Looking TPMS sensor deal
Discussion in 'Wheels & Tires' started by Viper, Nov 8, 2018.
  1. Nov 8, 2018 at 4:42 PM
    Viper
    Viper [OP] New Member
    C.
    2018 SR5 TRD Dbl cab cement
    Instead of changing out the tires twice a year I bought a new set of wheels and tires for my truck to use for winter driving. When I researched tpms sensors I realized that they were VERY expensive compared to others that I have bought. The part number for the sensor is
    42607-0C091. The cheapest I have been able to find is $58.00 each. Does anyone know where to find a better deal on these?
  2. Nov 8, 2018 at 4:45 PM
    gdiep
    gdiep New Member
    Syracuse, New York
    2014 Red Tundra CM SR5
    FYI- you have to program them each time you switch over. Either the dealer or you need tech stream. I’ve learned to live with the tpms light during the winter.
  3. Nov 8, 2018 at 4:56 PM
    Viper
    C.
    Even though each set of wheels has a sensor in each wheel?
  4. Nov 8, 2018 at 4:56 PM
    Buildn
    Buildn 2017 Tundra Dbl Cab TRD 4x4
    Cleveland, Ohio
    2017 Silver SR5 TRD 4x4 Dbl Cab
    Tinted windows, AVS vent shades, 2018 Toyota LED Headlights, LED Morimoto H11 Fog lights, GTR Lighting LED brake lights & GTR Lighting LED 3rd brake / cargo light kit. TRD center caps, center console tray, Alpine speakers, Alpine amp, Pioneer amp & 10" subwoofer. TRD shift knob, TRD oil cap, TRD radiator cap, Drivers side grab handle.
    Viper,
    I went on Rockauto.com found the TPMS sensors from $30 to $45 Not sure if you have Discount Tire stores in your state but I showed them the Rockauto price and they provided there sensors for $28 each with an 8 year warranty.
    Hope that helps
  5. Nov 8, 2018 at 4:58 PM
    doggiecareman
    doggiecareman YOLO / Best to do it with a Toyota
    Eric
    North Central CT
    2019 TRD PRO CM Sapphire Black
    TRD rear sway bar, BFG KO2's, Truxedo Pro X15 Tonneau, UnderCover swing boxes, DeeZee bed mat, GoRhino BullBar, Weathertec mats F&R, 3M PF and Opticoat Pro coatings, Wesin HDX running boards, wired bedrail lights,
    58.00 is about as cheap as it gets. Normally from the dealer they are 100.00 plus. I struggled with whether to do the 2nd set and decided against it for this reason. As stated above, running them without the sensors is a reasonable option, especially considering it was okay to do so for over a hundred years prior to their implementation.
  6. Nov 8, 2018 at 4:59 PM
    Viper
    C.
    Unless I am wrong the 2018 Tundra uses a different sensor than all other Tundras.
  7. Nov 8, 2018 at 5:07 PM
    Viper
    C.
    My last vehicle was an 03 Dakota that I bought new and drove it until March this year when I bought the Tundra. For the last umpteen years I have been staring at dash lights flashing, blinking, and burning steady in every color imaginable. I know it is petty but I don’t want to see a dash light on my truck for many, many more years.
  8. Nov 8, 2018 at 5:52 PM
    hudrock
    hudrock New Member
    So Cal
    Truck, White, Cool
    Definitely different between Steele and alloys on the 18s. I just went though all this BS. 58 isn't bad for OEM, dealer will charge 100-110 per unit. It's a freaking racket IMO
  9. Nov 8, 2018 at 7:05 PM
    ARES
    ARES ARES Fabrications
    God Bless America
    2018 Tundra TRD Cement
    2018+ Tundras TPMS can only be programmed at the dealer ship and its like $60 Bucks. I went through the headache when I changed out my wheels and tires. And you can only use OEM TPMS sensors.
    Cheapest route just deal with the light on the dash for a few months until you put your regular set back on. And use a manual tire gauge to keep a check on your tire pressures.
  10. Nov 8, 2018 at 7:07 PM
    Thegr8punkin
    Thegr8punkin A G.D.M/Sofa King Cool/COTJ's dreamboat
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    I think @joonbug found some that might work for super cheap...
    joonbug likes this.
  11. Nov 8, 2018 at 7:16 PM
    joonbug
    joonbug bacon bastrd
    Joon
    NorCal - Dublin
    2015 DC 5.7 TRD off-road
    I bought 5 tires from America’s Tires. They matched a price I found online. I think I told them I’d buy it if they hooked me up with some tpms. Normal price was about $60 each. I got them for $30 each.
    Thegr8punkin likes this.
