message: Trailer Brakes turned Off
Discussion in 'Towing & Hauling' started by ghengis, Jul 28, 2019.
  1. Jul 28, 2019 at 5:49 PM
    ghengis
    ghengis [OP] New Member
    mike
    2018 toyota tundra
    I have been getting this message now for a few months. Trailer brakes are not working, but all the lights are functioning normal. It shows trailer connected and no error message. Took it in to dealership and they said it was okay. I tried hooking it up to another trailer and got the same message Trailer brakes turned off. that trailer is working fine for the person using it and is having no problems with the brakes. If I try to adjust the gain on the brakes then I get an error message "trailer brakes turned Off" not sure what going on here, hopefully somebody knows because the dealership seems clueless.
    Thanks again for any suggestions.
  2. Jul 28, 2019 at 6:01 PM
    sbxx312
    sbxx312 New Member
    2018 Tundra TRD Sport
    There's a TSB for your factory brake controller. Hopefully the update fixes your problem.
    mountainpete likes this.
  3. Jul 28, 2019 at 6:43 PM
    ghengis
    mike
    2018 toyota tundra
    I just took it in on july 25th, 2019 and they did the "el1904 reprogrammed ECU (trailer brake controller ECU)" and it did not change anything.
    Unlike most posts I have found on the controller, Mine does not show trailer disconnected, no error code. It just says "trailer brakes turned off" and they are not intermitent, they just do not come on at all.
  4. Jul 28, 2019 at 6:49 PM
    koditten
    koditten New Member
    Are the trailer lights LED's. They might be drawing so few amps the ECU does not recognize them as being present.
  5. Jul 28, 2019 at 6:56 PM
    ghengis
    mike
    2018 toyota tundra
    Yes they are LED,s and they are working fine all the lights work great. The truck is recognizing the trailer hooked up. And no error codes. It just says "trailer brakes turned off" and of course the brakes do not activate or work.
  6. Jul 28, 2019 at 7:00 PM
    ghengis
    mike
    2018 toyota tundra
    Also everything did work when first used in August of 2018, Brakes, lights no issues.
  7. Jul 28, 2019 at 7:00 PM
    koditten
    koditten New Member
    When you step on the brakes, do the trailer brake lights brighten?
  8. Jul 28, 2019 at 7:02 PM
    koditten
    koditten New Member
    Can you try it with another trailer?
  9. Jul 28, 2019 at 7:02 PM
    ghengis
    mike
    2018 toyota tundra
    Yea, they do. You can definetly see the difference between driving lights and brakes.
  10. Jul 28, 2019 at 7:04 PM
    ghengis
    mike
    2018 toyota tundra
    I did try another trailer same thing all the lights worked fine, but still said "trailer brakes Turned off" ( there was a construction crew across the street from me that let me plug into there trailer that was working for them)
  11. Jul 28, 2019 at 7:13 PM
    ghengis
    mike
    2018 toyota tundra
    this was also after the appointment at the dealership on the 25th of July after they did the update. That I tryed the other trailer.
  12. Jul 29, 2019 at 5:50 PM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    Hooked up my boat trailer today for the first time on my 2019 Tundra. The truck said “no trailer” when trying to adjust the brake controller. It let me adjust the gain but nothing.
  13. Jul 29, 2019 at 7:46 PM
    ghengis
    mike
    2018 toyota tundra
    Yea mine will not let me even attempt to adjust the gain, it just sends up error code "Trailer Brakes Turned Off" when I push the gain buttons.
  14. Aug 3, 2019 at 11:25 PM
    ghengis
    mike
    2018 toyota tundra
    purchased a tekonsha 90250 prodigy which is a proportional brake controller which runs the brakes itself. the trailer brakes work good with this controller. So it does appear to be something wrong on the toyota end, but they still claim there is nothing wrong with the trailer brake in the truck. not sure what to do at this point. Seems a little crazy to spend over $40,000 for a truck to pull a trailer, and the have the trailer brake controller not work?
    koditten likes this.
  15. Aug 3, 2019 at 11:40 PM
    Twinky
    07 double cab work horse
    Is the OEM trailer brake an individual component, or is it integrated?
  16. Aug 3, 2019 at 11:44 PM
    ghengis
    mike
    2018 toyota tundra
    It's integrated. All 2018 tundras have them.
  17. Aug 3, 2019 at 11:45 PM
    ghengis
    mike
    2018 toyota tundra
    Built into dash and connected to on board computer display.
  18. Aug 4, 2019 at 1:25 AM
    Twinky
    That is disappointing to hear then. If it was the standalone component like my 07 has its a little easier to accept getting a new unit.
