M/T Tire Question
Discussion in '2nd Gen Tundras (2007-2013)' started by Yodder J, Dec 10, 2019.
  1. Dec 10, 2019 at 12:33 PM
    Yodder J
    Yodder J [OP] New Member
    Northwest Arkansas
    2011 Silver Tundra SR5 4WD DC
    DAP Tune, Truxedo ProX15 bed cover, WildPeak AT3s
    What happens if you have to drive fast, on a highway for example (maybe your wife is pregnant and you are rushing her to the hospital) but you have M/T tires on your truck, will they explode if you get your truck up over a certain speed? Will they become unstable if you get them up over a certain speed? Just curious...
    Thanks for the input
  2. Dec 10, 2019 at 12:48 PM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
  3. Dec 10, 2019 at 12:52 PM
    KMG
    KMG New Member
    Kevin
    Yacolt, WA
    2018 White Tundra Limited DC 4x4 TRD
    BFG KO2s, TRD Rear Sway Bar, Firestone RideRite Air Bags, B&W Gooseneck Hitch, Trail Ridge Extendable Towing Mirrors
    Check your tire's speed rating. Remember that is the max your tire can safely travel under the very best conditions. It doesn't factor in your truck, modifications, road conditions, etc. Be safe.
    L 75 mph 120 km/h
    M 81 mph 130 km/h
    N 87 mph 140 km/h
    P 93 mph 150 km/h
    Q 99 mph 160 km/h
    R 106 mph 170 km/h
    S 112 mph 180 km/h
    T 118 mph 190 km/h
    U 124 mph 200 km/h
    H 130 mph 210 km/h
    V 149 mph 240 km/h
    W 168 mph 270 km/h
    Y 186 mph 300 km/h
    14burrito likes this.
  4. Dec 10, 2019 at 12:56 PM
    Aerindel
    Aerindel New Member
    Montana
  5. Dec 10, 2019 at 1:07 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    This will happen
  6. Dec 10, 2019 at 1:08 PM
    Yodder J
    Northwest Arkansas
    I'm being serious. M/T tires are specifically designed for off road performance but how do they react when you have to push them in a real life emergency scenario on the roads? I know that most, if not all A/T tires can at least be somewhat competent at high speeds on pathed/apshalt or cement roads, I'm just wondering about M/T tires, that is, how will they react when pushed on a highway, will they be too dangerous to handle, will they literally fall apart?
  7. Dec 10, 2019 at 1:11 PM
    Yodder J
    Northwest Arkansas
    Ok, I guessing that most M/T tires are going to be L rated
  8. Dec 10, 2019 at 1:14 PM
    Yodder J
    Northwest Arkansas
    Yep, that's kind of what I imagine will happen if you try and do 120mph with your M/T tires
  9. Dec 10, 2019 at 1:25 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    I don’t think u can even get to 120 on the tundra. They have a cut off unless u removed it with a tuner or tune.
    jewsNbrews and TheBeast like this.
  10. Dec 10, 2019 at 1:33 PM
    Yodder J
    Northwest Arkansas
    Fair enough but I'm living in truck central USA and I'm sure that many of you all see more trucks and SUVs on the highways than sedans/coups/wagons and many, many of these trucks and SUVs are wearing M/T tires and I know that I've seen some real speed demons driving trucks or Jeeps or whatever going over 80 mph.
    And I'm considering putting some M/Ts on my truck as I have a farm that gets muddy and I don't want to get stuck and having an M/T tire would really help. That said, I'm not going to buy tires that might explode on me if I have to push the truck in some kind of emergency. It's a legitimate question.
    Do the real expensive M/T tires have a higher speed rating, I'm guessing that yes, they do and that is probably one of the reasons they are more expensive
  11. Dec 10, 2019 at 1:34 PM
    MrMax
    MrMax Introvertigo Eximious Geargasm
    Rob
    Eastern Iowa, USA
    2011 Crewmax S/C TRD Rock Warrior
    The guys here already informed you that your tire's have a speed rating(Check It!). Keep in mind the speed and weight ratings for the tire are at maximum pressure rated for the tire. If you exceed the speed and/or weight rating you do so at your own risk, and yes tires do blow and or tear themselves apart under these circumstances. Other than that they are going to HOOOOOOWWWWWWLLLL lika a motherfu@#$%r rolling down the road.
    jewsNbrews likes this.
  12. Dec 10, 2019 at 1:48 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Guessing vs reality....
  13. Dec 10, 2019 at 1:54 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Few more, all Q
    Yodder J[OP] likes this.
