Map lights flickering..
Discussion in 'Lighting' started by RollTide82, Mar 19, 2020.
  1. Mar 19, 2020 at 7:00 PM
    RollTide82
    RollTide82 [OP] New Member
    Michael
    2019 Tundra 4x4
    I put some Amazon map light LEDs in some time back. They sort of flicker at times while on. It almost seems like the ones on the dome light are fine...just the maps by the rear view do this. Anyone else have this problem before I go buy a more expensive set?
  2. Mar 19, 2020 at 7:17 PM
    zlaneb
    zlaneb New Member
    Austin, TX
    Same problem, but I bought directly from a vendor that advertises on the forum. Driving me crazy, ready to go back to the 'normal' lights.
  3. Mar 19, 2020 at 7:23 PM
    RollTide82
    Michael
    2019 Tundra 4x4
    Glad I am not the only one...about gives me a seizure trying to get my act together when I get in the truck at 5 am ....
  4. Mar 21, 2020 at 6:24 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2017 Sequoia LTD
    Rx350 retrofitted, Morimoto Led fogs. interior and exterior leds swap. TRD drop in filter. Carbon filter delete. Led DRL panels. TRD Shift knob.
    I feel like they do that when they are dying
  5. Mar 21, 2020 at 6:30 AM
    RollTide82
    Michael
    2019 Tundra 4x4
    I bought like a 10 pack and they all do it. Even turned the bulb 180 degrees. I'll just buy more expensive ones if we survive the damn corona
  6. Mar 21, 2020 at 6:30 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Its because of the dimming feature on our trucks. I had some that flickered and some that don't, I think its hit or miss. Yet higher quality should work better.
    Rocko9999 and NewImprovedRon like this.
  7. Mar 21, 2020 at 6:42 AM
    BrandonL812
    Brandon
    2017 Sequoia LTD
    I had the fyreflies leds in them and only 1 flickers. Switch that bulb to the rear (sequoia) and no nore issue since. The lastfit bulbs also works great.
  8. Nov 17, 2020 at 10:40 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    Anyone tried Sylvania bulbs for this? My map dome light also flickers, always the passenger side, tried changing the bulb, but I do think its just because they're cheap Amazon bulbs.
  9. Nov 17, 2020 at 10:48 AM
    RollTide82
    Michael
    2019 Tundra 4x4
    I ordered vleds...problem solved
    joseph_womack likes this.
  10. Nov 17, 2020 at 10:49 AM
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    I ordered vleds now I have a buzzing sound coming from the mapp light when door opens
  11. Nov 17, 2020 at 10:51 AM
    joseph_womack
    Joe
    Louisiana
    Thanks! I think I'm going to test out the Sylvania
  12. Nov 17, 2020 at 10:51 AM
    joseph_womack
    Joe
    Louisiana
    You tried contacting VLED?
  13. Nov 17, 2020 at 10:54 AM
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    Not yet
  14. Nov 17, 2020 at 11:38 AM
    BrandonL812
    Brandon
    2017 Sequoia LTD
    Try flipping the vled bulb 180. See if it still buzz.
  15. Feb 3, 2022 at 8:51 AM
    Rocko9999
    Rocko9999 New Member
    Did you ever try these? Do they flicker?
    joseph_womack[QUOTED] likes this.
  16. Feb 4, 2022 at 7:23 PM
    joseph_womack
    Joe
    Louisiana
    yep! I've had them for quite awhile now, no flicker, they've worked great for the past couple months
    Rocko9999[QUOTED] likes this.
