Map Light Out
Discussion in 'Lighting' started by Blankcheese, Sep 11, 2016.
  1. Sep 11, 2016 at 11:07 AM
    Blankcheese
    Blankcheese [OP] New Member
    Johnny
    '16 SR5 DC 4WD
    Replacing the interior bulbs with LED and now my left map light won't work with a new LED or the original bulb. The right one works fine. I figured they were on the same fuse, but wanted to confirm?
  2. Sep 11, 2016 at 11:08 AM
    Should be. Sure it's not a contact that got slightly bent?
  3. Sep 11, 2016 at 11:12 AM
    Blankcheese
    Johnny
    '16 SR5 DC 4WD
    I'm going with bent contact, I looked on the interior fuse panel picture I found on here, and I didn't see any reference to map light at all.
  4. Sep 11, 2016 at 11:12 AM
    That fuse is under the hood
  5. Sep 11, 2016 at 11:13 AM
    Blankcheese
    Johnny
    '16 SR5 DC 4WD
    I bought a set of LEDs off Amazon for about $20 and so far this conversion wasn't really worth it. I like the color of the LED light but the added brightness isn't as dramatic as I thought it would be.
  6. Sep 11, 2016 at 11:14 AM
    Blankcheese
    Johnny
    '16 SR5 DC 4WD
    If the map lights are on the dome circuit, I have a socket issue
  7. Sep 11, 2016 at 11:53 AM
    vidman
    vidman New Member
    Rick
    Massachusetts
    I have the same problem with my drivers side socket. still playing with it. the copper tangs that the bulb pops into are real loose and its really starting to piss me off.............but i will feel better soon..:cheers:
    NewImprovedRon likes this.
  8. Sep 11, 2016 at 1:18 PM
    14limited
    14limited Diehard Florida State fan
    Matthew
    14 limited 4wd
    3" OME magnum front bumper and steps spyder headlights MB TKO wheels
    Guy on Facebook had awesome LEDs
    AnonVet and NewImprovedRon like this.
  9. Sep 11, 2016 at 1:35 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    My dome lights go off sometimes (not often) best I can guess is sometimes the reflector opening isn't big enough and messes with the connection by jamming down the LED.
    I need to Dremel the openings a little bit haven't gotten around to it yet.
  10. Sep 11, 2016 at 1:36 PM
    vidman
    vidman New Member
    Rick
    Massachusetts
    I installed some nasty bright LEDs in my Taco and i had to take them out for ones that were a little less potent. Too much light in a small truck..
  11. Sep 11, 2016 at 2:08 PM
    Blankcheese
    Johnny
    '16 SR5 DC 4WD
    I'm trying to figure out what actually turns the light on? On the left map light, I made the mistake of asking the metal reflector out to get to the bulb. Well you can guess what it looks like after putting in back in again...
  12. Sep 11, 2016 at 2:19 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I had the same problem. I thought I was screwed, but just bent the metal reflector back into place after putting it back in. Seemed to do the trick
    It's a pressure switch located furthest from the windshield. From what I could gather, it's either a prong connected to the light cover or a flat surface that triggers the switch.
    I had broken the light cover hinge so I didn't want to push my luck by playing around with it any more than needed
    Maybe try rotating the bulb? Might have the polarities switched? Had to do that when putting in mine.
    Don't know if that'll help but that's the extent of my knowledge. Good luck John!
  13. Sep 11, 2016 at 4:02 PM
    Blankcheese
    Johnny
    '16 SR5 DC 4WD
    I mangled the one metal piece pretty good and broke a tab. I tried the LED both ways, a second LED and the original bulb. Thinking prongs now, need to revisit it when I have some more patience. Thanks for the info its greatly appreciated!
    Law323[QUOTED] likes this.
  14. Sep 11, 2016 at 4:16 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    No problem brother. Sorry it wasn't much help!
  15. Sep 15, 2016 at 9:39 PM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    I just installed an $11 pack of LED'S from Amazon and they are pretty badass. Bright as hell and have had a few folks stop at my house and ask about them. They shit when I say 11 bucks from amazon lol.
  16. Sep 16, 2016 at 9:10 AM
    PMG
    PMG New Member
    Have link?
    PMG
