Looking for 1G Front Suspension Recommendations - Access Cab w/ Winch Bumper
Discussion in '1st Gen Tundras (2000-2006)' started by JustJake, Feb 23, 2021.
  1. Feb 23, 2021 at 11:03 AM
    JustJake
    JustJake [OP] New Member
    2006 AC
    Hi All,
    For the past year, I have been running the OME lift kit and diff drop comprising of 2885 springs and 90004 nitrocharger struts in the front with oem UCAs.
    I have a BFF plate bumper with winch hanging off the front. In the engine bay is an extra battery and an ARB single compressor.
    Even with all this added weight, I am still getting aprox. 2" inches of front lift. (Like a fool, I did not take before and after measurements.
    I am not happy with the ride quality. Driving over a gravel or dirt road is extremely harsh.
    In addition, I have a driveline vibration I have not been able to diagnose.
    Have any other 1G access cab owners had great luck with other lift options? I would even be happy with less lift as I plan on keeping my 32" tires for the foreseeable future.
    I don't want to spend much money, but I do want to improve the ride quality.
    Thanks
  2. Feb 23, 2021 at 11:18 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    03 Tundra AC TRD
    I've been really happy so far with my ADS coilovers. I woult say adjustable coilovers are going to be the best bang for your buck and give you ability to dial in any lean and have it nice and level. Plenty of good CO options that others can chime in with or has been posted already.
    JustJake[OP] likes this.
  3. Feb 23, 2021 at 11:19 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Looking at the ARB specification chart it looks lke 2882 might be your best bet if you want to soften the ride...and it will likely lower it a bit (even though they are the same height, they are softer 500 vs 590lbs) with a bit more sag...but if I was you I would call Wheeler's and ask them based on what you have now. They were very helpful to me...and they have some of their own springs that might be ideal
    https://view.publitas.com/arb-4x4-a...application-catalogue-edition-36/page/178-179
    JustJake[OP] and Darkness like this.
  4. Feb 23, 2021 at 2:22 PM
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    OP says he doesn't want to spend much money. That might be tough to do.
  5. Feb 23, 2021 at 5:47 PM
    Professional Hand Model
    Hand Protectors
    Billys 5100 at one notch up. Remove BF bumper and reinstall Original Sweet Chrome Bumper from Circa 00-02.
    Float like Butterfly and Sting like Bee!
  6. Feb 24, 2021 at 6:43 AM
    JustJake
    2006 AC
    I think my best bet cost-wise is going to be trying another coil spring from OME.
    Wes_heppy and speedtre like this.
  7. Feb 24, 2021 at 6:44 AM
    Wes_heppy
    Wes_heppy Trucks...Dirtbikes... Guns...
    Weston
    2003 tundra 4x4 4.7
    TC UCA Radflo coilovers Long Tubes LSD
    I really like my radflo coilovers. The extended length 2.5in ones were 1300 I believe so if you went with the regular 2in ones it would be cheaper probably about 1000.
  8. Feb 24, 2021 at 12:36 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Even if you go with 2884 or 2883 springs, they are the same spring rate. Just different lengths.
    You'd see more difference in ride quality with better shocks.
  9. Feb 25, 2021 at 5:56 AM
    JustJake
    2006 AC
    Would a Bilstein 5100 be better?
  10. Mar 2, 2021 at 12:14 AM
    wandering_boy
    wandering_boy Junior Tech Wizard
    California
    2005 AC SR5 TRD
    Don't let a kid out smart you.
    I would go with a Toytec coilover I also have a BFF bumper (low pro hoop tho) and a warn 10k winch. Since they are regressive all that extra weight doesn't make it slosh around and the 700 lbs should probably suit your needs. I run these But at the same price I would go for their new fancy ones. They do recommend UCA's but if you already have them or if your not really looking for lift and them with little preload I think you'll be fine. I'm up two inch's and my ball joints have been ok so far but I do plan on getting different ones soon. Also, we may get a discount with them since they are listed as a vendor so you may have money left over for a lift block in the back if need be. They also have killer customer service. Bit hard to reach because I think theres only one or two people in the office, but when you get a hold of them they crush it.
    Dannydirtyfingers likes this.
  11. Mar 2, 2021 at 7:45 AM
    Kcrusher62
    Kcrusher62 New Member
    I went with Radflo and 700 lb Eibach springs, also did SPC upca. Running BFF bumper with full front hoop and 10k warn with synthetic rope.. Radflo are pricey, but pay once cry once,and they are rebuildable. So far happy with set up. does not ride stiff in my opinion. Hope this helps.
    wandering_boy likes this.
  12. Mar 2, 2021 at 6:12 PM
    Hny_Bdgr
    Hny_Bdgr New Member
    black 2000 toyota tundra sr5 v8 4x4
    If it fits it ships
    my ome 2885 springs are sagging with my tacoma arb bumper and harbor frieght winch and group 31 battery i just ordered new ome 2886 springs hopefully i will be able to have my truck squat again
  13. Mar 8, 2021 at 5:41 AM
    JustJake
    2006 AC
    Mine never sagged. You might have received the old style of 2885 which were redesigned by OME to prevent sagging.
  14. Mar 9, 2021 at 8:48 AM
    Hny_Bdgr
    Hny_Bdgr New Member
    If it fits it ships
    i bought mine a year and a half ago
  15. Mar 9, 2021 at 8:55 AM
    JustJake
    2006 AC
    Could be new old stock
  16. Mar 10, 2021 at 10:10 AM
    Hny_Bdgr
    Hny_Bdgr New Member
    If it fits it ships
    could be but i am just gonna upgrade to the 2886s
  17. Mar 10, 2021 at 10:45 AM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    Does anyone here have experience with ADS? Also get your orders in now. The universal basic income check sounds like it will be here shortly. It will cause fun stuff to disappear from shelves again for the next few months.
  18. Mar 10, 2021 at 10:47 AM
    Hny_Bdgr
    Hny_Bdgr New Member
    If it fits it ships
    if they make a 700lb front coil over with an external res ill be interested
  19. Mar 10, 2021 at 6:08 PM
    wandering_boy
    California
    2005 AC SR5 TRD
    I believe they might. They at least do remote reservoirs.
  20. Mar 12, 2021 at 7:52 AM
    JustJake
    2006 AC
    Welp,
    Checked my lift measurements this morning.
    DF: 91.9cm , DR: 98.2cm
    PF: 95.5cm , PR: 96.3 cm
    I think I blew a front nitrocharger shock. Checked my maintenance log, I actually have almost 30k on them.
