Lubricate Propeller Shaft (4wd)
Discussion in 'General Tundra Discussion' started by bob_dobalina, Aug 4, 2022.
  1. Aug 4, 2022 at 12:35 PM
    bob_dobalina
    bob_dobalina [OP] New Member
    Trying to do my own maintenance and found this "Lubricate Propeller Shaft (4wd)" every 5,000 miles, which I've never done.
    After much digging, I found a diagram of lubrication points stating:
    Grease Grade:
    Propeller shaft (Except double-cardan joint): Lithium base chasis grease NLGI No. 2
    Double-cardan joint: Molybdenum disulphide lithium base chasis grease NLG No. 2.
    Here's what I found at my local shop will this work?
    https://www.oreillyauto.com/detail/c/synpower/valvoline-14-1-ounce-full-synthetic-multi-purpose-grease/val2/985
    https://www.oreillyauto.com/detail/c/valvoline/valvoline-14-1-ounce-moly-fortified-multi-purpose-grease/val0/633
    Do I need to use 2? If you just used one, which one? I hate grease guns I always make a mess, and I've never had much luck swapping out canisters so I'd probably need a gun for each one?
  2. Aug 4, 2022 at 12:41 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    What year truck? Sounds like a first gen... I always just use whatever grease I have on hand. Grease is grease in my opinion. I use the same grease for all the zerks
  3. Aug 4, 2022 at 12:44 PM
    bob_dobalina
    Sorry, forgot to mention 2016 4WD
  4. Aug 4, 2022 at 12:51 PM
    AZBoatHauler
    So.Arizona
    I use Lucas red n tacky no 2 for everything and nothing has fallen apart yet. I also only do this annually of every 15k miles because if you add grease every 5k it’ll sling everywhere eventually IME.
  5. Aug 4, 2022 at 12:54 PM
    bob_dobalina
    so maybe the non-moly general purpose valvoline I linked would be a good option?
  6. Aug 4, 2022 at 1:39 PM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    There's a spec on page 526 of your owners manual - Lithium base chassis grease, NLGI No.2. Anything that meets this spec is good. I use Mobil 1 Synthetic Grease.
    bob_dobalina[OP] likes this.
  7. Sep 12, 2023 at 6:07 PM
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
  8. Jan 23, 2024 at 6:06 PM
    rpmcgarvey
    rpmcgarvey New Member
    2020 Blue CrewMax Tundra TRD
    I have 2020 tundra crew max 4x4. I am at 20k miles. Bought it with 10k miles. I keep seeing lubricating the propeller drive shaft. However I check and do not see any zerks. Is the propeller drive shaft sealed on 2020 generation?
  9. Mar 20, 2025 at 3:00 PM
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Same question. Is my 2019 sealed???
  10. Apr 12, 2025 at 6:49 AM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    After a certain year they are sealed, I think it’s 2017? I know my 18 has sealed u joints.
