Looking for creative way to monitor tail gate open and closed position
Discussion in '2.5 Gen Tundras (2014-2021)' started by CanTundra, Mar 6, 2022.
  1. Mar 6, 2022 at 12:20 PM
    CanTundra
    CanTundra [OP] New Member
    2021 Tundra TRD Off Road
    I have seen some that are magnetic contacts vs a standard pin switch .
    let me know your ideas
  2. Mar 6, 2022 at 1:58 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Eyes are the best method I know...;)
  3. Mar 6, 2022 at 2:09 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Anitmatter "container". Closing the tailgate breaks the vacuum causing matter and antimatter to mix....
    ..."BOOM" means the tailgate is closed.
    1UP likes this.
  4. Mar 6, 2022 at 2:16 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Have a friend sit in the back with a cell phone. Tell him to call you whenever the gate opens or there is a status change.
  5. Mar 6, 2022 at 2:16 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    I used this for my bed lights, could be used to power an “open trunk” lamp in the cab somewhere. It’s just an OEM door lamp switch like in the door jamb.
    DCCCC5FA-CFE7-416D-9B7C-EE95F77FFBCE.jpg B1536616-342D-4B43-95FE-EA352C8432AF.jpg
    HulkSmurf14, hANNAbONE, Jego and 7 others like this.
  6. Mar 6, 2022 at 2:22 PM
    panicman
    Eric
    I was joshing!
    You must be doing some activity where this is an issue. What exactly are you doing that would require this kind of monitoring?
    When you start the truck, and then move the gear selector to D, you pass R, which gives you a rear cam view that would tell you if the gate is open or closed.
    Would that suffice for you, or do you do something that requires your gate to open and close while you are in motion?
    I installed a new head unit that allows me a full time chase view:
  7. Mar 6, 2022 at 2:44 PM
    Jim LE 1301 Camaro Lover, SSEM # 11
    Do you have a link for that switch?
  8. Mar 6, 2022 at 3:02 PM
    2mchfun
    The switch/gate ajar lamp combo could get real annoying hauling long cargo, especially in the dark. If it is opening by itself, just fix the mechanism.
  9. Mar 6, 2022 at 3:19 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Get another camera and insert it in your 3rd brake light. Then you can on command see your tailgate and bed as necessary.
    I've been considering this instead of getting a front camera in the grille.
  10. Mar 6, 2022 at 3:30 PM
    1lowlife
    1lowlife Toxic prick and pavement princess
    DADA
    THE GREAT STATE OF TEXAS
    On my 3rd Tundra 2005 DC 2014 DC 2026 CM Limited
  11. Mar 6, 2022 at 3:48 PM
  12. Mar 6, 2022 at 6:32 PM
    Omohundro
    Jody
    McMinnville TN
    No, I stopped by the local salvage yard and got one from a Toyota truck they had there.
  13. Mar 6, 2022 at 6:32 PM
    :thumbsup:
  14. Mar 6, 2022 at 6:33 PM
    Omohundro
    Jody
    McMinnville TN
    I think they charged me 5 bucks for it and the screw.
  15. Mar 6, 2022 at 6:35 PM
    Can't beat that.
  16. Mar 6, 2022 at 7:03 PM
    CanTundra
    That OEM Toyota one is nice but would have to find a connector to match. Thats the idea and water tight
  17. Mar 6, 2022 at 7:59 PM
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    I did something similar. I used a magnetic switch to change the rear camera video signal when the tailgate is open. I added a second camera on top of the tailgate.
    HulkSmurf14 and Saltyhero13 like this.
  18. Mar 6, 2022 at 8:02 PM
    CanTundra
    Thanks guys what I am looking to do is create a switch to add into aftermarket security
    so basically if tail gate opened triggers alarm
    so it would be simple single wire to make ground when tailgate is open
    Jego likes this.
