Looking for some help from a trd pro owner
Discussion in '3rd Gen TRD Pro (2014+)' started by Tundracm16, Sep 25, 2016.
  1. Sep 25, 2016 at 6:24 AM
    Tundracm16
    Tundracm16 [OP] New Member
    Southwestern pa
    2016 tundra crewmax trd
    Trd exhaust, trd sway rear sway bar,spray in bed liner, fold a cover,tint
    I recently swapped out my 14 cm for a 16 and after having that one for 3 years completely stock I've decided I have to do some minor mods to the 16. So I'm looking for so help from a pro owner. And this may have been covered somewhere else in a tread but couldn't find any. Would a owner please measure the height at the most common spots wheel wells and hitch. I would like just to get to pro height nothing crazy I only average 3-4K a year on the truck so I dump a ton off money in my vehicles anymore but I would like to finally do a small lift. I was checking them out and I was thinking either 5100s or a Lrt kit an want no higher than pro.
    Thanks for your help.
  2. Sep 25, 2016 at 4:56 PM
    driverdog
    driverdog New Member
    Virginia Beach
    2015 Inferno pro
    Nerf step bars spray in bed liners window tint integrated brake controller
    I have only replaced the tires...only increasing the width not height unless you factor in different manufacturers.
    Went from Michelin P275/65/18 to Terra Grapplers LT285/65/18
    First picture is Rf:
    RR
    LR:
    LF:
  3. Sep 25, 2016 at 5:03 PM
    driverdog
    Virginia Beach
    2015 Inferno pro
    Rear bumper pic:
  4. Sep 25, 2016 at 5:19 PM
    Tundracm16
    Southwestern pa
    Thx driverdog, that will help out a lot.
    driverdog likes this.
  5. Sep 25, 2016 at 5:23 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    The middle number of the tire size (the 65), is called the aspect ratio. If you go with a wider tire and leave the aspect size the same, you will have a taller tire. 285 * .65 > 275 * .65
  6. Sep 25, 2016 at 5:24 PM
    driverdog
    Virginia Beach
    2015 Inferno pro
    My pleasure,
    Let me know if you need any other measurements.
  7. Sep 25, 2016 at 5:26 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    2015 Tundra SR5, 5.7, 4X4
    Tow Mirrors, 275/60R20 Toyo AT2's
    This. 65% of 285 is greater than 65% of 275.
    NewImprovedRon and driverdog like this.
  8. Sep 25, 2016 at 5:31 PM
    driverdog
    Virginia Beach
    2015 Inferno pro
    I did not know this. I have some learning to do!
    Thanks!
    BlueFalconActual likes this.
  9. Sep 25, 2016 at 5:35 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    :thumbsup:I worked at a tire shop for a couple years before I joined the War Cult. The "Euro Metric" tire measurement system is goofy and requires a calculator to know how tall a tire actually is.
  10. Sep 25, 2016 at 5:42 PM
    driverdog
    Virginia Beach
    2015 Inferno pro
    It makes sense now that you and @mdavis explained it. I had a rather simplistic notion of tire sizes.
    Thanks!
