Long tube headers for Tundra.....yes or no
Discussion in 'Performance and Tuning' started by AircareTundra, May 25, 2021.
  1. Jan 28, 2026 at 5:53 AM
    #61
    texasrho83
    texasrho83 Ye Olde Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Headers sure do sound good though :p
  2. Jan 28, 2026 at 6:18 AM
    #62
    ProperOne
    ProperOne New Member
    You got two rigs. Ok i follow. DD seems to be setting the bar pretty high in the exhaust category
    im on here for my 5.7L 2nd gen sequoia
    After considering cat back options and price, along with wanting a non common tone, LTHs and a full setup seems reasonable, if theres solid gains to be had over a off shelf Catback
    dirtydeeds likes this.
  3. Jan 28, 2026 at 7:02 AM
    #63
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA 1 7/8 Longtubes, Snivs 1.88 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT Trans/valve body, 4.5inch intake with 10x2 SABM, FIC 880/930cc injectors, 450 Walbro, Direct Port W/M injection, GM 95mm TB, DW fuel regulator, E-fan, Remote engine air/oil cooler, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    Initial development back in 2012-2014 saw 49hp and 89lbs of torque increase for NA.
    455h0le_dachshund likes this.
  4. Jan 28, 2026 at 7:12 AM
    #64
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    According to Doug Thorley, these numbers are possible (expected?):
  5. Jan 28, 2026 at 8:21 AM
    #65
    ProperOne
    What i dont like about these main stream companies/ hence my favoritism towards DirtyD, thorley claims a must have for NA and Super Charged, yet from what im gathering SC sees no benefits
    So why the SC claim Mr Thorley?
  6. Jan 28, 2026 at 8:24 AM
    #66
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    A query with no answer it seems :monocle:
  7. Jan 28, 2026 at 8:49 AM
    #67
    Saltyhero13
    Saltyhero13 Throbbing Member
    30 seems like a reasonable claim with LTH+ Unrestricted catback. I gained ~10HP when I added LTH to my Supercharger and a restrictive stock catback; I've since replaced the exhaust.
    texasrho83 and reywcms like this.
  8. Jan 28, 2026 at 9:56 AM
    #68
    dirtydeeds
    Keith
    USA
    more than I can list here
    When naturally aspirated the gains with headers are huge. We have a direct bolt on header, mid pipe, catback combo specific for a sequoia. Actual engineering, not just throwing parts together. 760-877-4234.
    Keith
  9. Jan 28, 2026 at 9:58 AM
    #69
    dirtydeeds
    Keith
    USA
    It’s easy to sandbag the ‘before’ then take the highest numbers ‘after’.
    that’s the problem with Dyno testing. It’s very subjective. Without an e/t at the track or being there at the Dyno sessions, I’m always Leary when I see claims with just Dyno numbers.
  10. Jan 28, 2026 at 9:59 AM
    #70
    dirtydeeds
    Keith
    USA
    Naturally aspirated, with dual 2.5” exhaust, Thorleys were good for 41hp. 89tq. And .5 seconds in the 1/8 mile.
    Supercharged
    Supercharged, nothing.
  11. Jan 28, 2026 at 10:07 AM
    #71
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    I am supercharged and 3” Long Tubes, generally would say stick to just supercharging and a cat back unless you are doing a full build. The long tubes can be a headache electronically and the gain vs dollar is much lower than supercharging. If you are considering long tubes I would first determine why not supercharge?
    The combo is very fun though and fast.
    455h0le_dachshund and dirtydeeds like this.
  12. Jan 28, 2026 at 10:13 AM
    #72
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
  13. Jan 28, 2026 at 10:16 AM
    #73
    dirtydeeds
    Keith
    USA
    I speak to 10-20 people on the daily. And a lot of them are debating this exact thing.
    long tubes with a proper exhaust is about half the price of supercharging. But supercharging is more gain.
    the part I like better about long tubes, the truck drives exactly the same as it did before the long tubes. No weird shifting. No weird burps or hiccups. Stock reliability. Stock feel. Only more power!!
    M14 EBR and Shanet421 like this.
  14. Jan 28, 2026 at 11:10 AM
    #74
    455h0le_dachshund
    455h0le_dachshund NO MASTERS, NO CHAINS
    Coastal TX
    Penelope & Elvira
    Probably akin to companies that claim gains from so called cold air intakes that are just hot air intakes.
    whodatschrome, Mdl and texasrho83 like this.
  15. Jan 28, 2026 at 11:31 AM
    #75
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    With the 5.7 Tundra...no matter what the performance question is, Supercharging is always the best answer.
