Loses power after running for a while
Discussion in '2nd Gen Tundras (2007-2013)' started by Wayne Knight, May 10, 2019.
  1. May 10, 2019 at 8:03 AM
    Wayne Knight
    Wayne Knight [OP] New Member
    2007 Tundra
    2007 Tundra - Loses power after awhile.Let engine cool 10 minutes then is OK.Replaced both bank 02 sensors. Didn’t help. Any ideas?
  2. May 10, 2019 at 8:08 AM
    15whtrd
    15whtrd Mr. Blonde
    Any warning lights coming up? It could be anything, sounds like it’s going into limp mode.
  3. May 10, 2019 at 8:12 AM
    Wayne Knight
    2007 Tundra
    Yes. Engine light flashes like a strobe.Used Actron tester but shows no codes
  4. May 10, 2019 at 8:15 AM
    15whtrd
    15whtrd Mr. Blonde
    You would think a code would pop up. Can you get a hold of a better scanner? Also check the obvious. All the connections to the battery and grounds. Maybe it’s something really simple.
  5. May 10, 2019 at 8:15 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    Alternator?
  6. May 10, 2019 at 8:25 AM
    Wayne Knight
    2007 Tundra
    Battery connections good.
  7. May 10, 2019 at 2:51 PM
    Wayne Knight
    2007 Tundra
    Battery & Alternator ok. Engine light goes off after engine cools for 10 minutes & runs fine for about 10 miles
  8. May 10, 2019 at 3:53 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    If the CEL is flashing it is for a critical fault code. I'm thinking it might be a Toyota-specific fault that your scanner does not support. You need to get the code(s) read some other way to know where to go from here.
    15whtrd, Sas, TheBeast and 2 others like this.
  9. May 11, 2019 at 10:39 AM
    Wayne Knight
    2007 Tundra
    Will do,Thankyou
  10. May 11, 2019 at 10:41 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    What kind of fuel do you use?
  11. May 11, 2019 at 11:01 AM
    Professional Hand Model
    Hand Protectors
    Flashing like a strobe is a new one. In this to learn.
    15whtrd likes this.
  12. May 11, 2019 at 11:57 AM
    Wayne Knight
    2007 Tundra
    Alternator ok. Trying to find what is overheating causing lack of power.After 10 min of engine shut off everything ok.
  13. May 11, 2019 at 12:00 PM
    Wayne Knight
    2007 Tundra
    Another code tester on its way today
  14. May 12, 2019 at 7:42 AM
    Wayne Knight
    2007 Tundra
    Other tester showed 0 codes. Others suggested options varied. Since lack of power only occurs at high RPMs, 50 mph + might be catalytic converters.Ck for defective gas cap pressure build up. Since cruise control only works occasionally it might be defective.Might need a new fuel pump. ???????
