Lowering my front by an inch
Discussion in 'Suspension' started by Chuckm, Aug 18, 2018.
  1. Aug 18, 2018 at 11:50 AM
    Chuckm
    Chuckm [OP] New Member
    Charles
    2015 Toyota Tundra TRD Pro
    None
    hi all, I want to lower the front of my Tundra TRD PRO by an inch, has anyone here done this?
  2. Aug 18, 2018 at 12:50 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I've never done it, but I've lowered older Honda Civics by cutting the coil springs a bit. I wouldn't do that to your high-dollar Pro suspension, though. One option would be to replace the fronts with a different coilover setup that attains the ride height you want. You could also try replacing the Pro coil springs with shorter length ones with the same spring rate as the Pros, but I don't know who would offer them. Eibach, maybe?
  3. Aug 18, 2018 at 12:50 PM
    Blueknights75
    Ron
    Clayton, NC
    Why????
    reaper3030 likes this.
  4. Aug 18, 2018 at 1:12 PM
    Chuckm
    Charles
    None
    I don't like the way it looks when the rear hangs low, since I actually bought my truck for traveling, camping, snowboarding, and long distance road trips, which is alway pack in the back. Also im ordering my custom A.R.E. Truck campershell, which already weighs around 200lbs plus all my gears.
  5. Aug 18, 2018 at 1:14 PM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    Have you looked into airbags or shackles to raise the rear instead?
    Grumpy Uncle and 1UPPER like this.
  6. Aug 18, 2018 at 1:23 PM
    Grumpy Uncle
    Pat
    CO
    2016 Black CM Tundra TRD Off Road
    Welcome from CO.
    Get airbags
    Or
    Add a leaf
    Or
    OME Dakkar leaf packs
    My topper weighs in at around 350lbs plus another 100lbs or so in the bed
    Blueknights75 likes this.
  7. Aug 18, 2018 at 1:30 PM
    Chuckm
    Charles
    None
    I mainly just wanted to see if the bilstein shock/coil is adjustable, im guessing the answer is not. I don't want to mess with additional parts since I bought the bumper to bumper warranty.
  8. Aug 18, 2018 at 2:11 PM
    equin
    Ed
    DFW, TX
    As far as I know, the Pro coilovers aren't adjustable. Given your needs, though, I'd go with air bags or an add-a-leaf in the back as others suggested.
  9. Aug 18, 2018 at 2:16 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    They aren't adjustable. It would be easier and cheaper to raise the back an inch or so. I agree with you, I don't like the "level" look of the Pro, IMO is looks nose high. Look into an add a leaf since you're getting a cap, maybe air bags but they can be a hassle. Or maybe lift shackles. I think add a leaf is you best bet since you're adding the bed cap
  10. Aug 18, 2018 at 2:52 PM
    Professional Hand Model
    Hand Protectors
    Sell and buy a 1st Gen! More pay load capacity and you’ll never sit with your ass dragging.
