
    Abilene, TX
    None... Yet
    What needed trimming on yours? I'm leaning more towards the 17's with 0 offset to get a little more stick out. Just can't decide between 285's or 295's
  7. May 14, 2018 at 8:42 PM
    yoneytan
    yoneytan New Member
    Asi
    14 CM
    I know you asked for standards but maybe this helps some. 18” Method NV +25 with 295/70 Toyo Open Country. Installers removed both front mud flaps which I will trim and put back on. Didn’t take a pic showing how far out the tires are but they’re about an inch beyond the fenders. If you need to see it lmk.
    Erichudgins and 831Tun like this.
  8. May 14, 2018 at 8:43 PM
    yoneytan
    yoneytan New Member
    Asi
    14 CM
    My truck has a 3/1 kit
  9. May 14, 2018 at 8:48 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I did the cab mount chop, that's about it. I try pretty hard to get it to rub and it doesn't right now. I'm switching UCAs and will get more caster, we'll see what happens then. The lift is roughly 3+ /1.5 with about 12.5" of travel in front and 13" rear.
  10. May 14, 2018 at 10:38 PM
    TheBeast The Beach
    3/1 and cmc done/front liner pushed fw.
  11. May 14, 2018 at 10:38 PM
    TheBeast The Beach
    with 0 offset you gonna need some good trimming
    831Tun likes this.
  12. May 15, 2018 at 8:08 AM
    tuckertravis
    Tucker
    Abilene, TX
    None... Yet
    Will one of y'all running the 18's with +18 offset take a pic down the side of your truck please? More than likely going the 18 route
  13. May 15, 2018 at 8:14 AM
    yoneytan
    yoneytan New Member
    Asi
    14 CM
  14. May 15, 2018 at 8:56 AM
    tuckertravis
    Tucker
    Abilene, TX
    None... Yet
  15. May 15, 2018 at 9:07 AM
    TheBeast The Beach
    check Icon wheels as well. 17" size with 25mm offset. Optimized for Tundras. shouldn't have to do much to fit 295 on them.
    tuckertravis[OP] likes this.
  16. May 15, 2018 at 9:57 AM
    yoneytan
    yoneytan New Member
    Asi
    14 CM
    You’re welcome!
    That was the exact set up I was gonna do if I were to proceed with fender flares which I believe he ended up doing.
