Loose tailgate cable
Discussion in '2.5 Gen Tundras (2014-2021)' started by WFD473, Dec 5, 2019.
  1. Dec 5, 2019 at 5:07 PM
    WFD473
    WFD473 [OP] Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    So I noticed yesterday when my tailgate is down the left side cable is tight and the right side is loose. Does anybody else have this issue? Is it an issue? Is there an adjustment to make them equally tight when it's down?
    Medic343 likes this.
  2. Dec 5, 2019 at 5:22 PM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    Mine is the same way, never thought much about it lol
    WFD473[OP] likes this.
  3. Dec 5, 2019 at 5:36 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    Mine is the same way...you just started something I didn't want to look further into. Thanks a lot! LOL
    WFD473[OP] and MAGDADDY like this.
  4. Dec 5, 2019 at 9:15 PM
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Lol, sorry fellas. My concern is whenever there's any weight on the tailgate, it's only being supported by the one cable. Not sure if that's a long term safety issue or not.
  5. Jul 10, 2020 at 11:08 AM
    Doctor Flex
    Doctor Flex Just browsing...
    Utah
    2020 White 1794 TRD
    TRD Pro skid, Line-X, Tonneau, drivers grab handle, wireless charger, RB 20's, TRD Pro wheels, Gator Liners.
    Not to revive an old thread but one of mine is the same. But, I only noticed after getting my Line X sprayed in. It closes perfectly and contacts the bed latches at the same time. I might need to remove it and re seat it in the brackets where the tailgate is attached to the truck bed. Kind of weird. I thought they were safety but the brunt of the weight was on the hinges anyway. Could be wrong.
  6. Mar 7, 2021 at 2:55 PM
    so_juanderful
    so_juanderful New Member
    Honolulu, HI
    2017 Cement Tundra TRD Pro
    Anybody found what causes it? I noticed my left side is loose, and search tab brought me here.
  7. Mar 7, 2021 at 3:30 PM
    Azblue
    Azblue Beer is Good Ban Moderator
    The Dirty T
    Mine was like that. Dealer replaced under warranty a few years ago. The new cable definitely helped, though it's still slightly slack, but with just a slight pressure (5lbs of pressure or less) it tightens up so I'm not worried at all about it.
