Lug Nut Question
Discussion in 'Wheels & Tires' started by BreadGuy, Apr 2, 2022.
  1. Apr 2, 2022 at 5:20 PM
    BreadGuy
    BreadGuy [OP] New Member
    I just ordered a used set of used TRD wheels from ebay and lug nuts are not included. I was just wondering of the lug nuts from my old steeleies are fine to use. Any help would be appreciated.
  2. Apr 2, 2022 at 5:25 PM
    SouthWestGA
    SouthWestGA New Member
    Steel lugs are only compatible with steel wheels nothing else
  3. Apr 2, 2022 at 5:27 PM
    Blang805
    Blang805 New Member
    Central Coast California
    2010 CrewMax Platinum 4x4
    Build in Signature
    Toyotoholic and ShreveportTSS like this.
  4. Apr 2, 2022 at 6:33 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    ^ this. They are this type. Do not use beveled acorn style. Need to be lug centric 2F09CF1B-0ADD-4C49-8F88-1FBCF9A24F8E.jpg
    WVI likes this.
  5. Apr 3, 2022 at 3:24 PM
    captainnemojr
    captainnemojr New Member
    2024 Tundra Platinum HV 4x4 TRD OR
    I'm about to swap my 1794 20" with TRD Off-Road 18" wheels. Would my lug nuts work?
  6. Apr 3, 2022 at 4:02 PM
    jhardy1979
    jhardy1979 New Member
    Justin
    MGM 2015 Tundra Crewmax Limited 4x4
    I believe those both use the same style.
    captainnemojr[QUOTED] likes this.
  7. Apr 21, 2022 at 2:36 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    All of The OEM lug nuts should be the same, its only when you venture out into aftermarket non OEM you'll run into different seat styles. Remember the OEM alloy lug nuts are made to work the OEM steelie spare.
