Lift n and 35s
Discussion in '2.5 Gen Tundras (2014-2021)' started by TXRailRoadBandit73, Jun 26, 2016.
  1. Jun 26, 2016 at 3:03 PM
    TXRailRoadBandit73 [OP] YOTAS,RAILROADIN',RÖKnRÖLLN',BEER,MAX/GEMMA
    Anyone out there running 35x12.5R20 with a 3-1 kit with or without skid plate? like I've stated soooo many times before I have a rough country 4.5 kit I don't like it...truck came that way from dealer bought truck used jus want some input from Tundra World owners '14+ I wana lower cause I had a '13 with same tires...tires rubbed oem skid plate a bit but I removed also any diff on '13 to '14 front end?
  2. Jun 26, 2016 at 5:57 PM
    jlee
    jlee New Member Vendor
    jerry
    Bay area CA
    2016 TRD Off Road on 35's supercharged and Kings and A 2002 SAS'ed supercharged Tacoma on 37's Linked front and rear
    Oh one or two.
    35x12.50's maybe a 1.5" lift in the front and no skid at the moment.
    Is the crossmember cut out with the 4.5" lift as well? If so it will be hard to revert to a 3".
  3. Jun 26, 2016 at 7:29 PM
    It's the entire kit from rough country look it up 4.5" 2 cross members front and rear diff drop kit blocks for rear spacers over coils larger knuckles skid plate jus don't like CV axle angels...when I had the 2013 it had same tires 35*12.50r20 with a 3-1 with oem skid plate n tires rubbed a bit on plate ...so this '14 I have has the 4.5 kit turning radius decreased just too high bout truck used n came with this kit think i wana do 3-1
  4. Jun 26, 2016 at 7:32 PM
    I called the outfitter store that put kit on they said I would need to buy the oem knuckles and oem cross members too if I do a 3-1
  5. Jun 26, 2016 at 8:23 PM
    jlee
    jerry
    Bay area CA
    Oh one or two.
    I didn't think you could buy an oem crossmember. It's cut out when doing a drop bracket lift.
  6. Jun 27, 2016 at 2:48 AM
    So I'm screwed?!?
  7. Jun 27, 2016 at 4:43 AM
    jlee
    jerry
    Bay area CA
    Oh one or two.
    Pretty sure unless you know a shop that does them all the time that can take thier time cutting one out so it can be welded back into your truck.
  8. Jun 27, 2016 at 11:43 AM
    OMG thanks
  9. Jun 27, 2016 at 12:02 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  10. Jun 27, 2016 at 12:06 PM
    csuviper
    Broomfield, CO
    No mention of cutting the front cross-member. Take a look underneath your truck at the front crossmember. See if the stock one is cut at all.
  11. Jun 27, 2016 at 12:15 PM
    jlee
    jerry
    Bay area CA
    Oh one or two.
    Yeah they don't say to cut it.
  12. Jun 27, 2016 at 12:27 PM
    csuviper
    Broomfield, CO
    I am going to say that it is not cut. So lets see what would need to be replaced:
    I'm thinking if you get a complete 3/1 kit all you would need to replace would be the spindles. You should be able to find a set of used ones from others that go to a 4"+ lift.
    You should get new seals. I didnt fully read through it but you may also need some hardware if it was replaced with something provided with the kit.
  13. Jun 27, 2016 at 3:23 PM
    Thanks a million
  14. Jun 27, 2016 at 3:27 PM
    csuviper
    Broomfield, CO
    Since we are on the topic of 3/1 lifts, have you made a decision of which you are going to go with? Budget?
  15. Jun 27, 2016 at 6:12 PM
    Really have no which I need to choose toytec or readylift
  16. Jun 27, 2016 at 6:19 PM
    Also looked carefully under front end looks like no cuts made to cross members I jus need original knuckles n seals