    Sorry to hear.
    Your new unit is working well for you at least?
  19. Aug 4, 2019 at 7:02 AM
    sbxx312
    sbxx312 New Member
  20. Aug 4, 2019 at 9:29 AM
    ghengis
    mike
    2018 toyota tundra
    Yes, the new unit works great.
    Sbxx312, I am not getting the trailer disconnected message as others were, but the thread you posted I had not seen. I will probably order one of those connectors, considering how inexpensive they are, just to see if it fixes my problem also.
    Thanks, mike ( I will post again once it arrives and I have a chance to try it.)
    NewImprovedRon likes this.
  21. Sep 22, 2019 at 6:08 PM
    Leoromero15
    Leoromero15 New Member
    2019 CM tundra limited
    @ghengis where you able to figure out a solution, I have 2019 that started doing the same thing. It worked the first time I towed my trailer but now I’m just getting that trailer brake controller off message.
  22. Sep 23, 2019 at 9:23 AM
    ghengis
    mike
    2018 toyota tundra
    No fix yet other than the external brake controller I have been using. But I have still not tried the fix sbxx312 had mentioned a couple of posts back yet. You would really think this should be something toyota would figure out though.
  23. Sep 23, 2019 at 9:31 AM
    ghengis
    mike
    2018 toyota tundra
    Is yours doing the same thing with the trailer showing in dash as hooked up, but just says trailer brakes turned off?
  24. Feb 29, 2020 at 5:12 PM
    Mickh26
    Mickh26 New Member
    Michael
    2018 Tundra XP
    Leveling kit
    I had this same issue today with my 2018 Tundra - Trailer Brake Control OFF. All of the lights, signals, etc worked, but not brakes. I took the truck to the dealership and they updated software, etc. but still could not get the brakes to work. I still had the message and would get the error message if I manually adjusted the gain. Turns out the brake controller had been turned off in the vehicle settings menu. I had a software update done for the front sensor back in December. I am not sure if this reset it back to the factory off position or not. Anyway. To turn the controller back on, scroll over to the Gear icon all the way to the right on the center display menu using the steering wheel buttons, down to vehicle settings and then to trailer type - Electric 0-4999lbs, 5000+, etc and then choosing your trailer type. In my case the electric 0-4999 lbs. option. This fixed my issues and my brakes are back working. I hope this helps someone. Seems so easy after the fact, but just figuring out that it had been turned off was the big hassle. Seems this stumped the dealership too.
  25. May 9, 2020 at 5:28 PM
    1stTundra18
    1stTundra18 New Member
    2018 Tundra SR5 Crewmax 4x4
    Your a GENIUS!! I'm sitting her at my storage site about to take the camper and had the same issue. Easy fix! Thanks!
    Ruggybuggy likes this.
  26. Jan 25, 2022 at 8:51 AM
    Squirrel2021
    Squirrel2021 New Member
    Ross
    2019 Tundra Crewmax
    OH my GOD! I’m going to try this! Likely the dealer did this accidentally when the head gasket was replaced. Will check it now!
  27. Mar 19, 2022 at 8:44 AM
    Dmcdelite
    Dmcdelite New Member
    New Port Richey Fl
    '21 Calvary Blue TRD Sport Tundra 4x4
    3/2 Rough Country Lift Fuel Assault Wheels Kenda Kleaver RT Tires Tyger Bull Bar Mictuning Rocklights and Interior Leds Clazzio Leather Seat Covers
    This is what worked for me.. I think you may need to turn it on after every battery disconnect!
  28. Sep 4, 2023 at 10:45 AM
    pro2amendment
    pro2amendment Member
    Indiana
    2018 Tundra: 5.7L Flex, MGM Gray DC, Offroad pkg
    Bullet liner
    Thank God!!!! Worked for me. I kept calling dealers to see if anyone was familiar w the TSB and no one was or said would look into and not call back.
    Mine also was brakes off message. New trailer back in April and worked fine until trip in august. Not sure why the brake controller reset to off but solved a lot of frustration
  29. Sep 19, 2023 at 5:18 PM
    Arculus
    Arculus New Member
    I'm so glad I found this thread!
    Special thank you to Mickh26.
    You totally saved my day!
    I had just rented a travel trailer for two weeks and right after I picked it up the electric brakes wouldn't work. I sat on the side of the road totally bummed out cause I would've had to return it and cancel my trip. No way I'm taking a big rv trailer on the highway with no brakes.
    Anyway, I found this thread and within 2 minutes I had the brakes working like a charm. ✌️
