Locking issues
Discussion in '2.5 Gen Tundras (2014-2021)' started by Navygunner, May 21, 2020.
  1. May 21, 2020 at 6:32 PM
    Navygunner
    Navygunner [OP] New Member
    2020 tundra crewmax 4x4
    6 inch rough country lift, 35” pro comp tires, S&B cold air intake
    Has anyone had locking issues? Key out of the ignition and key FOB won’t work. Key in hand and try to lock the truck with the driver side console and it locks and switches back in locked... can’t even use the key FOB to lock the doors only by hand using the key.
  2. May 21, 2020 at 6:42 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    No... that sounds weird. I’d take it in and have them look at it.
  3. May 21, 2020 at 6:50 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Does your truck have push button start? If so, perhaps the switch that tells the ecu the truck is in park is not made.
  4. May 25, 2020 at 2:43 AM
    Navygunner
    No push button start on my truck. The key FOB only works in the morning when I go to work. One time. After the truck has sat over night. I tried the spare key and it doesn’t work either.
  5. May 25, 2020 at 5:23 AM
    Anthony605
    Anthony605 New Member
    Anthony
    2020 Limited Double Cab
    By any chance did you switch any of your bulbs (especially the bed lamps) to LED? I had that issue on m 2020 when I installed some LED bulbs. I switched everything back and all is good.
  6. May 25, 2020 at 1:43 PM
    Navygunner
    No have not done anything to my truck in over a month. It’s only 3 months old...
  7. May 25, 2020 at 3:08 PM
    TTund16
    TTund16 New Member
    Good to know. Wonder what caused that? Did the bed lights work after switching to LED? Nothing got shorted?
  8. May 25, 2020 at 3:12 PM
    TTund16
    TTund16 New Member
    I am sure the fob batteries are ok being 2020. No?
  9. May 25, 2020 at 3:17 PM
    Navygunner
    Fob batteries are fine. The truck is only 3 months old. I even tried the spare key and same issues.
  10. May 25, 2020 at 3:41 PM
    Anthony605
    Anthony
    TTund16 -- It was actually RF interference given off by the bulbs that caused my issues. As soon as I switched back to the regular bulbs, everything was all good.
    TTund16 likes this.
  11. May 25, 2020 at 3:51 PM
    TTund16
    TTund16 New Member
    @Anthony605
    I've read that LED lights can cause issues with garage door openers but didn't know how common that was. Good to know!
