Lower control arm R&R. WIll the iner sleeve give me issues?
Discussion in '2nd Gen Tundras (2007-2013)' started by ftmyerstundra, May 12, 2022.
  1. May 12, 2022 at 5:07 AM
    ftmyerstundra
    ftmyerstundra [OP] New Member
    Gary
    2007 Tundra Crew Limited
    absolutely none
    Truck is an 07 but there is no corrosion underneath as it is a southern truck. Will I have issues removing the inner sleeves after I remove the cam bolts? Is there a trick to getting the sleeves out or will I need a special tool? Please let me know if you have done this.
    Thanks
    Gary
  2. May 13, 2022 at 3:02 AM
    ftmyerstundra
    Gary
    absolutely none
    Nobody? I thought this repair would be a little more common. I dont really want to just change the balljoints as the bushings are now 14 years old and I am sure they are ready to be replaced also.
  3. May 13, 2022 at 4:38 AM
    ftmyerstundra
    Gary
    absolutely none
    I understand and thank you but my concern is getting the cam bolt sleeve out of the bushings to release the back of the control arms. I am hearing that they will seize so I am hoping to get someone's experience on this.
  4. May 13, 2022 at 4:52 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    :worthless:
    ...but seriously. Are you talking about the cam bolts seizing within the bushings?
    Trying to understand (or remember) this sleve you refer to
  5. May 13, 2022 at 6:15 AM
    ftmyerstundra
    Gary
    absolutely none
    Yeah, just wondering if that is a certainty or my results may differ. Also, if they dont seize is it best to buy new or reuse. Just kinda wondering what to expect.
  6. May 13, 2022 at 6:16 AM
    ftmyerstundra
    Gary
    absolutely none
    Thank you sir. I guess I need to make a youtube video as there doesnt seem to be one.
  7. May 13, 2022 at 6:27 AM
    Forcefed
    Forcefed New Member
    2007 Tundra Limited
    6 inch lift, ADS suspension, Alcan custom rear springs, 46 gallon metal gas tank, Full Line-x body, Wheels with 35's, Smittybilt bumpers front and rear, 10k warn winch, custom rack.
    So I had the issue with one cam sleeve stuck in the control arm. I tried to heat it up and nothing. I ended up just cutting it out. I was replacing the bushings on the control arm anyway so I didn't care. Went to Toyota and ordered a new cam sleeve. I live in the New Mexico but I take the truck all over and one side was fine and my driver side was stuck. When I started cutting all I saw was rust, it was bad the hole thing was rusted. It happens, I have seen post of people up north having a hell of a time trying to remove the lower control arm due to this issue.
  8. May 13, 2022 at 7:25 AM
    COTundie
    Trey
    Pretty things
    Yikes. I hope OP's are friendly.
    When I replaced my coilovers there was zero issue with the cam bolts... And thank you. I DO remember the sleeve which has the cam for the opposite side from the bolt now.
    If yours don't appear to be corroded, I doubt they will give you much trouble.
    FYI, I have not heard good things about aftermarket cam kits, should you have to have to cut things apart.
    This kinda makes me feel like I should have used a bit of anti-seize when I reassembled mine. Oh well.
  9. May 13, 2022 at 7:36 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I just did mine. Socal truck, the sleeve came out easy, i was grateful
  10. May 13, 2022 at 8:43 AM
    ftmyerstundra
    Gary
    absolutely none
    Thanks guys.
  11. May 13, 2022 at 8:52 AM
    SouthWestGA
    SouthWestGA New Member
    If you need cam hardware OEM is the best
    aftermarket won’t hold the torque specs
  12. May 13, 2022 at 9:31 AM
    ftmyerstundra
    Gary
    absolutely none
    Trying to find part numbers for all the cam bolt pieces is proving difficult but i will get it done.
  13. May 13, 2022 at 9:43 AM
    SouthWestGA
    I would call a helpful parts department and double check these numbers for your vehicle
    You’ll need 2 of each part
    1 for each side
    This is an old list I had for my 2nd Gen
  14. May 13, 2022 at 9:46 AM
    ftmyerstundra
    Gary
    absolutely none
    You are the man thank you sir.
  15. Jul 19, 2022 at 4:20 AM
    ftmyerstundra
    Gary
    absolutely none
    As info, started this yesterday. Passenger side came out without any issue at all. SHould have this side buttoned up today but my toque wrench doesnt go to 206lbs for the lower bolts. Also, is there a link to all the torque specs?
