Medic's Transformer
Discussion in '2.5 Gen Builds (2014-2021)' started by Medic, May 4, 2017.
  1. May 4, 2017 at 9:15 PM
    Medic
    Medic [OP] New Member
    Ontario, Canada
    2014 Limited Crew Max
    I switched from a 2016 Tundra DC TRD in Super White to a 2014 Tundra Crewmax Limited with Tech package at the end of March.
    I had a lot of up grades planned for my previous truck that I had not installed due to either life being busy or the parts were ordered but had not arrived yet.
    1. One of the first mods was Salex OD organizers.
    - ordered from Amazon
    These organizers fit great and are much better design than the Toyota offered version. Should be a standard option on all trucks.
    2. Installed under hood LED lights from MattGecko
    Easy to install with great instructions and customer service.
    3. I also ordered the bed LED kit as well.
    4. Had a 30" single row light bar ordered for inside the hood bulge but after realizing how much cutting was involved, and the fact that cutting would open the hood up to salt/ debris etc , I decided to mount the light bar behind the grill.
    - Light bar ordered from Amazon
    5 & 6. I swapped out my limited grill with a stock SR5 grill that I changed the surround and the hood bulge to colour matched Super White.
    - ordered the hood Bulge from dealership and found the grill surround on Kijiji
    7. Light bar is being controlled by the Trigger system. Comes with 4 accessory plug ins, wireless remote and ability to control with the use of your cell phone.
    So far this system works great and don't have to run any wires into the cab.
    8. Had ordered a set of Spyders with LED bulbs for my last truck but decided to change rides before installing them.
    - Spyders and LED bulbs were ordered from nolimitautomotivesolutions.com
    9. While the headlights were out, decide to Plastic-dip the chrome bumpers as well.
    - bought the Plasti-dip from dipyourwhip.com
    10. Also changed the fog bulbs to LED to match the Spyders.
    11. Also did the anytime Fog light mod during the lighting upgrades.
    - instructions for this can be found in the lighting section
    12. Re-installed the Hypertech Interceptor.
    - found used from another Tundra owner in British Columbia
    13. Received the SDHQ ABS sensor guards.
    After damaging a sensor two years ago,these are cheap protection in comparison.
    And yes, there as quick to install as everyone else has stated. About 15 minutes. 10 mm wrench/ socket (unless yours is missing) and a 7 mm Allen key.
    - ordered direct from SDHQ
    14. Rear TRD sway bar.
    Installation was straight forward. I have noticed less body roll and more positive handling since the install but have not really tested it yet.
    - ordered from my Local Dealership
    15. Husky floor liners.
    - ordered from 4wheelparts.com
    16 & 17. Tires and Rims
    - BFG AT KO2 in 275/60r20 ordered from local Canadian Tire store
    - Fuel Vapor 20 x 9. +35mm offset
    This by far is my favourite mod yet. Super happy with look of the rims. Decided on these for a couple of reasons. Offset is high to keep tire in and avoid excess stone chips (this truck is my daily driver). Second was hadn't seen any other trucks with them installed and third was they are rated against salt and calcium that we get in the winter.
    18. Debadged all iForce, Limited, Tundra and 4x4 badges.
    This mod was free except for a little fishing line, elbow grease and time.
    19. Levelling suspension installed.
    Front- Bilstein 6112 on second highest setting
    - had the new spring painted TRD red
    Back - Bilstein 5100
    20. AMP Research Bed step
    This is nice feature for getting in and out with the tailgate down. Moves easily into position and quickly folds up near the bumper.
    - found on Kijiji
    21. Stubby Antenna
    TC Bunny carbon fibre antenna
    No noticeable loss of channels/ stations
    - Amazon.ca
    Having trouble uploading pictures tonight, will try again tomorrow. - Have since solved this problem.
  2. May 4, 2017 at 9:23 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Thats a weenie excuse for being lazy ;)
    Law323, zcarpenter92 and T-Rex266 like this.
  3. May 4, 2017 at 9:24 PM
    Medic
    Ontario, Canada
    Have tried for the past hour to get pictures to load with all the changes. Was working fine earlier.
    831Tun and Eclipsed & Floating like this.