  16. Jan 29, 2026 at 5:53 PM
    #76
    ProperOne
    Im with Deeds on this. The most form and function comes from LTHs. No worm can opening unlike SC’in
    literally bolt on LTHs as if they were stock. The job itself is identical to installing factory manifolds/headers. Along with the factory cats and tail section
    no special parts to order or explain, current and future.
    something that speaks to me, with my particular rig, i want no change in reliability or parts ordering. I still want the factory feel with just a rabbit in the hat
    Im rolling factory ride height, factory spec rubber, dropped to an 18 wheel, but thats subtle enough to just make you ponder what is diff.
    Just low ballin, even at 40hp thats incredible. Factor in that a decent cat back runs 1k+, whats a other 1,500$?
    At least that what brought me here. Sourcing a decent cat back and cost, might as well go in once and call it
  17. Jan 29, 2026 at 6:01 PM
    #77
    455h0le_dachshund
    Coastal TX
    Penelope & Elvira
    Factory feel with a rabbit on the hat is the Magnuson TRD supercharger.
  18. Jan 29, 2026 at 6:37 PM
    #78
    Silver17
    Northeast
    2026 Chevy 2500HD L8T 2017 Toyota Sequoia Limited
    LTH is basically 1/4 the price of the SC for 1/4 of the gains. Arguably install labor is at least half of the SC, everyone says it’s a knucklebuster. If you will always be happy with that 1/4 of the gains, or just need that LTH sound then they seem like a good route. If you’re still going to want a blower one day, just save the money and do the blower and skip the LTH IMO.
  19. Jan 29, 2026 at 6:51 PM
    #79
    dirtydeeds
    Keith
    USA
    Very good summary.
    Silver17[QUOTED] likes this.
  20. Jan 29, 2026 at 6:56 PM
    #80
    455h0le_dachshund
    Coastal TX
    Penelope & Elvira
    This.
    I love my JBA LTs, but still want more. I'm just glad I bought before covid wrecked everything and doubled the price.
    I always wanted a v8 and I always wanted headers for it. So when I finally bought my fourth and sixth trucks, they came with v8s in em and they got headers. Now the question for the 03 is do I supercharge, and if so roots or centrifugal... or remote turbo? I want to R150E swap my A340 too.
  21. Jan 29, 2026 at 7:02 PM
    #81
    Silver17
    Northeast
    I vote any positive displacement blower! I’m biased though.
  22. Jan 29, 2026 at 7:06 PM
    #82
    455h0le_dachshund
    Coastal TX
    Penelope & Elvira
    That's 100% my leaning as well. Next year the 03 is emissions exempt, so I'm free to legally do what ever with her. :D
  23. Jan 30, 2026 at 7:12 PM
    #83
    HondaDad
    HondaDad New Member
    Oregon
    2019 TRD Sport
    E/T & trap speed never lie :thumbsup:
  24. Jan 30, 2026 at 7:23 PM
    #84
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    I guess to help out the thread, here is my full 3” exhaust with Long Tubes, dumped after muffler before axle:
    It then sounds like this (with supercharger):
    https://youtu.be/zRBWlkEzP-o
  25. Jan 30, 2026 at 7:35 PM
    #85
    HondaDad
    HondaDad New Member
    Oregon
    2019 TRD Sport
    4.5 0-60 is smashing pretty damn good for something that big
  26. Mar 2, 2026 at 12:29 PM
    #86
    ProperOne
    Any sound clips of long tubes with a more conservative approach with the muffler choice?
    Im trying to hear how LT’s will sound with a more subtle style / factory style muffler
  27. Mar 2, 2026 at 12:33 PM
    #87
    Saltyhero13
    Loud AF is the answer. Muffler style and distance from the engine make a big difference.
    I doubt it but I'll see if I have my old sound clips.
  28. Mar 2, 2026 at 12:36 PM
    #88
    455h0le_dachshund
    Coastal TX
    Penelope & Elvira
    Saltyhero13 likes this.
  29. Mar 2, 2026 at 4:00 PM
    #89
    ProperOne
    Hmmm. Loud AF.
    hmmm Loud AF. The second video driving doesnt sound to loud
    Any start up clips??
    See personally i kinda like the trd exhaust tone that came on the 5.7 trd pro sequoia as an option.
    Not sure if the tundra was the same. I believe the tundra came two outs and the sequoia was a single rear section
    Id like to see if anyone accomplished a more “factory style” tone vs the overly aggressive
    Perfect world for me, just want the hp gains with a more tame not so deep and throaty
    Almost like an AMG or the escalade. Wanting that luxary note, not offroad chambered
  30. Mar 2, 2026 at 4:09 PM
    #90
    455h0le_dachshund
    Coastal TX
    Penelope & Elvira
    It's really not loud at all with the TRD catback. Even with the LTs and the resonator delete.
    I'll try to remember to get a start up video when I leave for work in a few. This is the 4.7L btw.
