Lift questions for 2018 tundra
Discussion in 'Suspension' started by Crewmax34, May 22, 2018.
  1. May 22, 2018 at 3:16 PM
    Crewmax34
    Crewmax34 [OP] New Member
    I’m looking for help lifting my quicksand tundra thinking about the Bilstein 5100s Leveling struts with the matching rear shocks but not sure what setting the front needs to be I have done some measurements so any pictures or advice on setting for the front would be of great help.
    TXRailRoadBandit73 likes this.
  2. May 22, 2018 at 3:17 PM
    Welcome from Texas, Let's see your ride
    Crewmax34[OP] likes this.
  3. May 22, 2018 at 3:54 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Welcome from Las Vegas.
  4. May 22, 2018 at 3:57 PM
    Crewmax34
    Newm likes this.
  5. May 22, 2018 at 6:01 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    If you are not lifting the rear set the fronts at 2" or you can go higher and add shackle on rear. 2" on front will get you level. If you want to maintain rake then add shackle. Keep in mind that 3" on front can get more complicated when it comes to alignments.
  6. May 22, 2018 at 6:15 PM
    Crewmax34
    I’m planning on running 285s so do you think I can get by ok with the Bilstein 5100s set on the middle setting if what I’ve read so far is correct and taking into consideration that my math is right there should only be about a 3/4 of and inch difference in front and rear but correct me if I’m wrong.
  7. May 23, 2018 at 3:22 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Shocks wont give you any rear lift
  8. May 23, 2018 at 8:16 AM
    hitech
    hitech New Member
    Blair
    SOMD
    2018 CM TRD OR Limited
    I have pretty much the same truck, 2018 TRD OR Limited in quicksand. I don't have any pictures but I will take some when I get home. I just had 5100s put on yesterday and had them set to the middle setting, which is about 1.5" lift, did nothing to the rear, just wanted to remove some of the rake. My front sits at just over 38" measured from the center of the fender well opening to the ground, and the rear is just over 39". I was at 36.5" in the front before the install. There's a slight lean on the drivers side, but it was there on the stock setup as well. The difference between the driver and passenger side is about .5", the passenger side being higher. So, if you do this, measure first, then if you are off as well, install a shim in the drivers side to correct for the lean.
    I have about 1 inch difference front to back on drivers side, and about .5" on passenger side.
    It drives excellent, no difference from OEM shocks, and looks better IMO. I don't plan on doing the rear because when I did my Tacoma, it introduced a bit of shake at certain speeds. The Tundra may be different, but that was my experience. As far as fitting bigger tires, I'm not sure. I'm sticking with stock tires until these wear out, then maybe going up 1 size.
    Hope this helps you. I'm new to this site, and I see you are too, so Welcome!
    mattyd170 likes this.
  9. May 23, 2018 at 8:30 AM
    Rica25
    Ricardo
    Tulare
    I did mine at highest setting in front and after about 6 months I added the 1 inch rear block and have all four 5100s
  10. May 23, 2018 at 3:47 PM
    hitech
    hitech New Member
    Blair
    SOMD
    Update to my earlier post:
    Here's a picture of mine before the 5100s and after.
    Before:
    After:
    I have no plans to do anything else to the suspension, maybe better tires down the road but I like the stock rims and it rides so damn nice the way it is.
    mattyd170 and r1-superstar like this.
  11. May 24, 2018 at 2:04 AM
    Crewmax34
    Good looking truck what tire size do you plan on running with it set on the middle setting thanks for the advice.
  12. May 24, 2018 at 2:40 AM
    hitech
    hitech New Member
    Blair
    SOMD
    I may go with 275/70 R18, which is one size up, however, the stock tires and size don't bother me. I could go a little big than that but not really feeling it. Good luck in whatever you do, hope my post was of some help.
  13. May 24, 2018 at 5:30 AM
    Crewmax34
    Was wandering if a 285 would fit with the Bilstein set at the middle set do you know anyone who has that kind of set up. Thanks
  14. May 24, 2018 at 6:52 AM
    hitech
    hitech New Member
    Blair
    SOMD
    Sorry, I don't really know anyone personally that has this setup, however, I think that there are quite a few on this forum that have just the front on 5100s and have bigger than stock tires. As long as you don't go wider than stock, I think you'd be OK with a taller tire, but I would do some searching here and see who else is running those size with a front 5100 lift.
  15. May 24, 2018 at 9:20 AM
    Crewmax34
    Thanks for your help.
  16. May 24, 2018 at 9:54 AM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    285/65/18 will fit without a lift. Ran ko2’s with that size of tire for almost 2 years.
  17. May 24, 2018 at 10:17 AM
    Crewmax34
    Going with a 285/70/18 toyo lift or no lift?
  18. May 24, 2018 at 12:01 PM
    Crewmax34
    Anybody running B8 5100 Bilsteins on the middle setting that will upload pics with a 285/70/18 tire?
  19. Jun 22, 2018 at 10:51 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
  20. Jun 27, 2018 at 3:43 PM
    hitech
    hitech New Member
    Blair
    SOMD
    r1-superstar[QUOTED] likes this.
  21. Jun 27, 2018 at 4:44 PM
    r1-superstar
    DB
    UTAH
    My Bilstein 5100 leveling struts arrived today. I will post pics of before and after. I'm only doing the front though.
  22. Jun 27, 2018 at 5:16 PM
    joesTundra
    joesTundra New Member
    Joe
    2018, Toyota Tundra Limited, TRD 4x4 off road
    I like the OEM from Toyota. all depends the style or the purpose. mine are use as a step for people to get in, plus if you live in snow
    area. the boards that hang down a couple inches from the body you can keep the snow from building up and also the running''
    boards that are flush to the bottom of your sills are small, and difficult to use when stepping up to get in the truck. good luck
    and enjoy new sliders
