Longer wheel studs for 2005 Tundra Limited
Discussion in '1st Gen Tundras (2000-2006)' started by MCLTD, Dec 12, 2025.
  1. Dec 12, 2025 at 5:39 AM
    MCLTD
    MCLTD [OP] New Member
    2005 Toyota Tundra Limited
    hello everyone, new to this forum - i have 2005 Tundra Limited, with 2" lift kit and 1" spacers. Mechanic in Toyota dealership told me that the lug nuts are only 4 threads on as opposed to 7-8, and recommended wheel studs replacement with longer ones.
    Looking for suggestion and links to the websites where I could buy those, for both front and rear wheels. Thank you in advance.
  2. Dec 12, 2025 at 6:01 AM
    2mchfun
  3. Dec 12, 2025 at 7:02 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    I’ve seen someone on here recommending different lug nuts to engage more threads.
    KNABORES likes this.
  4. Dec 12, 2025 at 7:27 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I guess it depends on your spacers and or the nuts that were supplied with them. Mine are 1" hub centric and use an acorn style nut. They thread just fine. The OEM rear hub studs are longer than the front studs, FYI (at least on the 2000 AC)
  5. Dec 12, 2025 at 7:34 AM
    Far left is the extended shank lug vs the standard conical seat on the right. The extended shank allows for more thread engagement in situations like these. I’ve run them on my 1.25” spacers on my truck for 15+ years.
    MCLTD[OP] likes this.
  6. Dec 12, 2025 at 12:07 PM
    MCLTD
    Thank you for the recommendation. I found these on Amazon, apparently compatible with 2005 Tundra: https://www.amazon.ca/KSP-M12x1-5-E...8410446417-B0BLN4CLDH-&hvexpln=0&gad_source=1
  7. Dec 12, 2025 at 12:38 PM
    Are they for the wheel to spacer? Or spacer to hub?
    FrenchToasty likes this.
  8. Dec 12, 2025 at 12:39 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    We like pics….