  4. May 4, 2017 at 9:38 PM
    Lmk if u need help uploading
  5. May 4, 2017 at 9:40 PM
    Medic
    Ontario, Canada
    Thanks,it is probably at my end. Router has been having issues. Text seems to be fine but pictures take more bandwidth. I am on satellite internet.
  6. May 4, 2017 at 9:41 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    :worthless: Just kidding. I'm looking forward to seeing the new ride.
    Eclipsed & Floating likes this.
  7. May 4, 2017 at 9:42 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Do you guys have point to point Internet up there? aka microwave internet?
  8. May 4, 2017 at 9:43 PM
    Medic
    Ontario, Canada
    Satellite based, Explornet
  9. May 4, 2017 at 9:44 PM
    Eclipsed & Floating
    Voluptuous Whitey
    I have microwave tower shots. Pretty fast and no data cap. Does Ontario have it?
  10. May 4, 2017 at 9:50 PM
    Try PM'g me the pix and I'll get them up for u. Should be less BW that way...I think.
  11. May 5, 2017 at 2:43 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I wanna see....
  12. May 5, 2017 at 8:13 AM
    Tundra Pirate
    Tundra Pirate Bamf
    Kelly
    Stanley, NC
    2014 Super White Tundra Crewmax 4x4 Limited
    Bilsteins 5100 Leveled Method NV Machine KO2
    Nice storm trooper color!!
    Medic[OP] likes this.
  13. May 6, 2017 at 6:29 AM
    Medic
    Ontario, Canada
    Updated the build. Still have more pictures to upload. Also plan on including part numbers. All vendors are included as these are the best prices I found for Canadians
  14. May 6, 2017 at 8:23 AM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    Great posts man!
    I liked you already because you're from Ontario, then I saw that we both have the same socket set... well done sir, well done.
    :fistbump:
  15. May 6, 2017 at 9:16 AM
    Darth Tundra
    Curt
    17 CM TRD Black
    NICE TRUCK!!!...AND AWESOME MODS BRO !!!!
    Medic[QUOTED][OP] likes this.
  16. May 6, 2017 at 3:31 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Nice pics and descriptions. Love the mods you've done so far. Looks great!!
  17. May 6, 2017 at 6:07 PM
    Medic
    Ontario, Canada
    Thanks
  18. May 6, 2017 at 6:09 PM
    Medic
    Ontario, Canada
    Thanks for the support.
  19. May 6, 2017 at 6:09 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Which bulbs did you put in t h e Spyders? Are they significantly more output?
  20. May 6, 2017 at 6:13 PM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    Truck looks great. Less chrome the better
    How did you damage you abs sensor...if u know??
  21. May 6, 2017 at 6:16 PM
    Medic
    Ontario, Canada
    I used XKGlow Fanless LEDs in both the headlights and fogs. As for the output, I didn't have the bulbs that came with the Spyders but I had read from numerous sources that the standard bulbs were less than optimal so I ordered upgrades at the same time. Hope this helps.
  22. May 6, 2017 at 6:20 PM
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    Awesome!! I'm on the fence for a crew after all the money i dumped into my current truck
  23. May 6, 2017 at 6:25 PM
    Medic
    Ontario, Canada
    To access the areas we deer hunt, we used old logging roads. Usually they are rough but we had a lot of rain which led to numerous mud holes. A large tree limb that was submerged broke the sensor on my truck.
    R0CKETMAN[QUOTED] likes this.
  24. May 6, 2017 at 6:27 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    CREW !!!...CREW...!!!.....CREW !!!...:)
    GNTundra likes this.
  25. May 6, 2017 at 6:56 PM
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    WIFE....WIFE....WIFE!!!! Lol
  26. May 6, 2017 at 6:57 PM
    Krezz
    Kevin
    More room for the family... tell the wife. :p
  27. May 6, 2017 at 6:59 PM
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    Trust me I've been there done that. I'm just gonna hold off for the 2020 and see what these bad boys will look like on the new revamp
    GNTundra and Krezz like this.
  28. May 6, 2017 at 7:01 PM
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    @Medic do you recall the spyder bulb size I think I may go led and sell my DDM hid kit
  29. May 6, 2017 at 8:12 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    LOL.....I REMEMBER THOSE DAYS...MARRIED TWICE..SINGLE NOW...
  30. May 11, 2017 at 6:47 PM
    Medic
    Ontario, Canada
    Updated mods list
