Lock-N-Lube Grease Gun Coupler
Discussion in '2.5 Gen Tundras (2014-2021)' started by rodm1, Jul 17, 2022.
  1. Jul 17, 2022 at 9:37 AM
    rodm1
    rodm1 [OP] New Member
  2. Jul 17, 2022 at 10:42 AM
    RustyShackle323 and FrenchToasty like this.
  3. Jul 17, 2022 at 10:47 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I posted in the home improvement section a while ago but the lock and lube gun I got from Germany is great!!!!! It uses no springs so the grease is never under pressure to spooge out any of the small cracks and loose connections. Highly recommended!
    Prostar 190 likes this.
  4. Jul 17, 2022 at 11:08 AM
    rodm1
    Are they still made in Germany I see the pneumatic one is made in India? I'm going to pick one up and give it a try you need 3 hands any other way.
  5. Jul 17, 2022 at 11:10 AM
    FrenchToasty
    Mo
    Bone stock
    Maybe? Let me check my big gurl list
  6. Jul 17, 2022 at 11:12 AM
    FrenchToasty
    Mo
    Bone stock
  7. Jul 17, 2022 at 11:27 AM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    Another vote for the lock n lube. Hands free once you clamp it on. Holds tight. Never pops off and never leaks. And look into a battery powered grease gun. You’ll do the maintenance more often because it’s so easy.
  8. Jul 17, 2022 at 11:30 AM
    This is what I do I run it on a Milwaukee grease gun.
    FrenchToasty likes this.
  9. Jul 17, 2022 at 11:32 AM
    FrenchToasty
    Mo
    Bone stock
    Are most of your zerks easily accessible? A lot of mine are in tight spaces where I’m not sure I’d be comfortable with the Milwaukee.
  10. Jul 17, 2022 at 12:12 PM
    Some what.
  11. Jul 17, 2022 at 1:55 PM
    babyshark
    babyshark New Member
    Where is this point you have to grease (picture?) and how often do you need to do it? Lock and lube is awesome.
    RustyShackle323 likes this.
  12. Jul 18, 2022 at 8:44 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    I have the regular LockNLube coupler (not the XL) and this adapter and can get to all the fittings on the drive shaft....
    https://locknlube.com/collections/greasing-accessories/products/locknlube-simple-90-coupler
    rodm1[QUOTED][OP] likes this.
